	This is a sticky topic.
 Here's something a bit different than the normal computer PSU, a Motorola\Vesta\who knows who else "Power Module". Designed for a 911 phone system of sorts, it supplies +5V, -48V and -96V at who knows what current.
 Wasn't a cheap thing new, the 2005 Motorola catalog advertises it at $2730.
 Anyway, onward. It's based on some sort of all in one power modules. Who made them or what they are, I have no idea. I'd have to desolder them to find out and that's too much effort.
 Full res images here: https://imgur.com/a/9IpjMComment
 Pretty sure those DC-DC modules are not Vicor, unless they are a series that wasn't around in the mid 90s.PeteS in CA
 ****************************Comment
 Main rig:
 Gigabyte B75M-D3H
 Core i5-3470 3.60GHz
 16GB DDR3-1600
 Samsung SH-224AB DVD-RW
 Delux MG760 case
 Yep, not exactly an original design either, the PC Power & Cooling Turbo-Cool 1200W (and the 1KW model that preceded it) used two 600W PSUs, though in the PCP&C each PSU is on its own separate daughterboard.
 That's how 1000W+ PSU was done at the time (around 2006-2008 or so)...
 The Difference is that in some designs you couldn't see the dual PSU Design well, in others (like those two) its more obvious.
 AFAIR my ST65ZF also is of those 'Dual PSU' Designs...Last edited by Stefan Payne; 03-09-2018, 01:40 PM.Comment
 HiPros old( HP-D2537F3R) and new(ish)(H265AM-00).
 Here are a couple similarly rated HiPro (Chicony) PSUs about a decade apart:
 First the old HP-D2537F3R (rated 250W):
 Primary:
 Secondary:
 Load test 12V@13A, 5V@10A 3.3V@12A (246W total)
 Voltages:
 12V: 11.868V
 5V: 5.1954V
 3.3V: 3.3570V
 Oscilloscope shoots (scale set to 20mV per division, same load):
 12V:
 5V:
 3.3V:
 Efficency about 78%:
 and the new(ish) H265AM-00 (rated 265W):
 Primary:
 Secondary:
 Voltages:
 12V: 12.084V
 5V: 4.9751V
 3.3V: 3.3976V
 12V:
 5V:
 3.3V:
 Efficency also about 78% (and surprisingly very slightly worse than the HP-D2537F3R):
 Maybe.
 The design complexity of these units sometimes leads to an early downfall, especially the APFC circuit, it seems.
 Oh, I'll take the HP-D2537F3R no doubt. The newer HiPro (H265AM-00), has APFC with Teapo as the main filter... ugh, my hopes aren't too high for it. Also, if I remember correctly, that model (or a very similar one) even had problems with exploding snubber cap. If that's not enough to sway me, look at the scope shots: the HP-D2537F3R has much cleaner outputs, thanks to its over-sized output caps (not to mention it's a breeze to find replacement caps for an oldschool HiPro like that, which usually can easily accommodate 12.5 mm caps, even in spots meant for 10 mm diameter caps).Comment
 Looks pretty small. The main supply probably operates at really high frequency, though, so I imagine that's what allows it to be so small and still deliver its stated power.
 That said, do you have a label shot of the unit? Just curious who made the PSU and how much juice it's rated for.
 All in all, looks pretty much just like any other double-forward single 12V-design of today. And minor rails appear to be DC-DC buck regulated (again, as usual).
 Not a fan of the all-black colors, though. Sooo boring nowadays! At least the PCB is not black on the bottom side too (I hate working on black PCBs.)Last edited by momaka; 04-17-2018, 06:07 PM.Comment
 Well, yeah.
 Its an LLC-Resonant mode Converter.
 So I'd expect it to operate between 400kHz and 1MHz, maybe 2.
 And I don't know if you see it on the Pictures but the Secondary Windings from the Transformer are soldered directly to the additional Board, where the +12V Rectifiers are.
 Thats the 550W version of the Cougar GX-F, made by HEC/Compucase.
 Ähm, its not Double-Forward because no Coil on the Secondary.
 But another one right next to the main Transformer.
 That's how you can distinguish an LLC-Resonant Mode thingy from other topologys.
 Yeah and the interesting/great thing:
 Its a Single Layer Board.
 Another Interesting points:
 The huge 1000uF/16V Polymer caps
 The Enormous (for a 550W) 470uF/400V Main Cap.
 ARGH, that's the usual operation frequency of the DC-DC modules.
 The isolated part operates in a range of maybe 50kHz or so, maybe even more than that.Comment
 VIP ST-235ATX 250W ATX.
 After 20 years of service it was time to retire this unit. It won't start anymore.
 I'm not sure who the OEM is but that XF marking on the main transformer and those stickers are something I see from time to time. The 555 based fan controler is familiar too.
 I was really impressed to find a TOP210 in such an old noname unit.
 No PFC
 Primary rectification: 4x IN5406
 Primary capacitors: 2x 220uf Capxon
 Primary switchers: 2x E13007 ;half bridge topology
 Standby IC: TOP210
 35mm size center tapped main trafo
 5V rectifier: S30SC4M
 12V rectifier: S10C40C
 3.3V rectifier: S20C30C
 -12V IC: L7912CV
 -5V current stabilizer winding + FR152 diode
 5V standby diode: can't see the markings...
 Nice fan controller circuit.
 Wires are awg18 thick on mb and peripheral cables. Was good enough for some pentium 2 office machine that runs nothing but word97 and solitare...Last edited by pdavid; 04-20-2018, 02:26 AM.Comment
 Impressive.
 HEC/Compucase build quality has definitely stepped it up a few notches from what I mostly saw from them a decade ago.
 Ah, I see. Thanks for the explanation. Didn't cross my mind to look for the (lack of) output toroid.
 Yes, LLC-resonant explains a lot how this PSU can deliver so much power out of so few components. I think that's also the same (or very similar) topology used in LCD monitor CCFL inverters as well as those small halogen light switching PSUs.
 Thankfully!
 PCBs with both big and small (SMD) components on both sides can be rather hard to troubleshoot when something goes wrong.Comment
 Nah, should repair it and make it last 20 more years.
 Same here. Which is probably another reason why I would say it's worth repairing it. On that note, I would guess the most likely reason this PSU doesn't start is due to bad caps - either the "start up" cap for that TOP210, the 5VSB output caps, or some of the small caps around the secondary-side PWM controller.
 This PSU has a classic oldschool half-bridge topology, so there's not much to go wrong with it. Should be a fairly straight-forward fix (if you have the time and desire for that, of course).
 Yup. Even more than enough.
 BTW, I like the unique and strange fan cutout. And it cools like it exhausts hot air into the case rather than out? I've seen a few old Pentium-II era PSUs like that, at least.Comment
 A 5V 1A USB charger i got from DollarTree.
 I noticed DollarTree started selling USB chargers recently (at least the one near me) and so i thought i should get one to take apart to see how good it is.(and no, i'm not talking about the car USB chargers, i'm talking about the USB chargers you plug into your wall outlet (the 120/220 type).)
 Anyway, time to see how it works.
 Topside....................
 https://www.badcaps.net/forum/attach...1&d=1524907393
 Looks ok.
 Bottomside.............................
 https://www.badcaps.net/forum/attach...1&d=1524907593
 Also looks ok.
 Primary side.........................................
 https://www.badcaps.net/forum/attach...1&d=1524907622
 The fuse is a standard fusible resistor.
 The capacitors are 2 Chenxing 'VENT' 4.7uf 400v caps with a small PFC coil between them.
 I think the controller chip is a CR521 but i can't find any info about it.
 Secondary side............................................................................
 The blue ceramic cap is a real Y-class capacitor.
 The diode is a SS34 3A schottky diode.
 The capacitor is a Chenxing 'LOWESR' 470uf 10v cap.
 And that's pretty much it, i think it's decent. I was going to do a load test on it but ran out of time to do so, but i'll try to do it in about two weeks.Last edited by RukyCon; 04-28-2018, 05:09 AM.I'm not a expert, I'm just doing my best.Comment
 Assuming...7 Photos
			by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
			by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
			by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
			by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
 I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
 i know that in linear power supply the noise will be very low comparing to SMPS supply....
- Loading...
