This is a sticky topic.
  • SIDMX
    • Nov 2010
    • 165
    • Mexico
    #1261
    Actually i don't know, it tested ok in a system based on celeron 420 1gb ram onboard video and only 1 hdd but when installed in another system: ECS AM2+ motheboard, Athlon 64 X2 7550, 7600GT VGA, 4GB RAM, 2 SATA HDD and a DVD-RW it shutdows immediately, I pulled the PSU out of the case and shorted it's 12V rail to test if the shutdown came from motherboard or PSU protection and was surprised to see that it really came from PSU.
    What kind of mods you think can be done??
    • Behemot
      • 4845
      • CZ
      #1262
      Short protection should have everything manufactured in last like 15 years, it is the most basic and I think also compulsory protection. It does not prove there is any over power protection though.
      • SIDMX
        • Nov 2010
        • 165
        • Mexico
        #1263
        Originally posted by Behemot
        .... It does not prove there is any over power protection though.
        You're right, will test in the proper way when i get the time.
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Got yet another Allied here....and it doesn't look too shabby. Better than I'm used to from them. Full input filter (Minus an MOV) 4A rectifier, and what's probably realistically 330uF input caps. Unfortunately it has 13007 switchers but I have some 13009's I can replace them with. it also has a CEF02N6A MOSFET. the heatsink should be of adequate size. The transformer says ERL-35 but it looks more like a 33 to me...could be wrong though.
          The actual rectifier ratings are 3.3V = 20A, 5V = 30A, 12V = 20A, and a thermally controlled DC brushless fan.
          I was planning on replacing the input caps, the switchers, recapping it, and looks like a resistor needs to be replaced. It looks a little cracked but not broken....the thing does power up a computer with all voltages in spec (Barely) the 5V is around 5.22V. But a bulged 10V cap could be causing some issues. Also, when replacing the switching transistors would I be able to reuse the thermal pads?
            master hoarder
            • May 2008
            • 12168
            #1265
            With some modifications it may do 350 W quite fine, 400 W max.
            Yeah right. With no space for PI coils, good luck keeping the ripple in spec on the outputs. Even with good caps, I'd guesstimate around 200W is where the ripple will start going really bad.
            It's a real 35.
            May also want to replace the ceramic cap next to it with the same value poly__ (styrene/propylene/ester... etc.). I've seen those ceramic caps burn up in Allied/Deer/L&C PSUs. Not sure why.
            Yes.
            • Behemot
              • 4845
              • CZ
              #1266
              • SIDMX
                • Nov 2010
                • 165
                • Mexico
                #1267
                I've seen daughter boards in BC before so i don't see any limitation there, lacking a scope to test/confirm results is what really stops me to proceed right now.
                  master hoarder
                  • May 2008
                  • 12168
                  #1268
                  Well that's a DC to DC converter or perhaps synchronous rectifier PSU - obviously it won't have the same type of filtering as the cheapo half-bridge PSUs.
                  Yeah, if you go that route and add the caps and PI coils on the daughter board(s), then the ripple will likely be much less.
                  • Behemot
                    • 4845
                    • CZ
                    #1269
                    That's not it, try again.
                      master hoarder
                      • May 2008
                      • 12168
                      #1270
                      Ok, but my point is, this PSU looks like it's designed to use a totally different filter. I'm not saying you can't have a PSU with no PI coils and very low ripple/noise output. It just has to be designed for it - something that's usually not the case with cheap PSUs that are stripped from the PI coils because the manufacturer was too cheap and not because they designed them to work without any.
                      • Behemot
                        • 4845
                        • CZ
                        #1271
                        I told you that's not it, try away! Forget DC-DC stuff, you are looking for something else there.
                        • SuperDuty
                          • Mar 2011
                          • 299
                          • France
                          #1272
                          Heden PSX-A830.
                          Just a little intro, Heden is a french brand famous here for the general poor quality of its products. They're more an importer/reboxer than anything actually. The worst power supply I had came from a Heden case I had bought in early 2005, but this thing held up pretty good for almost five years in my old rig (XP2200+, K7S8X, 9600Pro, 40Gb+200Gb). It was very silent too...but also very empty.
                          Here's a scary test from a few years ago about Advance and Heden PSUs (sister brands) : http://www.x86-secret.com/dossier-36...on_Noname.html
                          So here the thing, I'm not sure what to think about this one. Apart from the lack of PFC and the crap caps, it looks quite a lot better than any other Heden PSU I've had in my hands. Wires are 20AWG..
                          It seems like there is room for improvement.
                          • SuperDuty
                            • Mar 2011
                            • 299
                            • France
                            #1273
                            EZ-Cool ATX-500 JSP "500W"
                            This is from a computer in found in the trash in the UK last november, it's much younger than the rig it was powering (XP2600+, FX5200, 80Gb).
                            Never head about this brand, must be a UK thing. The case is very flimsy. It's not too good looking inside, I wonder where the 300 watts are...oh wait it's 500 !! Caps are all Sapcon and Canicon.
                            The Amp ratings are ridiculous, they have to be fake.
                            • cheese007
                              • May 2009
                              • 85
                              #1274
                              No bridge rectifier but they sprung for pi coils?!
                              • c_hegge
                                • Sep 2009
                                • 5219
                                I have seen an identical one here, so EZCool aren't just a British brand.
                                • Behemot
                                  • 4845
                                  • CZ
                                  #1276
                                  But seems like ExplodeGen is the OEM anyway. Seems like both can be transformed into half-decent 350-400W?
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    It's a Sun Pro. If you gave it beefy enough parts (replace the transformer, switchers, rectifiers and caps) you could probably make it do 350W or so. As it stands, though, I doubt it would do much more than 250W, maybe 300W if you ran it inside a fridge.
                                    • Behemot
                                      • 4845
                                      • CZ
                                      #1278
                                      Ah, yeah, the other one is ExpodeGen. I still confuse one with the other. But I still think it may do close to 400 W, it has ERL-35 transformer…
                                      Anyway, do you think momaka gave up and I should tell him the secret?
                                      • SuperDuty
                                        • Mar 2011
                                        • 299
                                        • France
                                        #1279
                                        So the Heden is at least semi decent and could be a good base for improvement ?
                                        On the bottom of the PCB, there is this reference : PCA X-2006C V:A-15
                                        The fuse is a T5A, which, according to the PCB markings, should be good for 180-240W units...hum.
                                        • Behemot
                                          • 4845
                                          • CZ
                                          #1280
                                          Well, you can work with that, but you have to consider whether the resulting power of say 350 W safely is worth the effort. You can get loads of 400W Fortrons with bloated caps where you only recap them and have nice PSUs.
