This is a sticky topic.
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    #3001
    Well, the most recent date code I spotted in the pix was "9752", on the PCB. So this was built in early 1998. This is consistent with the .7A 5VSB rating.
    Late 90's sounds about right, especially with that 5VSB spec, as you mentioned. Also, I just noticed a Gateway logo on the second case shot, so this most likely came out of a Gateway PC.
    We had to change the 7805 to an LM317, because the 5VSB turned on too fast with the 7805. By using the LM317 we were able to use a cap across an adjustment resistor to slow the 5VSB rise time. The customer, Sun Microsystems, was concerned that too fast a rise time might damage CMOS gates in the relevant circuits.
    Interesting.
    I suppose that was a valid concern back in the day, as many motherboard ICs were directly connected to the PSU rails, including 5VSB. Actually, I think this went on pretty much until late-era socket 462 and 478 boards.
    One of the reasons why many eMachines PCs died from the infamous Bestec ATX-250-12E PSU is because the socket 462 boards in those PCs typically had their LPC SIO, as well as some other TTL power control logic circuitry directly connected to the 5VSB. Thus, with the 5VSB from the Bestec overshooting to 10V or more, many of those ICs died. I actually have a board like that in my "for a rainy day" pile that I've attempted to fix. Most of the TTL ICs I mentioned were rated for 4.75V-5.25V. So no wonder they released the magic smoke.
    Nowadays, the 5VSB on motherboards usually goes through a linear regulator of some sort (typically generating 3.3V stand-by) and then goes to the ICs. So many boards are somewhat more protected from overshooting and quick-rising 5VSB.
    That is one beefy PSU! I might believe it good for 235W or 250W.
    I wouldn't be surprised if that's the case. For many OEM PSUs, the maximum rating on the label meant maximum _continuous_ power the PSU can supply (and even higher peak, if needed). Hence the overbuilding. Quite a contrast from the cheapo PSUs with 250-300W ratings that could only hope to peak that high for a few seconds before blowing up.
    The big usefulness limiter nowadays would be that 5VSB output current rating.
    And the 12V rail! Even a Core Solo won't be able to run with that PSU.
    But for an old 5V-heavy PC, it should be fine - especially socket 462 boards, as those usually didn't support S3 sleep (only S1, which means 5VSB was used, at the most, for WOL, WOR, and power by [PS/2] keyboard/mouse.) Actually, most Pentium II and 3 boards supported S3 sleep, but even those were stated to require no more than 500 ma to 1 Amp on the 5VSB. So I have a good number of motherboards that will work with this PSU.
    • Stefan Payne
      • 1267
      Something new for Entertainment:
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        #3003
        ^ Oh come on - would it really kill you if you posted a label shot?
        I really dislike playing this "guessing game" as to what it is. Yes, it's an ATX PSU. Yes, it's fully modular **. Yes, it has APFC and sync. rectification. And yes, it has crap cap brands on the outputs. With that said and not knowing how much it's rated for on the label, it's hard to judge it. Overall, I'd say it looks OK. But really, it's just another modern unit without anything noteworthy.
        ** Regarding the fully modular thing: I just don't get why they make the 20/24-pin connector modular too. It's not like you will use this in a server or to power your phone... or whatever else. No, it's an ATX power supply meant for an ATX mobo and thus will have its ATX connector always used. There's really no reason to add extra resistance with modular connectors, at least for the ATX cable. And it's just another cable that can get lost when people "put these away" in their closets, or wherever.
        Sorry, I just don't get the whole "looks over function" thing, which modular seems to push in some way.
        But again, other than that, it seems like an OK PSU. Maybe even better with a recap. I'd guesstimate it's rated for 450-550 Watts range? Perhaps 600W with some magic?? At least I like how they pushed all of the components towards the back of the PSU where the vent is (especially that primary heatsink), so that the fan can blow air more easily into the PSU... that is, hoping this is not one of those "eco" designs that doesn't run the fan until temperature X (read: components cooking) is reached.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4959
          • New Zealand
          #3004
          Yes, let's save half a watt of power in exchange for putting the whole thing in landfill years earlier!
          -David VanHorn
          • Stefan Payne
            • 1267
            WHere's the fun in that?
            But honestly, its a 650W PSU with 20A on minor rails.
            with the blue PCIe Connectors, its obvious who sells it (hint: Stone and Silver)
            With the Caps I strongly disagree: I see 1 Taicon and a bunch of Teapo SC. I'm fine with that.
            The JunFu/AsiaX and ChengX mix in CWT GPS units worry me more...
            https://www.silverstonetek.com/produ...id=813&area=en
            People not knowledgable about electric stuff want the shit be modular.
            I'M fine with a semi modular PSU with ATX, CPU and one PCIe cable with 2 connectors hardwired.
            You know too much.
            People still consider an almost 10 year old group regulated unit without OCP anywhere, no OTP and UVP on 12V as good, even for 50€ or more, just because "Wapanese Caps", wich are made in China anyway because Import Tax...
            Ähm, its 650W and possibly 750W as well.
            The 2 Polymer Caps are whopping 1500uF/16V ones.
            So the capacity on 12V is at least the same as the CWT GPS thing, that one:
            https://img.tweakpc.de/image/dsc-4476-andere.FEe
            Has 6x470uF/16V and 2x2200uF on 12V...
            This one has 2x1500uF + 2x2200uF/16V right next to it. However, there is a big 3300uF/16V Cap right next to the DC-DC Module...
            No, its not semi-fanless (pls bash Seasonic and Corsair for that shit) and it has a rather high fan speed.
            What I measured is around 800rpm or so. Of course only 120mm. And a sliht sirring sound. Not too annoying like the Hong Hua Fan in the CWT GPS I linked above. And that one was 750W...
            Just some nice note:
            The +12V Rectifyer are heatsinked to the Case with a big Thermalpad, wich is a nice touch.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #3006
              Yeah, well I don't spend all day reading PSU reviews or do enough builds with Silverstone PSUs to know that.
              Because you have the unit in front of you. I can't see jack-schit from those pictures.
              You know too much.
              Lol, don't be so quick to ironize me! After all, you provided nothing more than three sub-3MP pictures with more or less questionable focus and lightning. And I am supposed to figure it all out from those?
              I couldn't care less about OCP, OTP, or if it's group-regulated or not. As long as the PSU works well, lasts a long time, and doesn't kill the PC when it fails, it's fine with me.
              As for claiming that all Japanese caps are made in China... not true at all!!! All of the major Japanese brands still have factories in Japan. They just don't make as many as they used to (or rather produce only certain series), so that's why much of the manufacturing is outsourced to China, Taiwan, Indonesia, and etc. But certain series are still made in Japan.
              Good!
              It's also nice to see 120 mm fan used instead of 140 mm - allows the PSU to be more compact, which can be useful for some mATX cases.
              • Stefan Payne
                • 1267
                Oh well, its enough that you know how to repair them
                That's a Skill I don't really have so my old 420W Super Flower (Silentmaxx) unit died for no reason...
                OK, you want more pictures. Why don't you say so?
                Your wish is my command:
                That was ment to be about the not hard wired ATX Connector, nothing else.
                But to be honest: As long as its not done like the Huntkey X7/1200W (wich I can't use right now because I misplaced the Power Cable), I'm fine with whatever...
                Though hardwired is better, causes less problems...
                Yeah, I need to work on that but don't want to spend the money for that
                Here 2 Original ones:
                Yes, I was not clear enough.
                The Caps you buy from Digikey/Mouser are probably not made in china but somewhere else.
                The Caps that you find in something that is made in china is very likely made in China. At least the Caps inside of PSU.
                Good!
                Yeah, but the Fan They used I don't particularly like.
                D12SH...
                A 140mm fan would prove difficult with this unit
                You know Silverstone. They want it small.
                And this PSU is rather small -> 140mm long. And the Conectors are not outside the PSU (like the Strider Platinum)...
                I kinda like the Plattform.
                Though I have to take out my two 7970 and ram that inside, to test it for max. load to see how fas thte fan spins then.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  #3008
                  It's pretty funny that they could not find a spot to solder the X capacitor to.
                  Considering it's actually glued ontop the main PCB maybe it would have fit there lol
                  Or on the input PCB mounted on the backside, or make that a few mm larger.
                  But no, lets's just put some flying wires and hot snot, she'll be alright
                  As for your pictures: all you need is some better lighting.
                  You can build a lightbox with a white bed cover and a few pieces of wood.
                  Then just use a really high power floodlight outside it (500w halogen) it will look much better and costs almost nothing...
                  • Stefan Payne
                    • 1267
                    Yeah, maybe put some whitener onto the wallpaper...
                    One slight Problem: There is no Power in that room.
                    And I need to put a cable there somehow...
                    Well, needs some drilling and so...
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      #3010
                      I did - I wanted a picture of the label!
                      But I suppose all the other pictures you posted will do, too.
                      Indeed.
                      Yeah, that's understandable. Come to think of it, my setup isn't very good either. If anything, I simply rely on the fact that I have very good natural light in my room (which is where I take most of my pictures.) If it wasn't for that, my pictures would be terrible. So that's just lucky on my part. That said, I'm quite limited to what days I can snap pictures. If it's cloudy outside with thick dense clouds, I'll have to wait for another day.
                      D12SH...
                      Eh. I consider fans as consumable parts, regardless of what bearing type they have. After a certain number of years / hours, you just either have to replace or relube it (whichever applies.)
                      Oh, you have two 7970's?? I'm not going to be worried about you staying warm in the winter then.
                      Even one of those should be a pretty decent load test for the PSU. But two of them? Who needs a SunMoon PSU tester when you have those?!
                      As a bonus, maybe you will also be able to see your power meter "whizz" :
                      https://www.youtube.com/watch?v=ut5DXxK1dvk
                      • Stefan Payne
                        • 1267
                        You got a Link to the Manufacturer, that's better
                        its ST65F-GS.
                        Well, funny thing is that TWO 7970 are about the same or even less than a VEGA64 with +50% powertarget...
                        And the Gigabreit are freaking annoying with that shit Heatsink and the 7970GHz/280X BIOS...
                        So the 7970 doesn't consume that much power at all. Just the Heatsinks of many cards are utter horse shit.
                        • ChaosLegionnaire
                          HC Overclocker
                          • Jul 2012
                          • 3264
                          • Singapore
                          #3012
                          D12SH...
                          that part number looks like a yate loon 120mm sleeve bearing fan. consider yourself lucky that its an open sleeve bearing fan so its serviceable if it fails! most modern sleeve bearings are now all sealed so gg if it fails...
                          the only inconvenience is having to open up the power supply every year to lube the fan constantly to avert failure. but u have to open up the psu every year or so anyway to blow and clean the dust bunnies out to avoid getting the heatsinks clogged with dust and killing the psu anyway so what the hell...
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            #3013
                            its ST65F-GS.
                            Ah, I missed seeing that somehow in your post above. Sorry!
                            I don't know about that.
                            HD7970: 250 Watts TDP
                            Vega64: 295 Watts TDP
                            HD2400 XT: 19W TDP
                            Don't mean to turn this into a GPU discussion but... how do you folks tolerate such power-hungry GPUs in the summer?! I can understand in the winter, as it doubles basically as a space heater. But summer, when temps here inside go above 80F / 28C... not a chance I'd use one of those. Granted that in idle/desktop mode, they don't use much power... but then what's the point of having such a powerful GPU if you're not going to game or render with it?
                            No, it does eat quite a lot of power... but I do fully agree with you that many cards indeed have inadequate "horse shit" coolers
                            Speaking of GPUs and power usage... remember this PSU from a few pages back?
                            https://www.badcaps.net/forum/showpo...postcount=2960
                            To save you from reading its repair thread... basically I fixed it but didn't have caps for the APFC, so I removed the APFC altogether. Managed to get the PSU working and thought maybe it will just function with a slightly reduced power rating.
                            Well... all I have to say is, its power rating was more than "slightly" reduced. Trying to run an overclocked under-volted Q6600 (2.95 GHz @ 1.23V core) and a GTX560 works... as long as I don't do OCCT PSU test. If I do, the PSU simply shuts down. I guess APFC PSUs can't be used without their APFC circuit, after all. But up to 250 Watts from the wall, that PSU will do. (Yeah I know, 250W is a joke, isn't it - even a crappy Deer can do as much probably. But in its defense, this PSU still pulled good efficiency numbers: about 10-15W lower power draw from the wall compared to a 2T-forward no PFC FSP PSU. And as another comparison, the same PC with an Antec Earthwatts EA-500 80+ APFC PSU, the power draw was about 15-20W more than the Enermax PSU... so looks like APFC does lower efficiency a bit. Of course, all of that was taken with my Kill-A-Watt meter, so take those results with a grain of salt, perhaps. )
                            • Sacon_FZ
                              • Nov 2017
                              • 7
                              • Philippines
                              #3014
                              FSP Aurum 550w CM
                              Primary Side with 450V Panasonic HC Capacitor
                              Secondary Side With Nippon Chemicon KZE Capacitors. Daughterboard handles protection duties.
                              Barely visible on the chip due to lighting,FSP 6600 IC.
                              Transformers. Massive 12V Coil.
                              Transient Filtering.
                              All capacitors are:
                              -Panasonic for Primary Capacitor.
                              -Rubycon for the small capacitors.
                              -Nippon Chemicon for all secondary capacitors,barring the lone Rubycon.
                              It is Group Regulated, based on the active clamp resonant forward topology with synchronous rectification.
                              Phone camera can only do wonders on low light conditions,sorry for the bad pictures.
                              • PeteS in CA
                                • Aug 2005
                                • 3581
                                • USA, Unsure of Planet
                                #3015
                                Beautiful ... power supply porn!
                                PeteS in CA
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  #3016
                                  Originally posted by Sacon_FZ
                                  FSP Aurum 550w CM...
                                  Nice solid-looking unit.
                                  Only thing I will nick it for is the 270 uF primary cap - seems a bit on the low side for a 550 Watt unit. 330 or 390 uF would have been preferable. More if the PSU is supposed to be "upper" -tier. You can even see there is space on the PCB for a bigger cap.
                                  Other than that, not much else to complain about on this one.
                                  • Stefan Payne
                                    • 1267
                                    -no OPP I think
                                    ANd Group Regulated...
                                    but it should be rather cheap for a gold unit at the time.
                                    Today its to be avoided...
                                    • Sacon_FZ
                                      • Nov 2017
                                      • 7
                                      • Philippines
                                      #3018
                                      https://www.fsplifestyle.com/PROP162000499/
                                      Retail box and manufacturer website says it has OPP.
                                      I have no fancy schmancy load tester to test it,though
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        #3019
                                        Why would that be? Just because it's group-regulated?
                                        From what I see, most OEM builds today still use group-regulated double-forward (and in some cases, just STF) 200-350W PSUs. It's hardly an issue, even with modern hardware, where power draw variations between idle and max load can be quite large sometimes.
                                        Also, I'm pretty sure the above PSU should have OPP, as just about any single and double forward design usually does. Perhaps you meant OCP? I do see at least one current shunt in the above PSU. though.
                                        • Stefan Payne
                                          • 1267
                                          Yes and the brutal transient.
                                          Try a double forward with VEGA. Or x080ti from nVidia. That is aweful.
                                          It works but not something you'd want.
                                          The Power Saving mechanisms are just that brutal with modern Hardware...
                                          Öhm, no, not really.
                                          You can't have a group to regulate if you don't have a group, can you? ;-)
                                          Those PSU are usually single voltage.
                                          Maybe, maybe not. I know that old first Generation HEC units back in the day had a pretty brutal Voltage drop.
                                          But why risk it when you can get lower end DC-DC units for 40€ and every mid range from pretty reputable Manufacturers have DC-DC anyway...
                                          FSP Aurum ain't no Double Forward Design.
                                          Its Active Clamp Reset.
                                          Based on the Proprietary FSP6600 series for the primary and secondary (3,3V only) 6601. My be quiet Pure Power 10 with independant regulation has two of those FSP6601 on a modular Board.
                                          Here Picture:
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                            Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                                            by momaka
                                            More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                                            02-15-2022, 12:43 AM
                                            Boston Acoustics HD8 – build quality impressions & DIY woofer surround repair
                                            by momaka
                                            Boston Acoustics fans, this thread might not be for you.
                                            A few years back (~2018 time frame), I picked up a set of free JVC speakers from someone on Craigslist that no one seemed to be interested in. The guy also had a single Boston Acoustics HD8 speaker – yes, just one cabinet. He said he had no idea where he got this one from or why it's only by itself. But like the JVC speakers, it was going to get tossed at the end of that week… so I came to collect, as usual. And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the...
                                            01-30-2022, 11:57 PM
                                            DVR camera recorder switching power supply capacitor failure really
                                            by sam_sam_sam
                                            These cheap non brand capacitors at it again
                                            Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                                            Well at least I have the cameras back on line I to try the...
                                            01-22-2022, 06:28 PM
                                            DVR recorder Switching power supply Failure
                                            by sam_sam_sam
                                            When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
                                            Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
                                            This...
                                            05-27-2023, 03:03 AM
