This is a sticky topic.
  • Stefan Payne
    • 1267
    If we assume those caps are 65°C hot, with 10K less the lifetime doubles with a 1000h cap, than we have: 1000x2x2x2x2 = 16000h
    16000h equals about 666 2/3 days of operation.
    So that's still in the expected lifetime of that cap, is it not?
    • Behemot
      • 4845
      • CZ
      #2082
      Chinese crap barely holds two years if you run it 18 hours a day loaded at 65 °C. It depends on many circuimstances, if you run 100 W load on "500W" PSU filled with this it surely survives more than with 350 watts.
      • mariushm
        • May 2011
        • 3799
        #2083
        The "double rating with every 10c decrease" is just an estimation like I said. Most companies accept it and mention it in some of their documents.
        Like someone said above me, you need to ignore those hours when a device is not in use.
        Then you also have to keep in mind that it's ideal conditions, while in reality you'll have humidity (which could infiltrate though the leads for example or attack the aluminum exterior) or make the bottom bung crack and electrolyte unless you have the computer running 24/7.. then you have fans, dust etc etc
        • Stefan Payne
          • 1267
          Well and there's the problem of the 'inner temperature' of those things.
          For example the casing is about 65°C hot but you don't know how hot it's inside. Could be 60°C, could be 85°C.
          And still: Baseline is about 1000-4000h, depending on the diametre...
            master hoarder
            • May 2008
            • 12175
            #2085
            Originally posted by Pentium4
            I've isolated the whine to the 5VSB. I tried using caps with lower ESR and it still does the same thing. Went from nichicon PW 1000uF 10V to Panny FM 1000uF 16V. I wish I could remember if it was whining with the failed Canicon caps.[
            If it helps, the voltage on the 5VSB is very stable.
            Many flyback topologies tend to whine with low ESR caps. Usually doesn't cause any problems, though - at least it hasn't for me, and I've done quite a few with very very low ESR caps.
            Also, for some PSUs, the whine on 5VSB is normal. My Macron MPT-301 does it as well and it's quite loud. I'm not sure if it did it with the original Fuhjyyu caps or not, but I never bothered to see, becuase I've used it like that for a long time.
            I say load it with a 1A load and let it run for 1 hour. If nothing explodes, smokes, or overheats, it's probably fine. Perhaps check temperatures in the 5VSB area as soon as you are done with the test and unplug the PSU from the wall.
            • Behemot
              • 4845
              • CZ
              #2086
              Provide some cooling if you are to load it with (not very big) resistor. Cause 5 W even on 5W labeled resistor can cause it to heat very much after an hour, it will smell after few minutes and may set something on fire…so I recommend 10W+ resistor, or more smalelr ones.
              • _chiller_
                • May 2014
                • 6
                Hey, I got a Tacens Radix Eco II 600W:
                http://www.tacens.es/fuentes-de-alim...ix-eco-ii-600/
                Does anyone know the OEM of this thing?
                  • 31044
                  lol more like 350w
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #2089
                    300w maybe.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      #2090
                      Got an Hec 300arpt oldie but a goodie, got off carboot for 99p so a good deal weighs a tonne due to a huge passive pfc coil and thick steel case very well build going to recap and should be a solid unit
                      Specifications listed:
                      Sleeve bearing power logic slim line fan I used this because the old hec fan spun so fast made this psu unusable for a standard desktop due to being so loud also there was a lot of wind turbulence created because if the passive pfc coil covered half the old fan, it was rated at 12v .43 a :O
                      Primary transistors TT2144
                      Passive Pfc
                      Output rectifiers:
                      3.3v Mbr 4045pt
                      5v Mbr 4045pt
                      12v s3040pt
                      Bridge rectifier BgPbu605
                      Output capacitors:
                      3.3v 2* 2200uf 10v samwha will be replaced with 1* 3300uf Panasonic Fc 1*2200 uf 10v Panasonic Fc
                      5v 2* 2200uf 10v samwha will be replaced with 1* 3300uf Panasonic Fc 1*2200 uf 10v Panasonic Fc
                      12v 1* 2200uf 16v samwha 1* 470uf 25v jamicon will be replaced with 1* 3300uf 16v Panasonic fc 1* 2200uf 16v Panasonic Fc
                      Primary unit 2* 680uf 200v capxon
                      The rest of the capacitors are pce tur
                      Defiantly 300w will be great after a good recap.
                      • Behemot
                        • 4845
                        • CZ
                        #2091
                        Tacens uses whole bunch of OEMs - Huntkey, FSP, CWT, Andyson, HEC, Enhance. But this one does not ring any bell…
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          Whoever it is, it's the same as the new EVGA PSU I just recapped. I think it's good for at least 400W. Uses double forward with two 16A FETs on the primary, two 20A schottky for 12V with single rail, and 30A for 5V and 3.3V
                          • Behemot
                            • 4845
                            • CZ
                            #2093
                            What's the model name/number?
                            • Pentium4
                              CapXon Be Gone
                              • Sep 2011
                              • 3741
                              100-n1-0400-l1
                              • _chiller_
                                • May 2014
                                • 6
                                250W is max for the Tacens
                                I found an "8688F" on the PCB, does this help?
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  #2096
                                  It almost looks exactly like cit gold that I had if I remember it was a haisen or something not sure ?
                                  • Pentium4
                                    CapXon Be Gone
                                    • Sep 2011
                                    • 3741
                                    8688F doesn't turn up anything, and UL on mine only goes back to EVGA. Behemot, it kinda looks like the Zalman ZM400-LE that you reviewed
                                    • Behemot
                                      • 4845
                                      • CZ
                                      #2098
                                      It shares some similarities but all these generic chinese PSUs are the same. Two-transistor forward with PWM IC stand-by, magamp for +3,3 V.
                                      • Pentium4
                                        CapXon Be Gone
                                        • Sep 2011
                                        • 3741
                                        Yeah, but they're double forward. Idk, they look like the same OEM to me http://translate.google.com/translat...20%26bih%3D933
                                        And they both have abnormally barren on top side of the PCB, as in not many resistors, zener diodes, etc.
                                        • Behemot
                                          • 4845
                                          • CZ
                                          #2100
                                          Oh yeah, mistaken them, I do it all the time 2 transistor OFC.
                                          There's lot of SMD components these days, they are cheaper than leaded.
                                            03-31-2024, 02:12 PM
                                            07-01-2024, 06:34 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                            Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                                            by momaka
                                            More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                                            02-15-2022, 12:43 AM
                                            Boston Acoustics HD8 – build quality impressions & DIY woofer surround repair
                                            by momaka
                                            Boston Acoustics fans, this thread might not be for you.
                                            A few years back (~2018 time frame), I picked up a set of free JVC speakers from someone on Craigslist that no one seemed to be interested in. The guy also had a single Boston Acoustics HD8 speaker – yes, just one cabinet. He said he had no idea where he got this one from or why it's only by itself. But like the JVC speakers, it was going to get tossed at the end of that week… so I came to collect, as usual. And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the...
                                            01-30-2022, 11:57 PM
