Problem with UPS 850
  • aliiash
    • Jun 2019
    • 99
    • england
    My UPS 850 charging battery normally but if I press the power switch it work for only one second then turns off and not found any volt on output voltage port . What can I do in this situation ?
  • dmill89
    • Dec 2011
    • 2534
    Re: Problem with UPS 850
    How old are the batteries and have you checked the voltage? Many (most) UPSs have very "dumb" charging circuits (often only a constant float voltage with no regulation) that will try to charge a completely flat battery (I've seen many keep trying to charge a dead battery even after it had overheated to the point the case split open). Aside from that check for bad caps, if there is a fan make sure it is working (many consumer-grade UPSs uses cheap sleeve bearing fans with a high failure rate), and if you rule those out check any transistors to and relays see if they are good.
    • aliiash
      • Jun 2019
      • 99
      • england
      I changed the battery and charged. All components work normally, but if you press the power switch, UPS works for only one second and then turns off
        How did you charge the battery? What is the Voltage at the battery terminals with and without the USP plugged into the AC oulet?
        • SoporteHR
          • Sep 2018
          • 80
          • Venezuela
          Hi. The new battery is realy new?
          Check voltage of the battery with load. example a light incandecent.
          If the battery voltage drops considerably with the bulb connected, it is damaged. (Nominal 12vdc, with the bulb, goes down to 7vdc) the battery is damaged.
          Check the status of the switching relays, check the contacts and check their coils.
          It also checks the transformer transistors or mosfets.
          Perhaps this one is open and is not doing the work of generating the output voltage to the transformer.
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • Woodsworth
            PS3 CECHC03 60GB YLOD Troubleshooting
            by Woodsworth
            I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
            START
            Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
            03-19-2024, 07:58 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • Rick_1234
            by Rick_1234
            Good evening, gentlemen.
            Things I tried
            06-22-2024, 04:44 PM
