Dead Hp Compaq PSU
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Dead Hp Compaq PSU
    I just picked up a Dead little Hp Comapaq d530 unit for free. Its has a P4, 2.66 Mhz CPU, 2 Gigs of 333mhz dual channel ram, a Barracuda 7200 rpm HD, and a Sony CD/RW DVD/ROM. All this stuff is shoved into one of those Small Form Factor cases. The PSU is all screwed up. Something let all the "factory filled" smoke out for real. I would think that it took a lightning strike. Upon inspecting the PSU I found a few burnt up things. There is a little IC that has exploded. At least thats what it looks like because a major portion of it is just gone! There is also a diode that looks to be fried, and there are two or three other blacked parts near it. The top side of the board also has a few black spots on it. I didn't pull it apart to see the bottom "trace side" of the boards as of yet.
    Well I took a regular P4 PSU, and plugged the system up. I also had to plug in the fan wire going to the burnt up PSU because the system gave me the "PSU Fan Not Working" warning on the boot. As it turns out, that little Hp Compaq screams compared to my Dell, 2.4 P4. My test was fair too. Each PC now has one gig of the ram that came with the Compaq in it. I think my Dell must be sick to have gotten shown up so badly by that little compaq. Oh I also put all the programs on the compaq that I use on the Dell. The only difference is that the Dell is on Xp Home, and the Compaq is on Xp Pro. I want to fix the little compaq up for my wife. I can do this three different ways. One, Maybe the smoked PSU can be fixed. Two, I could get a new PSU, or three, I could recase the compaq in a regular P4 Case. The compaq has a queer PSU to say the least so I bet a new one would be expensive. The old one may be beyond all hope of getting fixed. If I were to recase it in a regular case, how do I get around the CPU fan not working warning? Now when I say "fix" the old PSU I'm not fixing it. One of you guys will get that job for real. What do you good people think I should do? If you want to look up the PSU here are the numbers off it. Its a 185 watt unit and says P/N 308439-001. Replace with Compaq Spare 308617-001.
    Mark Twain
    John Paul Jones
    Rod Serling
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: Dead Hp Compaq PSU
    Those HP compaqs are pretty fast. Most have Asus motherboards.
    I'm on a dell dimension 4600 right now with a 2.66ghz p4, and it is slow. Dells from this era are stable (if it has good caps as this does, about 4 years of non-stop running), but slow for some reason. This thing is terrible with games, a 1.4ghz p3 with 256mb of ram and a fx5200 would run like farcry (18-20 fps) on low settings, this thing has a 2.66 p4 with 512mb ram and a fx5200, and it barely (5-6fps) runs farcry on the lowest settings.
    • yanz
      • Nov 2004
      • 910
      I would choose option number three : recase the compaq in a regular P4 case. Because, that will be cheaper and easier in my opinion.
      As for the "PSU Fan Not Working" warning on the boot, i think you can easily fix it by using a three wire fan (with rpm sense) and plug it into ur mobo. Just let the mobo think there is a psu fan there (with rpm sense) and all will be smoothly going.
      But maybe others have different opinion..
      • Scenic
        o.O
        • Sep 2007
        • 2642
        @ yanz: thats exacty what i did with one of those HP boards..
        put everything into a regular ATX case, wanted to boot it up.. psu fan warning *argh*
        popped the PSU open and got the 2pin fan out, used a 3pin 80mm fan and soldered + & - to the original fan's connector (inside the PSU) and put the rpm sense line (yellow one most of the time) out of the PSU case and plugged it into the board. works perfectly fine and the PSU fan is still temp. controlled
          master hoarder
          • May 2008
          • 12175
          I agree with Yanz and Scenic, it just might be easier to get a new case and PSU.
          If the blown HP PSU is a Delta or Lite-On, maybe post some pics as it could be worthwhile fixing it. If not, maybe you could use it for parts - those units always have plenty of pi filters and coils and good input capacitors.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            iirc that is one of the units that was poured full of that nasty brown glue.
            it becomes conductive and BANG!!
            just recase the system and you will be fine.
            i see lots of these and if you get them before they blow up and clean out the glue they will be ok too.
            • Junk Parts
              Court Jester
              • Jun 2006
              • 8953
              Yes Kc8adu I'm going to go with the recase on this unit. This would give me better cooling, more power, and room for more drives too. I just may try to get around the PSU fan warning by wiring up a simple three wire case fan, and feeding the control signal back to that PSU rpm header on the mobo. I can get a Dell Dimension 4550 case for free right now from my buddy. I wonder if I can get this Hp Compaq mobo to fit in the Dell case???? I have a "back up" Dell PIII under my desk but I do not wish to bust it up for this repair project. That old PIII has more heart than all of this newer junk that I have for real!
              Mark Twain
              John Paul Jones
              Rod Serling
              • Junk Parts
                Court Jester
                • Jun 2006
                • 8953
                Ok I have the Compaq all broken down in pieces now. I'm putting it in a junk raidmax case that I had here. Need to get some nuts for the four screws that hold the CPU cooler bracket to the mobo. I also need to find a few more brass stand offs for mounting up the mobo in the case. The fun part as always will figuring out the front pannel USB's, headphone jack, power button, and indicator lights. I'm going to use an older ATI All In Wonder Video card in it now that the AGP slot will have a full sized bay to play in. I wish this flu would go away. Its kicking my ass. Taking that PC apart was all that I did yesterday, and it took me all day! It should have taken me twenty minutes to do that job. I guess I need so beer or something....
                Mark Twain
                John Paul Jones
                Rod Serling
                • kpataska
                  • Aug 2009
                  Cut off the P9 connector from the old 308439-001 PS, connect it to a 1k resistor and put the connector on the motherboard. On a cold boot, it will not issue the fan error. It does, however, on a warm boot. Don't know why...
                  I've also heard that just dead shorting that connector works as well. Never tested it.
                  I brought a D530 to life by using a surrogate ATX power supply and the 1k resistor trick, until I got my mitts on a replacement.
                  Hope this helps!
                  • Northeastern292
                    • Jul 2009
                    • 15
                    Personally, I'd find a PSU on eBay and throw that in, but used PSU's are nothing but trouble sometimes. Each has an advantage and disadvantage.
                    • lucky13
                      • Aug 2007
                      • 412
                      185 watt? Talk about under-rated.
                      Can you plug a fan to the fan connector on the mobo that used to have the 2 wires coming from the 185 watt P/S? I would think that would be suffice to trick it.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        my dad's d530 has a delta psu. the model number starts with dps.
                        sigpic
                        (Insert witty quote here)
                        • KeriJane
                          Mac Enthusiast
                          • Sep 2008
                          • 681
                          Hi Lucky
                          Actually, 185 watt isn't under-rated at all. It's adequate to power most reasonably modest systems.
                          The big problem is Over-Rated power supplies. The ones that should be marked "185w" but are instead marked "300w", "400w" or even "550w".
                          Over-rated junk leads people to believe that any computer needs at least a 300, 400 or 500 watt PSU just to operate and 1kw plus if you're going to get serious.
                          It just isn't so. Check the various online PSU calculators.
                          I'll take an honestly rated 185w PSU any day over a fraudulently-rated anything.
                          I'd say recap because it's probably a well-engineered unit and worth saving.
                          Good Luck,
                          Keri
                          The More You Learn The Less You Know!
                          • lucky13
                            • Aug 2007
                            • 412
                            Originally posted by KeriJane
                            Hi Lucky
                            Good Luck,
                            Keri
                            Hi Keri,
                            I forgot to add the
                            So it should read...
                            Of course I know the old fashion way of rating them....not the "mine is bigger than yours" syndrome.
                            Persoanally I judge p/s by their weight; the heavier the better
                              HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                              This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                              09-12-2024, 03:44 PM
                              HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                              This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                              This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                              09-12-2024, 03:36 PM
                              HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                              This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                              09-12-2024, 03:30 PM
                              HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                              This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
