This is a sticky topic.
Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more! -
It's too close to tolerance mantinel, I'd ditch it.Last edited by Behemot; 07-16-2013, 05:11 PM.Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
I don't usually replace input caps, mostly only the laughable small 200V ones or in displays where they tend to get bad more than I'd like.Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
HEC-550TB. Same unit as this thing. Caps on secondary are all Teapo, except for one Su'scon on the 5VSB and other assorted minor caps. Primary is CapXon.
I've seen that one before - i have the feeling you're gonna find "350W" silkscreened somewhere.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Is not yet decided but should get bronze price http://diit.cz/node/92121/su/b607cf0...9eaded3f021841Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Unknown OEM, the previous user ripped the label offbut everything points towards a 350W PSU, as in 6A bridge rectifier, TO-247 13009 switchers, 35 transformer, 30A schottky on 3.3V and 5V, dual 20A schottky's in parallel for 12V
Take a look at those LCZ capacitors....Their capacitance is way off, and check out the sleeving on the bottom, horrible!
Worst of all, check out those resistors by the supervisory chip, they're broken?!?! Is this just your typical "chinese quality" ?
The rest of the caps consist of Asia'x, Canicon, and Kingcon (the ones with Ruby style vents)Comment
Not ExplodeGen but the other one I still forget? Sun Pro? I'd say it was labeled at least 450 WLast edited by Behemot; 08-05-2013, 05:58 PM.Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
One as the other, I think they almost all use this two decades old designLess jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
P4, re those "broken" resistors, I think they are not broken, but intentionally snipped to trim some aspect(s) of circuit performance. The two resistors are 270K and 470K, and if in parallel with resistors of 1K-10K, those resistors could be used to have a small fine tuning effect. It's cheaper and quicker than a potentiometer, and slightly more reliable as well (compared to a potentiometer).PeteS in CA
****************************Comment
I believe the manufacturer is Dongguan Jiqixin Electronics aka Kineagle Electronics.Comment
AcBel API2PC23 200W power supply from a 2003 IBM S50 SFF desktop. The mainboard was full of dust and trashed, with twelve bad capacitors (the failed caps mostly being KZGs, three 85°C Rubycon YKs and a handful of small Rubycon CEs).
Photos were taken before removing the dust bunnies, in the early hours of the morning under a crappy CFL. The PSU is a two PCB design, separating the primary and secondary sides. Surprisingly, not one capacitor has bulged despite the amount of dust in there, although, the caps are entirely from Nippon Chemi-Con rather than the usual suspect brands found in most OEM PSUs.
On the primary board, we have a bridge rectifier, two 330uF 250V SMQ series and a massive PFC coil.
On the secondary board, there are some decent sized FETs and two copper heat sinks. The ATX power connector lacks the white -5V wire despite being from 2003, so it's a modern design (yet some cheap and nasty PSUs still come with them), and also has a single plug for a SATA hard drive - there is no floppy drive power connector (the floppy was a laptop style drive with a flat ribbon cable, although the board did have a regular 34-pin floppy cable as well). The 12V side has a single 2200uF 16V KY, 5V has two 1000uF 10V KYs, with the small caps being KME series (the larger KME with the vent is 100uF 50V). I can't see the other values around the 3.3/5/12V rails as it is too densely populated in there, but I assume these are also 1000uF 10V caps. I couldn't see the FET/Schottkey markings for the same reason.
The fan is a Protechnic MGA8012MS secured with rubber mounts instead of the usual screws, and has clips on the board so it can be replaced without having to get out the soldering iron. The fan was still OK however, despite the amount of dust, and the PSU still works as well.Last edited by Heihachi_73; 08-17-2013, 01:34 PM.Comment
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by CMCMHello Everybody,
Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
The outputs marked 12v and 20v are all measuring only 1v.
The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
The capacitors physically look clean (no bludgesor leaks) and... - Loading...
