Help identity blown part in Alesis Mixer PS
  • Carm99
    • Jun 2014
    • 69
    • England
    Alesis Multimix 16 firewire
    Small capaciter is blown and I dont know the size to get, as I can't get the Service Manual Online.
    Just asking if anyone has the manual or knows what size it might be .
    Heres a photo
    Its on the leg of a 7815 Voltage Regulator.
    Thanks.
  • R_J
    • Jun 2012
    • 9535
    Re: Help identity blown part in Alesis Mixer PS
    It's likely a .33µf, if on the input or .1µf if on the output
    • Carm99
      • Jun 2014
      • 69
      • England
      Thanks Man.
      I'll check...
      Its between the middle leg ,Ground ,and the Input ,from a 2200uf 35 volt cap.
      There was a big flame when it blew.
      Do you think the cap might have been bad to cause it to happen.?
      Cheers.
        • 31010
        ceramic caps randomly fail, and go short circuit.
        surfacemount ones can also fail from flexing - like if the board is dropped or bent.
        where in London are you??
        • Carm99
          • Jun 2014
          • 69
          • England
          I replaced 7815 and 7915 prior to it blowing as they were bad.
          I thought that was it. It worked ok but no output on the master as if the channels outputs weren't getting sent or not being recieved.
          Im a novice really but if i can test individual parts that are bad I can change em out.
          Im repairing it to sell. Its in bits at the moment.Im cleaning it up a bit.
          Im in NW London.
          • R_J
            • Jun 2012
            • 9535
            The cap value in this case is not that critical, It is mainly there to prevent high frequency noise and prevent the ic itself from self oscillating.
            If you don't want to order one, or don't have a cap meter to check values, check scrap boards and find one that is close to the size of the old one and it should work just fine.
            • Carm99
              • Jun 2014
              • 69
              • England
              Ive got a meter but the cap is blown so cant be measured.
              I was thinking it might be the same as the other one on the 7915.
              • R_J
                • Jun 2012
                • 9535
                PC20 & PC30 should be the same value (input to ic)
                  • Jul 2011
                  • 6039
                  Can you please post a photo of the front of board
                  • Carm99
                    • Jun 2014
                    • 69
                    • England
                      • Jul 2011
                      • 6039
                      This should fairly easy to fix as far as I can see from what I can see from the the photo that you have provided
                      I would check all the surface mount caps for shorts and check all of diodes for open or for shorts
                      I would also check all other caps for there ESR value if you have that type meter you can also check the surface mount caps as well
                      What are the parts number that are NOT LM7815 or LM2575
                      there is another part that starts with LM25–>something
                      What is the part number of PQ1
                      I hope this will help
                      • Carm99
                        • Jun 2014
                        • 69
                        • England
                        There are 2 LM2575's.
                        The PQ1 is BD239C.
                          • Jul 2011
                          • 6039
                          Please post your results of what you find wrong with this power supply
                          • R_J
                            • Jun 2012
                            • 9535
                            Are you still having problems with the mixer after repairiing the power supply? or are you still missing voltages?
                            It looks like they are just using .1µf caps on both the input and outputs of the regulators
                            • Carm99
                              • Jun 2014
                              • 69
                              • England
                              The 2200 big cap on the board is testing 0.00Ω esr.
                              • R_J
                                • Jun 2012
                                • 9535
                                Are you saying the 2200µf is shorted? are you checking the esr out of circuit?
                                • Carm99
                                  • Jun 2014
                                  • 69
                                  • England
                                  I used a MK-328 to test it and thats what it said i even reversed the leads and tested it the other way.Same thing
                                  • Carm99
                                    • Jun 2014
                                    • 69
                                    • England
                                    Yeah.Out of circuit.
                                    • R_J
                                      • Jun 2012
                                      • 9535
                                      Is the power supply working or not? As long as the cap is not shorted (check it with your multimeter (ohms) I suspect it is ok
                                      • Carm99
                                        • Jun 2014
                                        • 69
                                        • England
                                        Nope.No Resistance on the multimeter.
                                        • cmlewis89
                                          LG 47LB5DF blown power supply board
                                          by cmlewis89
                                          Hi folks,
                                          I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                          09-03-2024, 07:50 PM
                                        • Bektronics
                                          Schematic Digital Audio mixer RCF type M18
                                          by Bektronics
                                          Hello dear audio friends.
                                          I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
                                          The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
                                          I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
                                          Thanks in advance if anyone can help me with this schematic.
                                          Of course, all information about this digital mixer and possibly references...
                                          07-24-2023, 06:40 AM
                                        • drscoot
                                          HP X360 convertible battery blown fuse error, not charging
                                          by drscoot
                                          HP Modelnumber: 14-dh0061nb​
                                          This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                          The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                          I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                          And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                          All these 3 batteries are charging...
                                          12-15-2023, 05:54 AM
                                        • Thermaltake
                                          Yahama mixer PSU difference
                                          by Thermaltake
                                          I am planning to buy myself a new mixer. Yamaha MG12U or XU(not sure) and I always like to take a look inside of mixer to check how it looks, if caps are low quality and other stuff.
                                          I manage to find some teardown video on youtube but video name is saying MG12XU, but when you look at video on mixer it's MG12U.
                                          And when I google those two models they have different PSUs one have cheap low quality caps, and other is way better with quality ones Nichicon. So I am confused now from what model exactly is that better PSU??
                                          I google a little and found that there is this part number...
                                          09-17-2024, 11:52 AM
                                        • Thermaltake
                                          Power button on Behringer Xenyx 1204USB mixer dead ?
                                          by Thermaltake
                                          Hi, I got Behringer Xenyx 1204USB mixer, and in the morning mixer was working fine, but when I came home from bike ride I turn it On but nothing happend. Phantom switch is working because red light is On, but other switch no respond.
                                          I brought mixer to my friend today who is electronic expert and he will tell me if it's the button or something on power supply that died. But I am 90% sure that it's power button. My question is, is it possible to put some better quality switches on that mixer than the ones mixer came with, I found them very cheap and low quality.
                                          08-16-2022, 03:22 AM
