UPS Battery Float Voltage Low
  • Krankshaft
    • Jan 2007
    • 2328
    So I decided to check my APC XS 900 today to see what it's float voltage was.
    The charger is outputting 26.32 volts since there are two 12 volt batteries in series divide that by two and you get 13.16 volts per battery. Or 2.19 volts per cell (6 cells in a 12 volt battery).
    Now the standby (not cyclic) float voltage recommended for an AGM SLA is about 13.5-13.8 volts. They vary slightly but as a rule of thumb those values are pretty close.
    How critical is this voltage exactly?
    Is .34 volts really going to have a noticeable affect on battery life?
    I know too low a charging voltage can cause premature sulfation. But that is just over 1/4 of a volt of deviation.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: UPS Battery Float Voltage Low
    batteries with high leakage overloading the charger?
    measure the charging current.
    had an optima red top do that on a ups.
    it was used when i got it from a car we bought for parts.
    it started a 460 ford with no problem so i used it on the ups.
    i thought i had a charger issue in my apc 650 but i noticed the regulator was real hot.
    put the red top on my automatic charger to top it off but when it hit about 13.3 it stopped climbing,current draw increased,and it got hot.
    once an agm gets abused they do this.a guy from mk battery explained it as microscopic dendrite growth through the seperator.
    • ruletero
      Acer a515-43 low battery charge voltage
      by ruletero
      Hi
      Acer A515-43
      LA-H801P
      Fail: Does not charge battery, has low voltaje on connector.
      Laptop didn't want to turn on, only charge led blinked.
      I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
      I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
      Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
      10-24-2022, 02:31 PM
    • questore
      XPS 13 9370 CMOS battery voltage always low
      by questore
      Hi Everyone,
      I have brought you a mistery item
      This laptop have come with some strange faults.
      1. CMOS battery was flat 0v
      Symptoms:
      - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
      Amp drawing was stuck at 0.005 milliamps.
      - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
      After inverstigation RTCD1 diode had a low value...
      09-30-2025, 05:47 AM
    • Mcfeetroy
      Fishing bite alarm drains battery
      by Mcfeetroy
      Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
      08-01-2025, 03:52 AM
      Battery Hookup new listing “Case 100x 3.3v 2200mah - 200x 18650 Lifepo4” for $100.00 + shipping
      I bought a case of them the battery cells are made in China the charge curve looks decent for 1 amp charging rate there is also a BMS protection board which here is the website link to them
      https://batteryhookup.com/collection...-lifepo4-cells
      Here are more of the same but the difference is that they do not have the BMS protection boards but have the tabbing on them
      https://batteryhookup.com/collection...o4-power-cells this is...
      03-09-2025, 02:30 PM
    • trepachka
      iPad Air A1475 Boot loops after replacing battery
      by trepachka
      This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
      The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
      I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
      11-08-2024, 03:17 PM
