This is a sticky topic.
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    #1021
    Originally posted by Behemot
    I will dig out this post of mine (No. 700 in this thread if you wanna the pictures).
    Been playing arround with my new loader and clamp meter for a while. I have succesfully done more or less complete rebuilt of this thing some time ago. It should now be capable of it's rated power. One thing I have noticed is that it seems to HAVE some kind of protection despite how crappy it looks. The thing is, it sits on the least important rails - +3,3 and +5 V I have been able to squeeze only arround 130 W combined from these rails, than it shuts down.
    On the other hand, it really is able to provide 15 A for 12V power-hungry systems (well, plus some minor load on +5 V from fan). Voltmeter does not show any crossloading when loading 15A on that rail ONLY.
    Will try to do some starting review on this thing, stay tuned for more
    I can't wait
    • Behemot
      • 4845
      • CZ
      #1022
      Just one question since I am still not really sure in this area. I have tracked this to be a half bridge, is that correct? Not center-tapped transformer, symmetric transformer output to rectifiers. Two transistors, ones base connected to others collector.
      There is film capacitor between Vin and one transformer pin and small ceramic cap with resistor between the same pin and 0V. This is not very clear to me but somehow it corresponds to the schematic of half bridge. Putting this all together I think that's half bridge
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        #1023
        Behemot, it sounds like a half-bridge. In a half-bridge one side of the O/P transformer primary is connected to the center of the two input electrolytics and the other side of the primary is connected through a film capacitor to the center of the two transistors. The film capacitor - typically 1uF or 2.2uF - keeps the transformer core from walking into saturation due to slight imbalances in the on times of the two transistors. Is the PWM controller a TL494-KA7500 type and on the secondary side?
        PeteS in CA
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Originally posted by Pentium4
          I recapped this entire PSU except for the primary cap. Replaced the 2200uf 16V Teapo on the 5VSB to a 3300uf 16V UCC KY cap. I replaced all the 1000uf 16V CapXon's with 1500uf 16V UCC KY's (and there were 7 of them) so I'm hoping the ripple will be in check with this thing
          I'm having issues with my main computer and wondering if this thing would be adequate for my current build in my sig for a few weeks tops? I'm mainly worried about the ripple being too high
          • Behemot
            • 4845
            • CZ
            #1025
            Yeah, exactly, KA7500. Than LM339N for secondary compensation.
            • PeteS in CA
              • Aug 2005
              • 3581
              #1026
              An LM339 is a quad general purpose comparator. It's probably used for Power Good and some combination of protective functions.
              PeteS in CA
              • Behemot
                • 4845
                • CZ
                #1027
                Yeah yeah, tracked one pin to PG, they also talk about being directly suitable for 12 V in datasheet so I think it may somehow drive +12 V. Than typical things like short I guess.
                • PeteS in CA
                  • Aug 2005
                  • 3581
                  #1028
                  The outputs of an LM339 are open collector - the collectors of transistors which have no internal connection. This lets the user use whatever positive collector voltage they want, within the maximum voltage and the practical minimum voltage, by connecting a suitable pull-up resistor between the voltage and the output pin. Thus, an LM339 can adapt between TTL and higher analog voltages, in either direction. It's one of those 1970s vintage parts that is still a workhorse in modern usage.
                  PeteS in CA
                  • Behemot
                    • 4845
                    • CZ
                    #1029
                    Oh, I was battling with the osciloscope more than taking measurement yesterday, but I noticed the voltage regulation is not good, really, I blame the way how they are trying to acomplish that, I think they could take much better way than 4way comparator.
                    With no load, there are strange negative spikes on every rail. For example on +12 V, peak-to-peak ripple is arround 60-80 mV no load and jumps to over 200 mV with load. If I add even minor load on +3,3 and +5 V, it drops to 80-100 mV at 120 W load on +12 V. Obviously they didn't use minimum load resistors yet the supply needs it to be within specs.
                    • Behemot
                      • 4845
                      • CZ
                      #1030
                      Oh my. Preliminary results do not show any good. The -12 V rail oscilates like hell no matter what I do with the rest. I guess it may have something in common with the coil I have put in instead of wire? Maximum ripple was 310 mV
                      About the rest, well. The +3,3 V rail got boost from replacing superfast with shottky and is now over maximum tollerance in ATX - it went as high as 3,6 V. Rest is good voltage wise, but the ripple on +12 V is too high, from some 9 A out of norm. It has no Pi coil (just shares core of common output inductor) and there is space for only one cap (I have put in a 3300 uF/16 V Samxon RS).
                      Here are some pics, do you think there is possibility of adding something to the +12 V rail to calm it down? As for the -12 V, I will remove the coil (the blue one) and see what happenes. Oscilloscope measurement is typical for what too strong coil does.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        #1031
                        The comparator has nothing to do with voltage regulation. It is part of the protection (OVP/UVP) circuitry and the power good signal generator.
                        A working TV? How boring!
                        • Behemot
                          • 4845
                          • CZ
                          #1032
                          So you say the KA7500B is responsible for primary driving and secondary voltage controll?
                          Anyway, interesting fact is, the LM339N is most likely responsible even for OPP. I have not been able to suck labeled current from it, it has shut down at some point every time, no matter what combination of load I have chosen. I do not know whether it is ood or bad. It does not burn itself, yes, but…is it good they made it the way you CANNOT suck labeled power from it even if you tried?
                            Behemot, you got a Rigol now? How did you get that nice graph out -- I can only get screenshot-like images??
                            • Behemot
                              • 4845
                              • CZ
                              #1034
                              This one is still not mine - it's here under one project (for all those ppl who need to do their electronics stuff). Older model, 1062E so it has been some fight, but we managed to get the Ultrascope SW running again. I just took screenshots from it with Print Screen
                              It just was not running great unfortunatelly, I had to unconnect the scope, set it on the scope manually, connect it and take screenshot. And than again. When the program is running as it is supposed to be, you can controll the scope settings in the program.
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                #1035
                                KA7500B = TL494, classic PWM chip. Developed in the 80s, still being used because it's just good at what it does. A little googling will find you some schematics of ATX PSUs based on the TL494/LM339 combo. Other versions will use a LM393 and some more discrete components, or a different supervisor altogether. But the TL494 remains a basic building block for a lot of power supplies out there.
                                OPP is likely connected to pin 4 of KA7500B. It's coming from the driver transformer, via a 1N4148 diode, a small capacitor and a resistor divider.
                                It shows that labeled power is simply false, which is common practice in cheap, "no-name" PSUs.
                                • Behemot
                                  • 4845
                                  • CZ
                                  #1036
                                  But the thing is, most el cheapo PSU's don't have any protections. They just burn.
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #1037
                                    I will continue in separate thread to not polute this one anymore
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      #1038
                                      They do. The OPP is just configured too high to act as more than a short circuit protection. Because in the process of removing parts/substituting with cheaper ones, they usually forget to reconfigure the protection circuitry.
                                        Another possible explanation is to get xxxW peak power, so it works initially in the users computer, passes 28 day return time then goes bang as they try to use it for longer at excessive power.
                                        • Behemot
                                          • 4845
                                          • CZ
                                          #1040
                                          You can do RMA than anyway. Here is 14 days return and 2 years minimum warranty so it won't help.
                                          But since in my case it shuts down instantly, I cannot even believe the talk about "maximum" power for short periods of time which our local business inspection told me. I tried to get this thing out of market, but talking to official organs is like talking to doorkeeper on main train station. Why do we pay them than? Another reason for me to want minimalistic state desperately.
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                            Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                                            by momaka
                                            More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                                            02-15-2022, 12:43 AM
                                            Boston Acoustics HD8 – build quality impressions & DIY woofer surround repair
                                            by momaka
                                            Boston Acoustics fans, this thread might not be for you.
                                            A few years back (~2018 time frame), I picked up a set of free JVC speakers from someone on Craigslist that no one seemed to be interested in. The guy also had a single Boston Acoustics HD8 speaker – yes, just one cabinet. He said he had no idea where he got this one from or why it's only by itself. But like the JVC speakers, it was going to get tossed at the end of that week… so I came to collect, as usual. And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the...
                                            01-30-2022, 11:57 PM
                                            DVR camera recorder switching power supply capacitor failure really
                                            These cheap non brand capacitors at it again
                                            Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                                            Well at least I have the cameras back on line I to try the...
                                            01-22-2022, 06:28 PM
                                            DVR recorder Switching power supply Failure
                                            When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
                                            Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
                                            This...
                                            05-27-2023, 03:03 AM
