This is a sticky topic.
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    All those little caps were replaced with Mostly Rubycon YXF and one each of nichicon PW, and Panny FC. If it helps, the voltage on the 5VSB is very stable.
    • Behemot
      • 4845
      • CZ
      #2002
      And before, those also were all low-ESR caps?
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Originally posted by Behemot
        And before, those also were all general purpose caps?
        Hard to say, since all the ones before were CS and Canicon with no series I could go by the ESR, but who knows how much it has changed in 10+ years
        • Behemot
          • 4845
          • CZ
          #2004
          Typo, I meant low-ESR.
          They really have no markings?
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            #2005
            You can't go esr higher than YXF and FC. The whining is not due to the caps being too low esr.
            • Behemot
              • 4845
              • CZ
              #2006
              OFC you can, standard caps like Nichicon VZ, NCC KMG have higher ESR. YXF is only slightly higher than PW.
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                No markings on the caps whatsoever except 105C and early 2004 date codes. I thought that maybe the caps needed to be "broken in" so I let the PSU run over the weekend, but it's still whining. It's a high pitched whine, and can only be heard at certain angles. Could it be something ridiculous such as it not being grounded properly, or a bad joint somewhere? All I can think of that I changed on the PSU is trimming leads, readjusting PG/PS_ON wires, redoing some blobby joints, and changing the caps.
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  #2008
                  I would check all those things that you mention.
                  In my opinion a psu that has problem with YXF/FC and needs higher esr caps to function is not worth bothering.
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    Yeah, it's a nice PSU though. Bizarre issue. Your Linkworld is similar, does it do the same thing?
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      #2010
                      I have many Linkworlds, one of them makes whining sound. It's from 5vsb circuit and I think it's because I used Panasonic FM for critical 5vsb cap.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4924
                        • New Zealand
                        #2011
                        Why? You can still get high quality capacitors that are not low ESR, surely. If it works and lasts a long time, what's the problem?
                        -David VanHorn
                        • japlytic
                          • Oct 2005
                          • 2086
                          Two third-party Xbox 360S power supply units:
                          XP-360
                          150uF 400V Taicon AQ primary unit.
                          2200uF 25V ChongX before and after skimpy +12V inductor with 470uF 25V JWCO after +12V MOSFET switch.
                          470uF 25V JWCO after +5V regulator.
                          All other electrolytics are JWCO brand.
                          MBFR20100 x2 rectifiers for +12V.
                          WFF10N60 primary switcher.
                          KPL410 primary rectifier.
                          EMI filter choke has been omitted bridged out.
                          XP-360L
                          68uF 400V ChongX primary unit.
                          2200uF 25V FMZ (both bulging) before and after skimpy +12V inductor with 220uF 25V ZHC after +12V MOSFET switch.
                          220uF 25V ZHC after +5V regulator.
                          MBFR20100 rectifier for +12V.
                          18NM60N primary switcher.
                          KBP307 primary rectifier.
                          • RJARRRPCGP
                            • Jul 2004
                            • 6301
                            XP-360
                            XP-360L
                            The XP-360L actually looks less cheap. Looks like the caps are the only big issue.
                            (The transformer on the left-hand one looks real cheap!)
                            ASRock B550 PG Velocita
                            Ryzen 9 "Vermeer" 5900X
                            Arc A770 16 GB
                            eVGA Supernova G3 750W
                            Alienware AW3423DWF OLED
                            • Behemot
                              • 4845
                              • CZ
                              #2014
                              One big advantage of these cheap units is they are SIMPLE. They are just like the small wall chargers, just with bigger transformer and silicon, but build exactly same way. In 90 % cases only caps go bad, than you change them for japanese and you are done for next decade. Sometimes rectifier or transistor, but that's all.
                              Higher quality units may have slightly better efficiency, may have slightly lower ripple, may have somewhat more precise voltage control, but that is achieved by incredible field of dozens SMD components and complex feedback circuitry. Thus they are more expensive and when go bad, you are usually finished. Especially the modern flat units which have more glue than air inside, you cannot do anything inside even if you wanted.
                              • Pentium4
                                CapXon Be Gone
                                • Sep 2011
                                • 3741
                                And you think that yours is oscillating?
                                Obviously it's under-designed. It hasn't even been a year, and look how discolored the PCB is, and caps failed already.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4924
                                  • New Zealand
                                  #2016
                                  I wouldn't be too worried about that, it just looks like they used really old and cheap SRBP board, which starts out dark brown to begin with.
                                  -David VanHorn
                                  • goodpsusearch
                                    • Oct 2009
                                    • 2850
                                    • Greece
                                    #2017
                                    The voltage is stable on the multimeter. I don't care to make it silent. I can't tell you if it is oscillating and how much though...
                                    • ben7
                                      Capaholic
                                      • Jan 2011
                                      • 4059
                                      Some of us, like me, can hear these across the room when they are oscillating. Not very loud, but some of us have sensitive ears xD
                                      Muh-soggy-knee
                                      • RJARRRPCGP
                                        • Jul 2004
                                        • 6301
                                        I was talking about the wires on the transformer for the one on the left.
                                        (transformer wires sticking out)
                                        Arc A770 16 GB
                                        • japlytic
                                          • Oct 2005
                                          • 2086
                                          Correction: XP-360L should be XB-360L.
