This is a sticky topic.
  • pdavid
    • Jan 2011
    • 279
    • Hungary
    #2601
    Originally posted by Behemot
    No.
    Yeah, not anymore. I wonder if their post 2014 units have the DWG BY: xxxxxxx under the transformer? They sort of specify the desing for the OEM to build right?
    These supplies work by the way. Caps haven't failed yet. I have 3 more to check out. Seems to be decent units, good for vintage builds.
    • Stefan Payne
      • 1267
      Enermax has sold all their fabs, sadly they went to CWT and are selling many standard stuff with an enermax premium...
      They aren't as good as they were in those days...
      • dmill89
        • Dec 2011
        • 2534
        ^This, they still aren't "bad" but the entry/mid-level stuff is no different from the many other CWT rebrands in the same price range.
        • Stefan Payne
          • 1267
          And that makes them bad...
          A mediocre standard unit that you can get much cheaper elsewhere isn't a good unit...
          A higher price would be acceptable if it would be something special and did something different than other brands. For example a good multi rail unit with quite low OCP settings...
          But all Enermax is doing today is making 08/15 stuff and just put their fans in it...
          • hikaruichijo
            • Aug 2015
            • 123
            • Spain
            #2605
            Hi, opinions about this power supply please, sorry I forgot to take a photo of the back but the soldering was not very good.
            • Dan81
              SNES-powered
              • Oct 2013
              • 1866
              #2606
              450-500W. Maybe more with quality caps.
              Main rig:
              Gigabyte B75M-D3H
              Core i5-3470 3.60GHz
              16GB DDR3-1600
              Samsung SH-224AB DVD-RW
              Delux MG760 case
                master hoarder
                • May 2008
                • 12175
                #2607
                I think the "ZU" on the transformers means this PSU was made by Zumax Power. From what I've heard, they aren't that great, so I don't know if this unit will actually honor its 800 Watt rating. But I will wait for the other PSU experts here to chime in.
                All I can tell you is that this PSU has APFC and looks like it uses double-forward transistor topology. 3.3V rail is mag-amp regulated. Can't say more without knowing more, though. The rectifiers on the secondary heatsink should be somewhat indicative of what this PSU can handle.
                • hikaruichijo
                  • Aug 2015
                  • 123
                  • Spain
                  #2608
                  Hi, i've had to open it because the fan was making a lot of noise to replace it and now I'm worried because the system has and Phenon II X6 1100T, an HD7970 and 3 HDDS that is 125W+275W minimun when on full load the hole system maybe around 450W-500W at full load. And I'm not an expert on this matters but the quality doesn't look so good and I payd around 90 euros for it back on the 2012.
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    Yeah, this is a platform that Zumax, ePower, and Topower used for a while. It's a competent design, that's way overrated on the label. It will absolutely be able to handle that load. These units have a tight fan curve, so that's why the fan was speeding up. Those TDP ratings are unrealistic maximums. I have a "500W" version of that PSU, and it uses two 30A schottkys, I bet yours has better ones. I'd be more worried about the AsiaX caps it uses!
                    • hikaruichijo
                      • Aug 2015
                      • 123
                      • Spain
                      #2610
                      Hi, thanks, the fan has an strange bearing that I could not disasemble nor lubricate so I replaced it, thanks for the info I feel better now.
                      Next time I'll try to make better photos.
                      I tested one cap with the esr meter an it is still right an the output voltages are right also so I'll leave it for now.
                      • Viperel
                        • May 2016
                        • 34
                        #2611
                        Hello, i own a Corsair TX650 bought in 2008 which is in top shape except one detail, the 3.3V line shows around 2.99-3.05V (measured with a DMM).
                        I will post some pics with the little aged beauty!
                        • Stefan Payne
                          • 1267
                          What kind of protection IC does this thing use?
                          • hikaruichijo
                            • Aug 2015
                            • 123
                            • Spain
                            #2613
                            Sorry I already reasembled it and it is on the computer. But yesterday I had a problem with 700w model of the same brand, it burned a sata power because it was broquen and I did not notice it so I pluged it misaligned and it almoust got on fire but the power supply did not shutdown itself I had to unplug it so maybe it does'nt have a good overcurrent protectection....
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5072
                              • New Zealand
                              #2614
                              Well most ATX PSUs can supply dozens of Amps on most rails, which is plenty enough to burn connectors and wires and still not break a sweat.
                              You will only typically get an instant shut-down if you cause a dead short somewhere, and even then some cheap PSUs would just blow up...
                              -David VanHorn
                              • Stefan Payne
                                • 1267
                                who did it?
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5072
                                  • New Zealand
                                  #2616
                                  No idea. Antec?
                                  -David VanHorn
                                  • SIDMX
                                    • Nov 2010
                                    • 165
                                    • Mexico
                                    #2617
                                    Rosewill RG630-S12 (ATNG design)
                                    I really like this PSU except for the Teapos and the blown TNY277, it's the same model reviewed long ago at HS but definitely a newer revision, was "gifted" to me as a "for parts" unit but turned out to be an easy fix and it's now working without problems. I plan to do a full recap and use it in my main rig so what do you think guys?
                                    - U15K80R 15A Bridge rectifier
                                    - 400V 330uf Primary Cap
                                    - 24N60C3 PFC Transistor
                                    - RHRP1560 PFC Diode
                                    - CM6805 PFC Controller
                                    - UC3845B Main Converter Controller
                                    - 2 X 16N50C3 Main Converter Transistors
                                    - WT751002 SMPS Supervisor
                                    - TNY277PN Off-Line Switcher for 5VSB
                                    - S10C40C for 5VSB
                                    - S30D40C for 3.3
                                    - S30D40C for +5V
                                    - 2 X S30D60C for +12v
                                    • Behemot
                                      • 4845
                                      • CZ
                                      #2618
                                      Originally posted by Agent24
                                      No idea. Antec?
                                      Thats latest Xilence, Performance A+ series. OEM is Shenzhen Xin Hui Yuan Electronics Co., Ltd.
                                      • Stefan Payne
                                        • 1267
                                        No, just NO.
                                        • Philipus II
                                          • Nov 2014
                                          It's HEC
                                          Btw. Xilence A+ is non modular, the one Stefan is showing is fully modular.
