Help identifying power ic?
  • berthfield
    • Mar 2016
    • 7
    • Jamaica
    Good Day,
    I was recently presented with a inexpensive DVR that had a short in its power supply. After searching I was able to isolate the issue to the 5v rail, specifically a 6pin IC with the markings DDAAC. It seems to be some form of power ic or a buck converter or sorts.
    I have been searching but cant seem to find a way to identify these ICs, could you point me in the right direction please. Attached to this post is an image showing a similar circuit on the board that is unaffected.
    Thanks in advance.
    Last edited by Per Hansson; 02-22-2019, 03:44 PM. Reason: Offsite image uploaded & link fixed
  • R_J
    • 9535
    Re: Help identifying power ic?
    I can't see anything but an [X]
    • PeteS in CA
      • Aug 2005
      • 3580
      • USA, Unsure of Planet
      Either img tags are not working, or vBulletin is not recognizing the imgur page as an image, https://imgur.com/a/2oQ3LXE .
      I can't see clearly any IC such as berthfield described, but there is an electrolytic cap in the pic that clearly is swollen and vented.
      PeteS in CA
      • R_J
        • 9535
        U4 looks like a sot23-6 LDO, Maybe post the model number, maybe there is a schematic around
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Well, it's because it's a link to a webpage, not an image...
          I fixed the link now...
          • berthfield
            • Mar 2016
            • 7
            • Jamaica
            I changed that cap after taking the picture. The IC turned out to be a LDO as suggested but after searching for a few hours I was unable to find any replacements locally. The only markings on it were DDAAC not sure what that was supposed to signify.
            Edit: Forgot to mention that in the interest of time I removed the offending component and just went with a 7805 mounted to the side for 5v supply. There aren't many SMD suppliers locally and I was not willing to wait.
            Thanks all for your help.
            • Amraks
              • Nov 2011
              • 725
              working on the same board at the moment.
              where U5 is fried no voltage for the mouse is the only issue.
              I am suspecting its the same as U4 at the moment can't tell as the top has been burnt off.
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
                by sam_sam_sam
                03-31-2024, 02:12 PM
              • krob80
                PS5 Edm-010 No Power - Help identifying missing capacitor
                by krob80
                Hey everyone. I recently acquired a PS5 that is not turning on (no beep/power). PSU is good and there is no shorting on the 12V rail.
                It came with a Gen3 SSD installed so I feel that things went down hill for the previous owner when it was installed. F7003 was blown but there was nothing shorting to ground. I replaced the fuse but still no power (new fuse is still good for now).
                When connecting it to a bench power supply, it only pulls 10 mA (doesn't spike when first connected).
                I noticed that there are a couple capacitors missing from the Vcore power regulator (pictures attached)....
                05-15-2025, 04:24 PM
