Real wattage of LC-8500BTX
  • Jooo
    • Oct 2011
    • 222
    • Finland
    Hi
    I'm wondering if I should fix this low-end psu or not.
    Anyone know the real wattage of this? The full name is ACE LC-8500BTX (500W).
    If the real wattage is something like <300W, not worth fixing in my opinion, but if this can do even 400W I will probably fix + recap it.
    I could not find any reviews of this model.
  • mariushm
    • May 2011
    • 3799
    Re: Real wattage of LC-8500BTX
    It will probably do 350-400w at a lousy efficiency (~ 65-70%), but little of that on 12v - probably tops at about 100 watts on 12v, which is used now the most (cpu and pci express video cards)
    • rogfanther
      • Jul 2006
      • 458
      • Brazil
      Please, post pictures of the inside of it
      • Jooo
        • Oct 2011
        • 222
        • Finland
        Ok I'll post tomorrow.
        Well I replaced the one bulging capacitor it had. With... a Fuhjyuu salvaged from dead Antec Smartpower
        I also noticed that the sticker is lying: it says two 12v (15+16a) lines, infact this has only one.
        • rogfanther
          • Jul 2006
          • 458
          • Brazil
          Is this it ?
          http://www.hwupgrade.it/forum/showthread.php?t=2341526
          • Jooo
            • Oct 2011
            • 222
            • Finland
            Looks kinda like the second one, but my psu has atleast more capacitors on secondary. 120mm fan and same green capacitors though.
            My psu has no voltage select switch, and I dont remember that PCB over power connector.
            • Jooo
              • Oct 2011
              • 222
              • Finland
              Ok here comes the photos.
              • rogfanther
                • Jul 2006
                • 458
                • Brazil
                This psu has already appeared here, under another name. Reasonably good for 350W, from what I remember. Should not be able of much more.
                That burn marks near the transformer worry me. Seems it has been used with a machine that demands more than power it can handle. I have one like yours in the junk pile, waiting for some time to fix the 5VSB as a learning experience, but I would only use it with some lower wattage computer.
                • mariushm
                  • May 2011
                  • 3799
                  Yeah... no way is that psu with 2 x 12v rails ... and 16a on that is a bit exagerated.
                  Like I said, expect about 10-12A on 12v, which should be enough for a current processor and a video card with a single pci express connector.
                  That dark pcb is worrying though.
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    ~250W max
                    It's missing an input filter coil.
                    Output capacitors are 2x1000uF, too low for 500W unit :P
                    Main transformer is not real ERL35.
                    I can't decide if it is worth a recap.
                    • Jooo
                      • Oct 2011
                      • 222
                      • Finland
                      That's what I thought.
                      Well I will not fully recap it. I think that Fuhjuyy will do just fine.
                      As you can see in the pictures, there are some empty holes for cables. I added a pci-e power connector salvaged from another dead psu.
                      I'm probably going to use this as a psu for testing dead computers.
                      I found this video:
                      http://www.youtube.com/watch?v=bbWzAjL0rWc
                      It looks like exactly same PSU. Except that this one is oversized a little more. 5000W psu with no PCI-e connectors
                      • mcdaydavies
                        • Jun 2011
                        • 77
                        You recapped it with a fuhjyyu?? wow, from bad to worse...
                        • Jooo
                          • Oct 2011
                          • 222
                          • Finland
                          Did you read the whole topic?
                          It doesn't make sense to use capacitors which are worth more than the psu.
                          And it can't be worse than those green capacitors with no brand at all.
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            Originally posted by goodpsusearch
                            ~250W max
                            That was what I was thinking! Looks like 500-divided-by-2!
                            A half-assed 500! (Did the PSU just moon me?)
                            ASRock B550 PG Velocita
                            Ryzen 9 "Vermeer" 5900X
                            Arc A770 16 GB
                            eVGA Supernova G3 750W
                            Alienware AW3423DWF OLED
                            • Rulycat
                              • Apr 2010
                              • 724
                              • United Kingdom
                              They look like YC to me. Solytech seem to like them.
                              • rogfanther
                                • Jul 2006
                                • 458
                                • Brazil
                                I´ve seen about 5 of theses around here. One burned the 5vsb, one was weak for the computer. The others had green bulged caps only because the fan stopped and that regulation toroid cooked itself and the caps ( probably they were used in more power hungry machines, also ) .
                                Maybe better than putting crap Fujyus in it would be changing the fan and maybe some rectifier. That part of the board did get that burnt color for a reason.
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  ~250W max
                                  That's probably about right.
                                  Given the small heat sinks, I would say no more than 200W peak (and that's only if you actually spread the load across the 5V and 12V rails evenly). 150W if you want it not to overheat and work somewhat longer. Anything above that will likely have too much ripple and noise to be usable in a PC.
                                  I too can't decide if it's worth the recap either. You will probably need to do a lot of other improvements as well to make it better. Overall I'm leaning towards not to recap it and just use it as a test PSU for non PC use (i.e. test fans, small bulbs, and other electronics that won't load it too much).
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    Agreed. The fuhjyyu is too good for this PSU. He should have used a GSC or Sacon
                                    They are Yang Chun. Not great, but miles better than fuhjyyu, and way too good for this PSU
                                    • goodpsusearch
                                      • Oct 2009
                                      • 2850
                                      • Greece
                                      ~250W max
                                      I add to those:
                                      2x470uF primary caps = 300W max
                                      • 370forlife
                                        Large Marge
                                        • Aug 2008
                                        • 3112
                                        Definitely a Solytech unit, they seem to slap the XX-8500BTX model number on any unit and sell it as a 500W. I had this exact Solytech unit but it was branded as a Rosewill 350W. With complete output filters, input filters, larger primary caps (680uf or even 820uf if you are feeling frisky,) and some beefier secondary schottky's I would trust it for 300W. Not for long with that transformer, though.
                                        • cnti
                                          Samsung 245B PLUS - BN44-00195A - bang and smoke - solved - tips
                                          by cnti
                                          Hi.
                                          BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
                                          This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
                                          BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
                                          RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
                                          burned, measured 10M ohm.
                                          QM801 [real PSU:...
                                          10-19-2023, 05:33 PM
                                        • edugimeno
                                          Diagnose real-vintage Strong-Hammer arcade machine
                                          by edugimeno
                                          Hi there!
                                          My friend wants me to help him repair his old-real-vintage strong-hammer machine. Well it's only 90% real as the force applied doesn't lift the weight itself but it is measured and it moves a motor that lifts the weight
                                          I am attaching several pictures of the machine.
                                          It basically has 2 sides, left side has
                                          • 2 x 220->12+24v transformers
                                          • 2 relays (1 moves motor UP, other moves motor DOWN)
                                          • IGF and breakers for safety
                                          Right side is shown on pictures. It has 3 boards ( top-down)
                                          • Logic board. Receives 24AC and recitifies it into DC. Contains a uC (M80C85)
                                          02-29-2024, 11:05 AM
                                        • DynaxSC
                                          MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                                          by DynaxSC
                                          Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                                          I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                                          11-17-2023, 10:56 AM
                                        • danny34
                                          Thinkpad E15 Gen2 Intel "lower wattage AC Adapter"
                                          by danny34
                                          Hello folks,
                                          My Thinkpad E15 Gen2 with i7 had stopped loading and wouldn't start either. I noticed the typical error with the Mosfet QB6. This has become unsoldered.
                                          I soldered it back on and found that the gate voltage was too low and that's why it was getting hot. Then I wanted to replace the UB7. Unfortunately the one I ordered from China didn't want to run.
                                          So I soldered the old one back in and it still has its 18.9V at the output of QB6.
                                          I stuck a thermal pad on the QB6 to cool it down a bit.
                                          Now the E15 is running again, but unfortunately...
                                          10-30-2024, 02:10 AM
                                        • Stefan Steff
                                          HP laptop smart PSU wattage
                                          by Stefan Steff
                                          Is there any software/program what recognize the PSU wattage attached to a HP laptop?... like DELL has in BIOS/Battery status...?
                                          Thanks!
                                          S.S.
                                          08-05-2024, 06:29 AM
