This is a sticky topic.
Its not even that lucky. Its a half-bridge unit. If designed well, a half bridge unit can deliver the advertised wattage no problem. 13009's are not sufficient in this case, and this unit is not a stellar design.Last edited by 370forlife; 10-14-2014, 07:02 PM.Comment
As I suspected 400w max if that, I could upgrade the 13009,s but its not really worth doing as it has no pfc.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
I vote for try'n'load. Because the reality is you would condamn 80 % not-so-stellar PSUs on the market which can actually deliver the power…Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
Of course he does, he's from JG forums. They're total elitists about power supplies, they think most PSU's are garbage because they're used to seeing such good stats from the top of the line PSU's all the time.Comment
- don't even get me started....
"pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!Comment
Don't think so. It is a relief I finally meet some people who also care about quality when talkign about picking up new PSU, but nonetheless there is still many people advertising crap in there.
Not to mention if I was editor in there, the score of most power supplies would be half it is now and many won't pass at all. It has terrible voltage regulation, OK than, one point down. It does not even comply with ATX? Oh that's OK, we just take half a point down…under me such power supply does not pass, period. They are too soft on them…Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Let's not forget that they always whore out- those "reviews" are so positive and "sparkly" (hehe). But it's like newegg "reviews"- give five stars for "experience" (or lack thereof), and suddenly we know what we're talking about, either on NE or JG.
JG power supply "reviews" are an insult to anyone who's worked on, built, or otherwise has experience with them.
They should stick to reviewing cases. Preferably the nasty ones with razor-sharp edges, deep inside waiting to "surprise" someone.
Tells me all I need to know when they keep referring to the RFI/EMI filter as a "transient filter" (it is NOT) and proudly showing pix of questionable caps. Then upholding a 9.5/10 beacuse "the ripple rejection" is "excellent."
Sorry JG- good ripple rejection is part of any decent PS- don't pull something outta your ass and use it to whitewash those junk caps, which you and/or your buddies took pix of.
Just because "antecrep" may have fooled some people, remember there's a certain group that will never be fooled.
I refer to that bunch as "JonnyGOOFUP." Why not- same initials!
When L&C comes out with one of those large mostly 12V supplies, with internal converters to derive the other voltages, there will be an inside joke:
Deer and Buck (converter) season!"pokemon go... to hell!"
EOL it...
Because too much PR/Marketing bullshit and not a really balanced design.
Something like a cheap sleeve bearing fan, secondarys like Su'scon, CapXon, SamXon, next to no heatsinks but a big 'japanese cap(s)' sticker on the box, because they used on the primary side...
And the usual 8pin protection IC like a Weltrend WT7502 (witch is fine, when combined with say an LM339 or something like that as used in some old enhance or HEC designs)...
So in the end you have to say:
The best PSU out there comes with a computer. They don't have some fancy shit like sleeves or cable managment or other stuff...
Especially those double PCB PSUs like those NMBs I have here...Comment
Samxon caps are among the best being produced. Does not apply to GF and GK series, though.
I am not saying they are any good, but at least most of them nowaddays can deliver the power. They improved at least so far.Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Well another typical antec came to me full of blown fuhjyyus but apart from that a decent little cwt psu, rated for 480w semi modular need the cables though to be able to use this.
Had a nasty burnt 1800 ohm resistor on the primary side.
Specifications listed:
Ball bearing dynatron fan.
Double banks of output rectifiers
I couldn't see what the primary transistors were
Output capacitors listed:
5v 3* 3300uf 16v samxon rs
3.3 2* 3300uf 16v samxon rs
12v 2* 3300uf 16v samxon rs
-12v 1* 1000uf 16v Panasonic fr
-5v 1* 1000uf 16v Panasonic fr
5vstb ic design 1* 470uf 25v ucc ky 1 *220uf 25v jamicon (they are on the 5v stb weird values)
Smaller capacitors jamicon
330uf 400v rubycon uscLast edited by ReeceyBurger123; 10-20-2014, 07:44 AM.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
What's that big white thing screwed to the secondary heatsink for?Last edited by Stefan Payne; 10-20-2014, 09:35 AM.Comment
Hard to belive that is...
GF are 1000-4000h types.
GK are 2000-5000h types.
The life depends on the diametre of the cap.
GT and GY Types are 4000h-10kh types, so it's safe to assume that they will last longer...
But they will also be more expansive than the GF and GK types...
Another point:
Japanese capacitors sounds better than long life (minimum 5000h types) chinese/taiwanese capacitor...
For exaple:
A NCC KZE cap is also just a 1000-5000h type...
But most 'PSU testers' will rate a NCC KZE Cap higher than for example a Teapo SY, although the datasheet of the Teapo SY states that it lasts from 2000-6000h, so it's a bit better than the NCC KZE.
The same applies to the SamXon lineup. The ones that probably will last longer are more expansive. And you can't really put them into end user PSUs because of marketing/PR reasons. You'd rather use 'japanese caps', even though they are worse because of that...
Buttom line:
The really good stuff is not available in a box on a shelf in a store!!
Most PSUs we can buy aren't really worth it...
The really good stuff (like the Delta 500QB you can buy for about 15€ in Germany + shipping) is put into PCs from big OEMs like DELL, HP. And some of the stuff you can buy with a server case...Last edited by Stefan Payne; 10-20-2014, 06:57 PM.Comment
The lifetime ratings on the datasheets are endurance lifetime ratings. ie. how long the cap can run with its maximum rated ripple current at its maximum rated temperature before the specs go out of tolerance. Any cap will last longer than that in real world conditions. The difference between good caps and cheap caps is how much longer (and possibly how much the manufacturer decides to overstate the endurance lifetime).I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
The lifetime rating isn't in relation with technical parameters.
The lifetime depends on chemical formula of electrolyte, materials used (plastic/rubber/etc bottom, metal of leads) , dimensions of capacitor and a few other things.
It's an estimation of how many hours the capacitor will stay within specs (around some technical parameters specified) if you keep the capacitor at those high temperatures.
With lower temperatures, the lifetime rating increases... a non official rule says rating doubles with every 10c decrease in average temperature.
ps.
It's possible for a company to have a whole catalogue of very good capacitors but also have a few series that are simply bad. In particular with very low esr capacitors, this can happen, as the electrolyte inside them is more... let's say unstable. Some manufacturers get the process better, others don't. Samxon GF may be a victim, just as UCC KZG and a few other UCC series were, and like Nichicon HM and HN had problems around 2004.Last edited by mariushm; 10-20-2014, 09:38 PM.Comment
"Hard to belive that is..."
Why is that hard to belive ? That resistor is on the 5vstb and does help reduce that high pitch whine when in standby !Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
The lifetime ratings on the datasheets are endurance lifetime ratings. ie. how long the cap can run with its maximum rated ripple current at its maximum rated temperature before the specs go out of tolerance. Any cap will last longer than that in real world conditions. The difference between good caps and cheap caps is how much longer (and possibly how much the manufacturer decides to overstate the endurance lifetime).Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
- Loading...
