Help identity blown part in Alesis Mixer PS
  • Carm99
    • Jun 2014
    • 69
    • England
    Alesis Multimix 16 firewire
    Small capaciter is blown and I dont know the size to get, as I can't get the Service Manual Online.
    Just asking if anyone has the manual or knows what size it might be .
    Heres a photo
    Its on the leg of a 7815 Voltage Regulator.
    Thanks.
  • R_J
    • 9582
    Re: Help identity blown part in Alesis Mixer PS
    It's likely a .33µf, if on the input or .1µf if on the output
    • Carm99
      • Jun 2014
      • 69
      • England
      Thanks Man.
      I'll check...
      Its between the middle leg ,Ground ,and the Input ,from a 2200uf 35 volt cap.
      There was a big flame when it blew.
      Do you think the cap might have been bad to cause it to happen.?
      Cheers.
        • 31163
        ceramic caps randomly fail, and go short circuit.
        surfacemount ones can also fail from flexing - like if the board is dropped or bent.
        where in London are you??
        • Carm99
          • Jun 2014
          • 69
          • England
          I replaced 7815 and 7915 prior to it blowing as they were bad.
          I thought that was it. It worked ok but no output on the master as if the channels outputs weren't getting sent or not being recieved.
          Im a novice really but if i can test individual parts that are bad I can change em out.
          Im repairing it to sell. Its in bits at the moment.Im cleaning it up a bit.
          Im in NW London.
          • R_J
            • 9582
            The cap value in this case is not that critical, It is mainly there to prevent high frequency noise and prevent the ic itself from self oscillating.
            If you don't want to order one, or don't have a cap meter to check values, check scrap boards and find one that is close to the size of the old one and it should work just fine.
            • Carm99
              • Jun 2014
              • 69
              • England
              Ive got a meter but the cap is blown so cant be measured.
              I was thinking it might be the same as the other one on the 7915.
              • R_J
                • 9582
                PC20 & PC30 should be the same value (input to ic)
                  • Jul 2011
                  • 6059
                  Can you please post a photo of the front of board
                  • Carm99
                    • Jun 2014
                    • 69
                    • England
                      • Jul 2011
                      • 6059
                      This should fairly easy to fix as far as I can see from what I can see from the the photo that you have provided
                      I would check all the surface mount caps for shorts and check all of diodes for open or for shorts
                      I would also check all other caps for there ESR value if you have that type meter you can also check the surface mount caps as well
                      What are the parts number that are NOT LM7815 or LM2575
                      there is another part that starts with LM25–>something
                      What is the part number of PQ1
                      I hope this will help
                      • Carm99
                        • Jun 2014
                        • 69
                        • England
                        There are 2 LM2575's.
                        The PQ1 is BD239C.
                          • Jul 2011
                          • 6059
                          Please post your results of what you find wrong with this power supply
                          • R_J
                            • 9582
                            Are you still having problems with the mixer after repairiing the power supply? or are you still missing voltages?
                            It looks like they are just using .1µf caps on both the input and outputs of the regulators
                            • Carm99
                              • Jun 2014
                              • 69
                              • England
                              The 2200 big cap on the board is testing 0.00Ω esr.
                              • R_J
                                • 9582
                                Are you saying the 2200µf is shorted? are you checking the esr out of circuit?
                                • Carm99
                                  • Jun 2014
                                  • 69
                                  • England
                                  I used a MK-328 to test it and thats what it said i even reversed the leads and tested it the other way.Same thing
                                  • Carm99
                                    • Jun 2014
                                    • 69
                                    • England
                                    Yeah.Out of circuit.
                                    • R_J
                                      • 9582
                                      Is the power supply working or not? As long as the cap is not shorted (check it with your multimeter (ohms) I suspect it is ok
                                      • Carm99
                                        • Jun 2014
                                        • 69
                                        • England
                                        Nope.No Resistance on the multimeter.
                                        • swerg
                                          Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                                          by swerg
                                          Hey everyone,
                                          I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                                          I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                                          I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                                          06-06-2024, 03:39 PM
                                        • edugimeno
                                          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                          by edugimeno
                                          Hi There!
                                          I'm trying to help my friend who owns a restaurant be just bought.
                                          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                          It's stuck using, I guess, the 2 sided tape that comes with the strip
                                          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                          09-05-2024, 09:34 AM
                                        • G-Sting
                                          iPad Pro A1876 SHORT Part Identify Help Needed
                                          by G-Sting
                                          So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                                          So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                                          i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                                          SO My main concern is what part should i order what should i search the name for ?
                                          on Ipad...
                                          05-15-2025, 09:30 AM
                                        • ibo
                                          MSI GS75 10SF-227 Stealth identifying Blown part
                                          by ibo
                                          Hi guys,
                                          Hope someone can help me out here. i have this laptop and it wont Boot.
                                          now i found this blown part from motherboard but i dont know what it is and what the model nr is to order a new one. i didnt found schematics or boardview for this model. I think PU33 is the same chip....
                                          03-02-2023, 02:06 PM
                                        • Longon
                                          Behringer Pro Mixer DJX-750
                                          by Longon
                                          Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
                                          08-11-2025, 02:17 PM
