This is a sticky topic.
Powerlink LPJ2 "400W".
4-diode treatment with lame 4A diodes. Non safety approved Y caps. No other input filtering to speak of.
Primary: D13007s as main switcher, C5027S on standby. EI-33 label on the transformer... i ain't buyin' that. It's an ER-28 actually. 2x 470u Canicon caps, but judging by the can size real capacity is lower.
Secondary: 20A schottky on +5v, 10A schottky on 3.3v, and 12A fast recovery on 12v. 12v diode is stuck directly to the heatsink without a silpad. Small output inductors (coupled inductor is on a T90 core). No pi filters. 2x 1000u 10v Fuhjyyu TM on +5v. 1x 1000u Fuhjyyu TM on +5vsb and 3.3v, both bloated. 1x 2200u 16v Canicon on +12v, and 1x 470u 16v Canicon on -12v. Weltrend controller.
Can you believe this thing was trusted to power a C2D E6400 and 7600GS?Comment
I know 4A bridges, but not discrete 4A diodes.
Sorry, i meant 2A.
Does it look more like this to you:
Or like this?
Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
ACE AM608B1-300WS
This seems to be the 300W model of the AM607B1 that is 250W.
But instead of implementing better rated parts, it has significantly worse! Smaller heatsinks, tiny bridge rectifier, 330uF primary caps in place of 470uF and every capacitor is Fuhjyyu whereas the 250W model had some Teapos.
Some Fuhjyyu caps are bulging, but the output voltages appeared normal.
Do you think it is worth recapping?Comment
Well, the heatsinks are not SO bad, there are even output inductors and something what could be considered inptu filtraction. So it is not lsot case. Have a look at the rectifiers rating, if uderrated, change them, if fast recovery, chaneg them for shottky. It may actually give the 300 WLess jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
Well, the heatsinks are not SO bad, there are even output inductors and something what could be considered inptu filtraction. So it is not lsot case. Have a look at the rectifiers rating, if uderrated, change them, if fast recovery, chaneg them for shottky. It may actually give the 300 WComment
This looks actually good for 250W. Honest labelingComment
As for the transformer, it does not seem SO small for 290 WLess jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
PCline PCLAC90W
150uF 350V TREC on primary side and 2x 1000uF 25V on 15-24V output.
Two other electrolytics are Chang units.
GBU405 bridge rectifier.
IRF2807 MOSFET used as synchronous rectifier at 15-24V output - when I get a chance, I will make a circuit and post elsewhere on this forum, since this seems interesting.
FQPF8N60 primary side MOSFET.
NCP1377B SMPS controller.
350V electrolytic, underside and transformer top has thick heatsink washer-like mechanical dampening.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
PCLine is sold at PC World I think, and for ridiculous markups. It is pushed by the staff there lots.
If you want dangerous and unreliable stuff - you can get the same thing from eBay for about £10!Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Teapo are crap caps... who'd fake them? Looks like Hermei/Jamicon vent.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... - Loading...
