I have two of these badged as Compaq spares for;
Compaq Proliant ML530 ML570 G1 Server 450W Redundant Power Supply
The datasheet can be found at;
Being hotswap, can anyone help as to how to test one of these?
They have spade connectors and I believe an I2C control block.
Apparently (according to the datasheet), these require a min. load
of 0.5A on the +3.3V, +12V and +5v rails.
If I can figure out how the spades correspond to the rails, would
it be safe(ish) to power the unit on and test the no load O/P
readings with a m/meter?
I really just require to establish if these are working.
Of course, if I had thought about it, I should have grabbed
the connector and loom from the server they were removed
from to rustle up a quick test rig.
Any suggestions?
Any suggestions?
