Enermax PRO 82+ 525W repair
  • Syn-fi
    • May 2013
    • 29
    Re: Enermax PRO 82+ 525W repair
    got it sck054
      master hoarder
      • May 2008
      • 12175
      ^ Yup, SCK 054 is correct.
      Yours blown too? If yes, check the big 400V caps on the primary. Could be open-circuit or low capacitance or high ESR.
      BTW, looks like I still haven't updated this thread on the results I had with mine after removing the APFC circuit and running 2x 200V caps in series... but in short, I can't draw full power from the PSU without it shutting down. IIRC, it was shutting down somewhere past 200-250 Watts power draw on the AC side... so perhaps around 160-200 Watts of draw on the DC side, accounting for efficiency and whatnot? Therefore, the APFC is needed for full power output. Otherwise, if the lower power rating will suffice, the two cap APFC removal mod does works just fine.
      • PeteS in CA
        • Aug 2005
        • 3586
        • USA, Unsure of Planet
        Inrush limiting thermistors are like fuses. They blow if something else draws excessive current.
        PeteS in CA
        • nmbb
          Can not find Model/Value of Thermistor.
          by nmbb
          Machine: Autoclave.
          Brand/Model: SANYO MLS-3780
          Manual: (Sorry search option not working on this PDF)
          Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
          06-02-2022, 05:55 PM
        • Use2bavolvo
          Magic chef oven - thermistor ref voltage issue
          by Use2bavolvo
          I am having an issue with my wall oven temperature control is ~180f out of spec. The thermistor is measuring correctly but I noticed the ref voltage appears to be off. With the thermistor wires attached it's reading ~3.4vdc with the thermistor disconnected it's around I9.8vdc. my understanding is the temp is read off the resistance from the thermistor which leads me to believe the issue is with the ref voltage.
          Another observation is the temp setting and readout at lower temps is way off meaning the oven thinks room temp is 300f and bake relay doesn't engage unless temp setting...
          01-19-2023, 01:32 AM
        • fab13
          Thermistor exploded in two when turning on ps4 fat
          by fab13
          Hi there,
          I have a fat PS4 with the fuse (5a) of the power supply which blows with each power on and there was a loud snap in the power supply and again the same problem after replacing the fuse.
          I did not find a short circuit
          The component that broke in two is an SCK 084 thermistor (See photo)
          and measured at 11 ohm
          So far I haven't received a thermistor.
          Do you think that if I replace the thermistor and the fuse it should go away, because I have the impression that there is a strong current demand as soon as you press...
          11-05-2022, 06:29 PM
        • Rekoo1997
          Ambient thermistor out of range
          by Rekoo1997
          dell latitude 5570
          LA-C841P
          i am check ph601
          ph602
          ph603
          ph604
          ph605
          ph1302
          all is ok and flash bios
          and didn't fix
          Can someone please tell me where to find this sensor and how to correct the problem?
          04-21-2025, 10:35 AM
          Enermax Liberty ECO 400W [ELT400AWT] - from scraped to serviced
          by momaka
          Remember this pile of junk electronics I got last year? Well, that's where this Enermax Liberty ECO 400 Watt PSU came from. Like I mentioned, it had cut cables and many bulged caps on the DC output side. I stripped a few cables and did a quick temporary recap with whatever junk (but still reading OK) caps I could find, then performed a basic power test – the PSU passed. Thus, I knew I'd eventually go around to repairing it. One year later and we're here.
          First shown is the label below, so anyone reading can see what PSU we're dealing with here.
          02-15-2021, 01:05 AM
