This is a sticky topic.
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Saved proprietary Macron MPT-350D
    Okay, so this is another one of the last projects I did at my last company. Thing got about 39,000 running hours on it. The customer brought this computer in and wanted general diagnostics run, even though everything was "fine." I was immediately interested by the chassis ( http://www.newegg.com/Product/Produc...82E16811119071 ) and once I looked at the back of the power supply I yelled "MACRON" I noticed that it was indeed a Macron once I looked at the label, and that it wasn't quite an ATX PSU....I immediately knew that the PSU had bad caps (I even bet my coworker $1000 on it, he did not accept. DAMN! ) but the computer already had a memtest running on it. I opened the top case, and WOW, the thing was fucking hot! Just the side chassis of the PSU was 42C! I guessed that it was powering a Prescott P4 because just by glancing at the board I knew it didn't support Core 2, and the early 2005 sticker on it suggested it wasn't a Pentium D. Once the memtest was done I powered it down and took the PSU out. The thing had been off for about a total of 6 minutes, and the secondary heatsink still measured 75C! The primary was about 50C. I let it cool down and took the heatsink off the CPU. It was indeed a Prescott 3.2GHz P4, 640 model. The thermal paste was so dry and got so hot that it actually started turning brown. The unit was also powering a single 7200RPM hard drive, one DVD drive, a Radeon X1650, 4 1GB DDR modules, two TV tuner cards, a wireless G PCI card, a PCI sound card, and two 0.30A exhaust fans running at full speed. After looking at the inside of the PSU only having a 16A ultra fast, I'm utterly amazed that the thing didn't blow up! And look how cooked that resistor got. I couldn't see the value so I decided not to replace it.
    When pulling the secondary heatsink to replace the 16A ultra fast with a 30A schottky, the 16A rectifier partially split down the middle in the space where the three leads go in to the silicon, and you can see how the heat discolored it. The thing is a true champ Most of the rectifier screws were becoming loose so I tightened them.
    Almost all of the caps tested bad. The only caps that didn't test bad were both 2200uF 6.3V G-Luxon LZ caps on the 3.3V rail (I don't know how this is possible) and the 1uF 50V caps on the secondary. The 10uF 50V GoldLink caps on the BJT circuit read ~2.5uF and over 40Ω ESR I replaced all of the caps with Japanese parts, and because of the high heat and running hours, I replaced the 1000uF G-Luxon caps on the input with barely used 820uF Asia'X. I also redid a lot of the soldering joints that looked like they got weak from the heat they endured.
    The Superred fan span okay, but they covered the bearing so that I couldn't get to it. Because of this, I didn't take the risk and just replaced it with a Power Logic ball bearing fan Because of the ripple that the hard drive endured, I talked the customer into cloning their drive to a brand new 500GB one. Everything went successful. I only had an hour to work on this thing, so those are the things I did to it. But afterwards, the thing ran so much cooler! The side chassis of the PSU was barely lukewarm, and the air coming out of the back of the PSU was just warm instead of hot. Just another example of how tough these old Macron PSUs are. I don't think the customer realized what had to happen for their precious computer to maintain proper operation, but I sure felt good after the project was done.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      ^ Replace the 10 ohm resistor, it looks cooked! It might be for the snubber on that rectifier, so that might be why the rectifier started to get really hot.
      Edit: and replace the green film cap near it. It has turned dark green/brown, so yeah it's not had a happy life.
      Muh-soggy-knee
        master hoarder
        • May 2008
        • 12175
        #2323
        Re: Saved proprietary Macron MPT-350D
        I guess you can't hide your love for those things. Well, me neither .
        It's sad that this case/PSU got so many sub-par and negative reviews on newegg. The worst are reviews that say "Oh, its a 350W generic, so it must be crap". Then they go and buy a sub-$20 "non-generic" 500W+ Logysis or the like and think it is all good. Ugh.
        Imagine how many of those have been thrown away now due to crappy caps. Makes me wish I could somehow get them and fix them. They are such wonderful PSUs after a recap.
        He probably knows you'd be right and it was best not to mess with you.
        Well, good thing it wasn't a Pentium D. That would have made it run even hotter.
        Dang. And those heatsinks actually looks pretty decent too. My MPT-301 has the really skinny ones. I can't imagine what would have happened if this Macron had those.
        Yeah, that 16A ultrafast can take quite a beating before letting go. On my MPT-301, the Supperred fan had completely seized. Yet, whoever had it still wrote on it "Fan does not run. Power out OK"
        It's not visible from the photos I posted, but I had the same exact resistor and capacitor really darkened. I think ben7 is correct, it is a 10 Ohm resistor. As long as it's still in spec, it doesn't need to be replaced. Same goes for the green cap. Macron usually uses 103j (i.e. 0.01 uF 5%) polypropylene rather than ceramic - a nice touch IMO.
        I've seen the same happen in an Allied PSU with those snubber resistors. This is usually caused by the output caps failing.
        I hope you saved that Superred fan. The one in my MPT-301 was sealed like that as well and it was completely seized - couldn't even turn it by hand. Had to drill the plastic on the back to get it taken apart. I did, and in the process, I destroyed the plastic c-washer that keeps the fan rotor blade assembly from pulling out. But it ran fine without it, so I left it as is. That was some 5 years ago or so. It still is running to this day. Not rattling or anything either. So Superred fans are good, IMO.
        1 hour. ONE hour? It takes me that long to scratch my ass. Then another one to realize that I did so I can stop.
        Geez man, you're a true PSU wiz.
        • Behemot
          • 4845
          • CZ
          #2324
          I share the same for different FSP Group units. Quite good too and mostly with bloated caps only.
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Ah, 10Ω. Well it's too late now, that unit has got a solid 1,150 more running hours on it by now. I'm no longer at that company I did the work for, but I specifically asked my coworker if this exact unit came back in, and he said no
            Haha, I guess that says something though, because he had only been at the company for 3 days
            Yeah, I love these PSU's Can't hide it...I'm also in love with proper AC plugs And I know, a lot of those newegg users have no idea what they're talking about. But...what's new? It's still a shame that Macron insulted themselves by using such bottom of the barrel caps in their well designed units. They seemed to squeeze the most out of the ancient half bridge design. I guess your only option to save some is to check fleabay often, and check your local PC recycling stores.
            No kidding! I'm amazed at how much punishing heat 90nm CPU's can handle though. I think this board uses lead solder as well, I don't think lead free solder could have survived, the BGA probably would have failed a long time ago.
            Very true. But what I'm thinking is that the PSU was getting abnormally hot for a number of reasons:
            1.) That 16A rectifier had to be overloaded or close to it its entire life. (Reducing efficiency in the process?)
            2.) The rectifiers were becoming loose on the heatsink
            3.) The poor cooling on the Pentium 4 right below the fan intake of the PSU was pulling extra heat inside the PSU.
            4.) Pretty sure the failing caps would create more heat?
            Because afterwards, the PSU ran about as cool as your MPT-301 powering a P4 system with no video card. So either it was extra heat from the CPU, or the efficiency was becoming abysmal to create so much heat! Seriously, the before and after heat difference was amazing.
            Oh yeah, I remember that thing
            I figured as much. I know that resistors can handle an incredible amount of heat. Something like 160C for metal film? I also figured that all this damage was caused by the overloaded rectifier and failed output caps, and that the new, almost double rated schottky + new caps would be good enough to keep it going. I've also seen this is an Allied and a Deer PSU before. So yep, failed output caps sounds accurate haha
            Yes, I normally save Superred fans if they have a seal. I already have so many spare fans, I didn't want to spend the time on this one, so I threw it away. Sorry! At least I put another Power Logic back in the field, does that make up for it?
            Thank you! But guys like you are the true PSU wizards, knowledge wise. I just have a speedy process and a nice soldering iron which makes things go faster. Only charged $90 to do that power supply job, they happily paid it.
            Which design? There are so many solid FSP units that used garbage caps
              master hoarder
              • May 2008
              • 12175
              #2326
              No PC recycling stores here. Rather the county does it for several months in the spring and summer at their site. Not allowed to take anything. And most people in the area here either chuck stuff in the bin or try to sell them on CL for a small fortune, lol.
              Actually, the forward voltage drop of diodes decreases with increasing temperature, so technically efficiency improves.
              I think the biggest contributors to the inefficiency were those dried up caps on the BJT drive circuit (making the BJT turn on too slow and run for longer in their linear regions) and the fact that the 12V rail was a fast recovery rectifier rather than a schottky. FRs tend to have 1V or more Vf, whereas for schottky, it is usually 0.3-0.7V - almost 2 to 3 times less losses.
              We had an interesting experiment back in my older college. Had to cook two resistors for a lab in various ways - one was by slowly increasing power and waiting a bit between increases to see at what power level the resistor would fail. The other was by pulsing really high amounts of power. In both cases, the resistors could handle about 2-5 times its power rating. IIRC, we did this with 1/4 Watt carbon film resistors, and most too at least 1W before they became open.
              I hate killing good components, though, so that lab was not my favorite. Already knew what would happen when you abuse a resistor :P: .
              Heh no probs. It's just in my inner soul to try and save anything and everything that is salvageable.
              As the saying goes: those who can't do should only teach .
              • Behemot
                • 4845
                • CZ
                #2327
                Everything up to Blue Storm II / Everest / Epsilon incl. The latest started failing with other problems too but still mostly caps.
                Man 90 bucks for that? I think you can buy some very nice new unit for that kind of money!
                • Wester547
                  • Nov 2011
                  • 1268
                  • USA.
                  #2328
                  Probably because G-Luxon was and is (before and after their acquisition with Teapo) inconsistent as with other Taiwanese and Chinese brands. Sometimes they fail and bulge just by sitting there for many years, other times they last several years of heat and torture as in your case (at least two of them). It may also have to do with the fact that the failed G-Luxon LZs are on the +5V rail and are literally touching the +5V/+12V toroid... and that toroid probably became quite a bit hotter than the +3.3V toroid during operation (this was a +12V heavy system from what I can surmise). Loose rectifiers can definitely impede the thermal transfer to the heatsink.
                  That Prescott may be leaded solder but it's still a LGA775 CPU as far as I know and the LGA775 socket is very fragile (warps easily) and its pins very easily bent and broken, and that might cause issues after that many acrid thermal cycles. The stock thermal paste surely didn't help. And that CPU only has a maximum operating temperature of almost 67*C in accordance to Intel.
                  And 42*C, you would consider hot? I know everyone's perception of heat and "pain tolerance" diverges, but IMO over 50*C is about the point where something becomes burning hot and uncomfortable to touch. 60*C is definitely too hot to touch and 70*C can scald your tissue in a second.
                  Or those who can't do tech should only teach?
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    That makes me sad, actually lol
                    Interesting. So the increased amperage rating, lower VF, and being tight to the heatsink made that much of a difference. Amazing!
                    Yeah that'd make me cringe too, poor resistors That's amazing though that they could handle 2-5 times their rating. How long could they handle that?
                    I'm sure you do plenty, you just take forever to type out the posts and upload pics I think your next dissection should be the ePOWER. No pressue. *nudge nudge*
                    Yes those were good units! Yeah, but they got 5 hour turn around time. Plus, it wasn't a standard ATX PSU, seems like a rare type. Better than paying for one on eBay, waiting for it, and then probably getting one with bad caps in it. Also, fierce competition for business in downtown Seattle, so we had to make some money off our good service and special knowledge.
                    I'm still surprised. The whole unit was very hot inside, and those caps are about 10 years old. And I bet that system used more 3.3V than modern ones.
                    Intel is probably erring on the safe side. This CPU was idling at 60C and while testing got up to 80C. Imagine this thing in the past few summers...After replacing the thermal paste, it idled at 39C and peaked at 57C. That's how bad the old thermal paste was! It wasn't a stock cooler, it was significantly better, but still installed in 2005.
                    No not hot to my fingers, but for the side of a PSU chassis while running, I'd say that's pretty hot!
                      master hoarder
                      • May 2008
                      • 12175
                      #2330
                      Well, what do you know, I even still have my lab report on this laptop.
                      Actually, the two resistors we tested (100 Ohms, 1/4 Watt, 1%) could handle about 1W of power without going out of spec for more than 5 minutes. So they may very well be capable of that rating indefinitely. However, at that power level, they did discolor quite a bit. Beyond 1W (1.15 Watts, actually), they started increasing in resistance, went out of spec, and burned out.
                      Yeah, that's because I want to make my posts as perfect as possible (and they are never perfect, damit ). But I do have the pictures taken, at least.... Actually, even the write-up with all of the parts, I just checked. Don't know why I haven't posted it yet. Let's aim by the end of the week. I promise this time.
                      Wow, that thermal compound really was gone. It's actually not that hard to keep those Pentium 4 Prescotts somewhat cool. In general, they will run warm, but nowhere near 60C idle. 39C idle is a lot closer to what I get mine to run at (usually 42C or less, depending on room temperature, of course).
                      • datoska
                        • May 2015
                        • 12
                        • Georgia
                        #2331
                        umm, sorry but i have one fast question...
                        DPS-800 LB - power supply from hp workstation.
                        will fit in atx case ? if some holes must be created for that, its not a big problem...
                        i'm also interested, how much 6 pin graphics card power connectors does it have ?
                        and what means those 6 rails ? i'm kinda confused...
                        i know there is cpu line 1 and 2
                        but others :
                        12vD
                        12vB
                        12vM
                        12vG
                        (btw sorry for my english...)
                        and btw, i'm gonna buy it for 26.5$, its good deal for me....
                        • Compgeke
                          • Feb 2014
                          • 524
                          That's the XW8600 PSU I believe.
                          It won't fit an ATX board at all, it's proprietary to the workstations. I suppose with some modifications you can hack it up to a proper ATX connector and butcher the memory connector for the 12V CPU but it's probably more effort than it's worth.
                          It also has two 6-pin GPU power.
                          • c_hegge
                            • Sep 2009
                            • 5219
                            I'm pretty sure it's the same as the DPS-750CB I used to use. It is mostly standard ATX, but it's a bit taller, so it won't physically fit into the PSU compartments of most cases (with the exception of some very large cases, like the Antec 1200). I think that the ATX connector pinout is standard, though. As for how many connectors it has and the rail distribution, I don't know. I haven't seen an 800LB before.
                            • c_hegge
                              • Sep 2009
                              • 5219
                              Delta DPS-250AB.
                              https://www.badcaps.net/forum/attach...1&d=1432204397
                              Looks like a pretty typical TFX Form Factor unit. It came from a Dell Inspiron 530S.
                              Another shot of the Fan grille. Delta, you're doing it wrong! Wire grilles only, please!
                              The Label. It looks like we have 17A of 12V capacity. Not much, but enough for a PC with onboard graphics, I suppose.
                              Naturally, a Delta PSU uses a Delta fan. Hopefully I shouldn't have to replace it any time soon.
                              The Input filtering consists of three coils and two of everything else
                              The Internals. Not too bad, except for...
                              CapXon GL? On the 5vsb? On a cramped TFX unit? Are you serious, Delta?!
                              The rest of the caps are LTEC and Taicon. At least Delta usually get away with those pretty well. I'm still gonna recap it, though, with the exception of one 16V 1500uF Taicon which I don't have a replacement on hand for.
                              • Behemot
                                • 4845
                                • CZ
                                #2335
                                It is cheaper to cut into metal plate than buy wire grill
                                You can use Samxon RS 3300/16, no? There seems to be room enough for taller cap.
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  I could, but I'd prefer not to. I'd much prefer to keep the capacitance the same.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4959
                                    • New Zealand
                                    #2337
                                    I don't like Delta. They sneak a CapXon in somewhere too often for my liking.
                                    -David VanHorn
                                    • Stefan Payne
                                      • 1267
                                      Nothing wrong with that...
                                      At least they are better than JunFu/AsiaX and the likes...
                                      (But Delta also uses AsiaX)...
                                      • Wester547
                                        • Nov 2011
                                        • 1268
                                        • USA.
                                        #2339
                                        Ah, the power of the CapXon capacitors... so strong, they can't help but pop!
                                        No, I would not rank CapXon above AsiaX, JunFu, or Fuhjyyu. They are just as bad. I don't recollect Delta ever using AsiaX, though. Any idea what the primary and secondary silicon is in the supply? And looks like the -12V linear regulator is without a heatsink so definitely a bit cheaper by contrast to some other ones. Not that it matters, -12V isn't used much at all in modern systems. And I would preemptively lube the Delta fan anyway because I've seen several ASB0812HH fans from older Delta and Newton supplies seize or come close because of a lack of lubricant.
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 4959
                                          • New Zealand
                                          #2340
                                          Nothing wrong with CapXon? Could have fooled me.
                                          Are you saying all those bulging\leaking CapXon I've pulled and replaced were OK?
                                          -David VanHorn
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                            Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                                            by momaka
                                            More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                                            02-15-2022, 12:43 AM
                                            Boston Acoustics HD8 – build quality impressions & DIY woofer surround repair
                                            by momaka
                                            Boston Acoustics fans, this thread might not be for you.
                                            A few years back (~2018 time frame), I picked up a set of free JVC speakers from someone on Craigslist that no one seemed to be interested in. The guy also had a single Boston Acoustics HD8 speaker – yes, just one cabinet. He said he had no idea where he got this one from or why it's only by itself. But like the JVC speakers, it was going to get tossed at the end of that week… so I came to collect, as usual. And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the...
                                            01-30-2022, 11:57 PM
                                            DVR camera recorder switching power supply capacitor failure really
                                            These cheap non brand capacitors at it again
                                            Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                                            Well at least I have the cameras back on line I to try the...
                                            01-22-2022, 06:28 PM
                                            DVR recorder Switching power supply Failure
                                            When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
                                            Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
                                            This...
                                            05-27-2023, 03:03 AM
