Logisys 575W
  • etnietering
    • Apr 2009
    • 379
    Re: Logisys 575W
    There is noticeable heat stress discoloration around where the +12v rectifier goes, indicating to me that the original one was under a lot of stress, so I'd rather not use it again unless I have to. Unfortunately, the spot on the PCB for the +12v rectifier will only accommodate a TO-220 package. In that package I have the following options:
    40A/250V (what I put in)
    30A/150V
    60A/45V
    I could look through my stash of used parts for something else though...
    • 370forlife
      Large Marge
      • Aug 2008
      • 3113
      Re: Logisys 575W
      Try the 60/45 if you don't mind...wasting it...I guess you will just have really stable 12v voltages now.
      • etnietering
        • Apr 2009
        • 379
        Re: Logisys 575W
        I have a 30A/60V one that I salvaged out of an old AT unit. But I'll use the 60A/45V new one, I got 10 of them from ON for a $0.11 each...so I don't mind using it
        • 370forlife
          Large Marge
          • Aug 2008
          • 3113
          Re: Logisys 575W
          Want to borrow one of my 30v/70A parts I got from them?
          • etnietering
            • Apr 2009
            • 379
            Re: Logisys 575W
            hahaha well I got it in, and there's a change when I try to fire it up: before it would just chirp and that was it. Now, it chirps and the LEDs I put in light up for a second and the Fan twitches. So this leads me to believe that the problem was before with the 12v (both the fan and LEDs are on the 12v), and now there's a different (or unfixed) problem.
            • etnietering
              • Apr 2009
              • 379
              Re: Logisys 575W
              success! I took it apart again and noticed a solder bridge on the 3.3v rectifier. So I removed that, and now it works! Yay! So the problem was either my soldering on the +12v part, that I didn't know about, or that part itself. Hmm I didn't think having too high a blocking voltage could be a problem, but I guess I was wrong. Thanks for the help! The next upgrade will be getting a board made for my run-the-fan-off-the-standby-power circuit, and install that
              • 370forlife
                Large Marge
                • Aug 2008
                • 3113
                Re: Logisys 575W
                Sounds like it has some sort of short protection if it was shutting itself off with that solder bridge. Interesting. Did you replace the primary switchers too? If so, then you just have to do the transformer...he he he. Thats fun.
                • etnietering
                  • Apr 2009
                  • 379
                  Re: Logisys 575W
                  Nah I didn't bother replacing the primaries, they're rated for like 8 or 9A, which is far more than this piece of junk is ever going to need. And I'd be replacing them either with something that's 15 years old, or with my crazy ones from ON, and I don't want to waste them on this piece of junk....and I don't think I have a transformer that would be worth using - I think all the other ones I have are either the same size or even smaller!
                    master hoarder
                    • May 2008
                    • 12175
                    #89
                    Re: Logisys 575W
                    Good to hear you got it working .
                    I agree with 370forlife, though, it was probably the bad soldering on the 3.3v that was shutting down the PSU. I don't see why the high blocking voltage on that 12v rectifier would be a problem. Higher DC blocking voltage just means better protection in case something goes bad on primary.
                    Well either way, the original 12v rectifier was likely adequate as well. As for the PCB discoloration/burnt spots, I think that is due to the heatsink being too thin.
                    Should I try to turn it on without any of these diodes and see what kinds of voltages appear across where the diodes would be?
                    Probably not a good idea. Not sure what will happen, but there's always the possibility of the primary transistors blowing (if PWM IC doesn't see any voltage on output, it could turn pulses up on the primary transistors until it shorts them).
                    • Krankshaft
                      • Jan 2007
                      • 2328
                      Re: Logisys 575W
                      Unless you know where the feedback is coming from it's not a good idea.
                      The PWM only needs to sample one output and compensate for it if one secondary output is in voltage tolerance all of the others will be too (due to the transformer turns ratio).
                      As for measuring where the diodes would be unless you have a true RMS meter to measure the high frequency AC output from the switching secondaries you won't get the proper voltage anyways.
                      Meters that are not true RMS can only measure AC properly if it's a pure sine wave. A switcher outputs pulses.
                      • etnietering
                        • Apr 2009
                        • 379
                        Re: Logisys 575W
                        Yeah I thought something like that might happen if I were to try it...that's why I asked And I checked the soldering at least a dozen times with the original set of replacements, and they were all fine - it was only after I took them back out, switched the 12v one, and put them back in, that there was a short on the 3.3v line...which is why I'm at such a loss as to what the problem was. There are also some heat marks around the transformer - probably because it was powering a computer with two 85W xeons - that's > 14A on the 12v from the CPUs alone, assuming 100% VRM efficiency, which is not the case. I'm quite surprised it didn't just explode as soon as I powered up the computer. It actually held up pretty well (the only thing I had to do while still using it was replace the current inrush limiter), although I melted the 4->8 pin 12v connector
                        • etnietering
                          • Apr 2009
                          • 379
                          Re: Logisys 575W
                          Well I found some pictures I took of it after the first diode replacement - it looks the same now, except the middle rectifier is a B60L45G instead of a B40250TG.
                          But first, here's the new Y caps on the power socket:
                          And here's the secondary heatsink, with the new rectifiers attached, and the old rectifiers above. They are in this order: 3.3v, 12v, 5v
                          And here they are, almost visible reinstalled back into the PSU, along with all my Panasonic caps
                          • etnietering
                            • Apr 2009
                            • 379
                            Re: Logisys 575W
                            Well I took the transformer out of my 500W aspire and put it into my logisys, and my first transformer surgery was a success Here's some pictures:
                            Here's the old transformer (yellow) next to the new one (blue):
                            Here's the logisys without it's main transformer - more heat marks on the 12v line:
                            And here it is with the new transformer. There's about 1mm of clearance between it and the fan case...
                            I think now it might be able to actually put out the 330W it's rated for, and maybe more beyond that.
                            • Newbie2
                              • Sep 2005
                              • 885
                              Re: Logisys 575W
                              Beautiful work!
                              Now that power supply looks like a decent backup power supply that should last for a while.
                              My gaming PC:
                              AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                              ASUS M4A77TD AMD 770 AM3 Motherboard
                              PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                              G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                              TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                              WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                              ASUS Xonar DG 5.1 Channel PCI sound card
                              Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                              Antec Three Hundred Mid-Tower Case
                              Microsoft Windows 10 Pro 64-bit
                              Microsoft Windows 7 Ultimate SP1 64-bit
                              • larrymoencurly
                                • Oct 2004
                                • 960
                                Re: Logisys 575W
                                Originally posted by Newbie2
                                I don't think the bridge rectifier even needs a heatsink, all power supplies I've seen don't have one. His Dr. Pepper can heatsink is a little extra.
                                My 300W Delta has a small heatsink attached to its rectifier, but how does it help when it's barely larger than one side of the rectifier package?
                                • Wizard
                                  • Mar 2008
                                  • 2296
                                  #96
                                  Re: Logisys 575W
                                  This plate if it is copper or aluminum does help to spread heat to larger area instead of
                                  relying on the plastic/glass particle matrix to dissipate heat to air is smaller due to poor
                                  thermal conductivity.
                                  Cheers, Wizard
                                  • 370forlife
                                    Large Marge
                                    • Aug 2008
                                    • 3113
                                    Re: Logisys 575W
                                    I know, I would love to hook up my yuelin to a load tester and see how far it goes.
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      #98
                                      Re: Logisys 575W
                                      good enough if the fan is running.useless if not.adds just enough surface area to do the job with the airflow from the fan.
