Dell model L275E-01 pn: Wu142. Optiplex 755 small form factor.
  • PeteS in CA
    • Aug 2005
    • 3579
    • USA, Unsure of Planet
    Re: Dell model L275E-01 pn: Wu142. Optiplex 755 small form factor.
    Originally posted by stj
    it's getting pretty common in europe now to bypass hot thermisters with a fet/triac or relay just to save "something" or reduce heat output.
    we are under the thumb of the scum that are obsessed with carbon!!
    While I won't disagree with your assessment of the enviros, improving efficiency of PSUs in a big server-storage farm can improve the farm's electric bill, so to speak.
    Shorting out the inrush thermistor also allows use of a higher value thermistor that cannot sustain the normal continuous current: the inrush is lower in magnitude; the thermistor gets shorted out before it desolders itself or blows up. I saw the latter usage back in 1980 in which a simple wirewound panel mount resistor was used; the resistor did not survive long if the triac failed to fire, .
    PeteS in CA
    • Rainbow
      • Aug 2005
      • 1371
      The 180uF/420V cap is known to fail without any visible changes in L275E and also L235P (OptiPlex 780). Desolder it and you will see leak on the bottom.
      Then usually IC501 (TNY280PN) shorts, burning R600 (1R fusible resistor) and sometimes also F001 fuse (this should be same for L235P and L275E).
      Sometimes, PFC burns (instead of IC501 or in addition to) - Q100 (FCP16N60), D101 (STTH8S06D or BYC8-600) (this is from L235P)
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        Gud day sir. may i ask if you have the schematics of L235 and L275e you can share it with us. thank you so much.
        Never stop LEARNING because life never stops TEACHING!
        • Rainbow
          • Aug 2005
          • 1371
          I don't have any.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Originally posted by Duranitron
            thanks for the suggestion mates! i already repaired the psu by placing a thermistor sck054 and replacing the opto isolator 817B. now the psu is working perfectly and can be turn on and off. i think the relay is for in rush current protection an old 2005 design, now a days they omitted the relay and just place the thermistor. Thank you very much for the help and sharing your expertise.
            Glad you got it working, but your understanding of the NTC and Relay relationship is still wrong.
            I have drawn it here in PerCad v1.0:
            Code:
            L------NTC-------------
              \--Relay*---/
            N----------------------
            * = Relay with 500ms on-time delay
            This is used for power efficiency, I think it was Corsair that wrote it's almost impossible to attain the highest levels without switching the NTC out of the circuit.
            (Obviously a pretty expensive design, as quality high-power relays are not cheap).
              master hoarder
              • May 2008
              • 12170
              • Bulgaria
              #26
              I have drawn it here in PerCad v1.0...
              LOL Per, you almost got me with that one. Took me a moment to realize what you did there.
              • cozily
                OptiPlex 7080 Small Form Factor BIOS
                by cozily
                I have an OptiPlex 7080 Small Form Factor with the service tag 9NDV053. However, the fan doesn't spin when starting up, and the System diagnostic lights show Amber 2, White 1. According to the Service Manual, this indicates a CPU failure. But replacing the CPU didn't solve the issue, and flashing the BIOS copied from another computer results in the same error code.
                I'm reaching out to this knowledgeable community for guidance. Could this issue stem from a corrupted BIOS, or is it likely another hardware failure? I've exhausted my troubleshooting toolkit—even using a chip...
                07-21-2025, 10:32 PM
              • DenSDen
                Bios OptiPlex Small Form Factor Plus 7020
                by DenSDen
                Hello everyone!
                I have a PC that does not see either a discrete card or an m2 SSD. The integrated graphics only outputs a picture to one of the three DP connectors. Someone has already flashed the BIOS. I suspect that the BIOS is crooked.
                Please help me figure this out. I can't figure it out myself. I am attaching backups and markings.
                Thanks in advance!
                Service Tag: H9H3R34
                Express Service Code: 37578223840
                board vh0216
                04-04-2025, 09:00 AM
              • lzeta
                OptiPlex 5080 Small Form Factor Bios
                by lzeta
                Hi, I need bios file for OptiPlex 5080 Small Form Factor
                service tag JYL58B3
                I don't have the original dump because I've erase the eeprom and the usb where I've saved original isn't working anymore. I'm trying to recover it.
                12-11-2024, 03:39 AM
                DELL OptiPlex 5040 OptiPlex i3-6100 Specification for Upgrade or Repair
                This specification for the DELL OptiPlex 5040 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 5040 boardview and OptiPlex 5040 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                09-12-2024, 03:44 PM
                DELL OptiPlex 3040m OptiPlex 3000 i5-6500T Specification for Upgrade or Repair
                This specification for the DELL OptiPlex 3040m can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3040m boardview and OptiPlex 3040m schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
