L&C LC-B450E: Shorted secondary switchers?
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Hello all. Several months ago, I received a computer with a bad PSU. The computer didn't turn on at all. Further testing revealed that the 5VSB rail and PS_ON were present, but upon shorting PS_ON to GND to force the unit to start up, all the rails went dead.
    I've done some thinking recently and I'm wondering if this is a common sign of one of the secondary switchers being shorted. Any thoughts?
    FYI, not trying to repair this right now, but I'm keeping it around as a potential repair project for when I get some decent soldering equipment.
    TIA
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    Re: L&C LC-B450E: Shorted secondary switchers?
    I had one like that and I fixed mine by replacing all the rectifiers on the secondary. Not sure if the same applies here, but worth a shot.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
    • R_J
      • Jun 2012
      • 9633
      What do you mean all the rails went dead? did they have voltage before? or do you mean the standby 5vsb went dead now too?
      I would suspect shorted fets in the primary, when you forced the power supply on it likely blew the main fuse. so no more standby.
      • TechGeek
        Computer Geek
        • Jan 2015
        • 2254
        5VSB was present until I forced it on. Then nothing on all rails UNTIL I removed the jumper forcing it on. A second or 2 later, 5VSB came back. Fuse is intact.
        sigpic
        • R_J
          • Jun 2012
          • 9633
          Here are two versions for the the LC-B250 model, might be similar
            master hoarder
            • May 2008
            • 12175
            The 5VSB shouldn't die, even if the main PS has a fault, because these are separate PSs. The only two cases where I think this could happen is if:
            1) input NTC/thermistor has developed high resistance, thus allowing enough current for the main caps to charge and the 5VSB to run, but not enough for the main PS to run.
            2) driver transistors for the main PS on the secondary side (near middle/driver transformer, typically) may be shorted and pulling the 5VSB's secondary auxiliary winding low and causing 5VSB to shut down / go out of regulation.
            In any case, it should be fairly easy to fix the issue as these L&C PSUs aren't that complex really. In fact, if built well, they are pretty robust designs. Just very outdated, inefficient, and often without good output protections aside from short-circuit (and sometimes even that is not implemented properly, as I've seen some H-bridge PSUs not latch-down after short-circuit.)
            Also, you don't really need a special soldering iron to work on these. A 40-Watter will typically desolder anything in this PSU. Combined with a solder sucker, you should even be able to get the heatsinked components out, if need be. Though personally, most of the time I don't bother to do that with these cheap PSUs, as they are so gutless that I can work on them often without removing much of anything.
            • reessi
              Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
              by reessi
              Hello:
              I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
              I started on the ACER:
              Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
              All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
              I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
              10-29-2024, 11:31 AM
            • Yanleb
              Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
              by Yanleb
              Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
              I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
              D608, good
              D618 RF101L4S, good (See warning 1 below)
              D619 RF101L4S, good (See warning 1 below)
              D865 RF101L4S, shorted (See warning 1 below)
              IC464 Inverter HA MC74HC1G14, shorted...
              03-09-2020, 12:00 AM
            • modtool
              HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
              by modtool
              Hi to all,
              the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
              I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
              I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
              04-01-2025, 08:22 AM
            • BalkanBoy
              Dead Razer Blade 14 2022, shorted CPU?
              by BalkanBoy
              today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
              Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
              I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
              Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
              I removed coil and injected 0.7V, it draw around...
              09-27-2024, 12:44 PM
            • barry101
              Apple 820-3662 VCore shorted to ground.
              by barry101
              Hi, Would appreciate some help.
              I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
              Get charger light but no fan spin or chime. No liquid damage.
              Found PPBUS and VCORE both shorted to ground. Other rails were ok.
              Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
              With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
              Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
              06-24-2025, 07:34 AM
