This is a sticky topic.
Anyone anything on the topology of that unit??
And why did we miss that PIC16C72A Microcontroller?
And that 8pin chip on the output side between the cables is just a serial Flash ROM.
And that chip with the cap glued on top is a FanXPert 3 Chip (whatever that is)...Comment
Anybody seen a Deer this beefy?
Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
What post # is that? I don't know if my eyes are broken or what, but I just can't find that post.
Well I don't know about being beefy, but it certainly has some "meat" on it. Maybe enough to last an entire winter.Originally posted by Dan81Anybody seen a Deer this beefy?
Okay, silly Deer jokes aside, yes I have seen Deer PSUs this good before and even better. It all depends how much you paid for it. The cheap ones can be almost as bad as the L&C line. The better ones can be fairly decent: line filtering, PI coils on the outputs, and a real
"35" size transformer.
https://www.facebook.com/Telford-Tel...7894576335359/Comment
#1821 in this thread.
An old NMB WTX PSU.
Looks like my 'IT 300W' Power Supply.
That one with almost all caps bloated...Comment
Well,considering this one powers a dual core system (and not a high end one) it's pretty good for the job. I know Allied/Apex does some good units. They're pretty rare here though - this was the only one close to an Allied,save for the 4 diode bridge rectifier and EI-33 transformer.What post # is that? I don't know if my eyes are broken or what, but I just can't find that post.
I could actually say it powers a "GIANT ROBOT". (Megas XLR
The Delux is still powering the Athlon 64 3000+ system. I've got two more PSUs though - a Premier LC-B400ATX and a Premier LC-B450E. All those three have PI coils. The former has them installed by myself and the latter came with them already.
The LC-B450E also has a weird thing - one of the rails has actually two rectifiers in parallel - it's the 5v rail if I'm not mistaken. Why do that is actually past my ability to understand - why do that when you have the 12v rail?Main rig:
Gigabyte B75M-D3H
16GB DDR3-1600
Delux MG760 case
What is this? Pictures for ants?
http://cdn.meme.am/images/300x/5029296.jpgComment
Less jewellery, more gold into electrotech industry!
Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
Hm, this Forum does not support using image links with thumbnails.
Weird...
Used the same code in another forum where it worked - here it didn't..
And I can't edit my posting somehow...
Well than, as atachements (didn't want that...)Attached Filesif you find these attachements useful please consider making a small donation to the site
Corsair RM650x? Or maybe 750x.Less jewellery, more gold into electrotech industry!
More than 750w ?Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
P.S.,
We (the forum) encourage using attachments because images hosted off-site are unreliable.
As an example: You look at a year old thread to get info for a repair, only to get the dreaded "image not found" error! ... that can be quite frustrating!
-BenMuh-soggy-kneeComment
Interesting PSU.
I would guess either double-transistor forward or full-bridge. Maybe the latter as there are 4 transistors on what appears to be the primary heatsink. The other primary heatsink probably has the APFC transistor(s) and rectifier(s).
I don't know what the PIC chip does in it (or why there are even so many ICs). Most likely using a programmable IC like a PIC chip was easier than trying to make all sorts of controllers work together.
Very nice power supply!
I'd definitely mod it to ATX standard and use it if that is possible. I'm pretty sure this will work forever with those caps and that built quality.Last edited by momaka; 10-27-2015, 09:59 PM.Comment
Hm??
They use another plattform for the 550W model?Comment
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... - Loading...
