This is a sticky topic.
  • etnietering
    • Apr 2009
    • 379
    Well I was able to get the main transformer out, and under it it says:
    KY-2102 REV: 1.7-1 20Z
    and has a goofy looking symbol that looks kind of like a sideways S in a circle with 2 slashes through it
    • POM_MJ
      • Aug 2009
      • 228
      #82
      Here is another one of mine, NMB 460W model GM460WTXW01SSV need re-wired to ATX.
      Caps on secondary side are nichicon LXZ
      | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
      | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
      | 2xWD7500AYYS | 2xHD322GJ Raid0 |
      • etnietering
        • Apr 2009
        • 379
        Well, I'm going to stray from my norm of only posting junk...I just today got 2 of these: Compaq Model DPS-450-CB-1 A, although according to this thread the real maker is delta. And I believe it! This thing is built like a tank! And it was only 10 bucks on ebay Caps are all NCC with a few Rubycon thrown in, and three lonely TAICONs...Why TAICONs in such an overbuilt high quality piece of equipment? you might ask...well, I asked too, and I haven't gotten an answer yet.
        Anyway, on to the pictures!
        Here is the label - for once it's not a big fat lie!
        Here's the view in from the grill. I've never seen one this stuffed!
        After quite a bit of fiddling, I was able to get it apart. Here's an overall shot of the inside. Under the black sheet is a gigantic heatsink....I believe it's for the APFC circuitry. The primary filter cap is a huge NCC 470uF @ 450V monster.
        Here's the input filter. It's fused on both the hot and neutral lines. It has one huge joint coil, and two seperate coils, two HUGE Okaya X caps (1.0 and 2.2uF), and 2 Y caps. I believe there's more filtering by the power outlet, because it sticks out pretty far into the unit. The green thing in the heatshrink is either the Current Inrush Limiter, or a MOV. It's labelled Z1 (Z2 is missing), and I haven't taken the board out to see what it actually connects to. The big white blocks in the back are power resistors, and I have no idea what the ones on the TO-220 diodes are.
        Here's the secondary side filtering....I have more detailed pictures of each rail, but the 5v and 3.3v have NCC LXJ and the 12v has Rubycon YXF.
        Here's the 12v rectification. It's difficult to read the markings on the diodes, but I believe there are 2x20A and 3x40A, for a total of 160A filtering capacitor, and the rail is rated for 25A! Caps are 4x Rubycon YXF 2200uF @ 16v.
        And here we have the 5v rectifiers. I know these three are for the 5v, and there are others that may or may not be, I can't tell without taking the board out. They are rated for 30A each, so that's a total of 120A on the 5v line (but maybe more), and the rail is rated at 34A. Overkill much? Jeez! Caps are 4x NCC LXJ 3300uF @ 10v.
        This is the 3.3v rectification stage. If I'm correct, there are SEVEN 40A schottkys on this rail, for a total of 280A! For a 40! rail! The little guy in there is the 7912 reg for the -12v. Caps are 4x NCC 4700uF @ 6.3v. And I thought the other rails were obnoxiously overbuilt
        Don't have a picture, but the primary switchers (at least the one I can see) are IRFP460LC's, MOSFETs rated at 500v 20A continuous/80A pulsed. The main transformer is I believe size 42. Some of the jumpers in this thing aren't wire, they're more like a metal plate. I must say, I'm quite impressed with my first Delta PSU
        • 370forlife
          Large Marge
          • Aug 2008
          • 3113
          Follow the traces from the rectifiers to see what caps and what wires they end up to. That will give you an idea of what they are for.
          • 370forlife
            Large Marge
            • Aug 2008
            • 3113
            That is one sexy power supply.
            • etnietering
              • Apr 2009
              • 379
              Well I was able to get out the primary side board. The green thing is a MOV. The current inrush limiter is buried way way back in there (I was able to get that heatsink off too). I also found the temp sensor - it's on the PFC heatsink. I cleaned off both heatsink faces real nice and I'm going to artic silver them back together
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                remind me to post my compaq branded delta sometime. it is also built like a tank... stuffed with parts.
                dps= delta, hp=hipro
                sigpic
                (Insert witty quote here)
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3113
                  Don't forget NPS - newton, or basically delta but always with rubycon and UCC caps.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    ive never seen a newton one before. they ARE nice. most oem units i see are delta, hipro, or bestec
                    sigpic
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3113
                      They're simply delta's, as newton is owned by delta, but they always use premium caps.
                      • POM_MJ
                        • Aug 2009
                        • 228
                        #91
                        Sorry, wrong Caps name. they're chemicon LXZ
                          master hoarder
                          • May 2008
                          • 12175
                          #92
                          Not always. The one in my Dell Dimension has Ltec on the secondary. Primaries are Nichicon, though. 5vsb might have been Rubycon, but I don't remember too well.
                          By the way, that NMB and Delta above are awesome. Secondary sides on both have so much silicon that I wouldn't be surprised if they are able to jump start a car or qualify for a welder .
                          • 370forlife
                            Large Marge
                            • Aug 2008
                            • 3113
                            Kind of ironic, I was looking on leadman's website, and they actually build car battery chargers
                            That NMB is strange, no transformer. I'm not sure, but I think it has 4 small transformers, 1 for each rail (with one being both -12v and -5v or something like that,)
                            • POM_MJ
                              • Aug 2009
                              • 228
                              #94
                              The big one transformer is lower left corner of this picture, primary side connect to 5 pins connecter. its very strange transformer.
                              • POM_MJ
                                • Aug 2009
                                • 228
                                #95
                                ENlight VP-300
                                I think it's same design with DTK PTP-3007 from this post
                                https://www.badcaps.net/forum/showpo...&postcount=178
                                only one thing diiferent is it has 2 fans.
                                Caps on secondary side are very leak cause damage to 5Vsb circuit C5027, FOD817C opto, C945.
                                I replace them with SAMXON GF-series and SANYO WX-series.
                                • 370forlife
                                  Large Marge
                                  • Aug 2008
                                  • 3113
                                  goofy design, but has independently regulated 12v rails.
                                  • Gianni
                                    • Jul 2008
                                    • 681
                                    • Italy
                                    #97
                                    JJ-460PPSA: a friend gave me this PSU because he had problem on the PC and he suspects the PSU is the culprit.
                                    It has 2 fan, a separate over current limitation board dedicated to 12V and 5V.
                                    It looks good, has long cables and passive PFC.
                                    The caps are CapXon, they are not bulging or leaking.
                                    Ciao
                                    Gianni
                                    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
                                    H. J. Brown
                                    • 370forlife
                                      Large Marge
                                      • Aug 2008
                                      • 3113
                                      Topower
                                      • POM_MJ
                                        • Aug 2009
                                        • 228
                                        #99
                                        Super Flower SF-400P12 400W
                                        Here are caps on primary side, Fuhjyyu.
                                        Soldering look not so good.
                                        used SBL2040CT for 3.3V, SBL3040PT for 5.0V and F16C20C for 12.0V.
                                        Caps on secondary side has printed PCE-TUR and VENT on them.
                                        • 370forlife
                                          Large Marge
                                          • Aug 2008
                                          • 3113
                                          Wow, same capacity that my yuelin ylp-013 had on the secondary side. 12v is rated at 20A, with a 16A diode.
                                          Superflower is better than that now though.
