Replacing capacitors
  • ceramic
    • Feb 2009
    • 11
    When replacing a capacitor, does the capacitance have to be strictly the same? I know the voltage doesn't necessarily have to be the same but the new one has to be higher than the one you are replacing. So for instance, can you replace a 680uF 10V capacitor with an 820uF 25V capacitor (in case that's the only one you have handy and don't have time to order the same rating as the original). Thanks.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Replacing capacitors
    It depends on what you are working on.
    If cap is part of a tuned circuit then uF may be critical.
    For filter caps on mobo's not so much.
    As long as you don't lower ESR too.....
    Going up a bit is okay [and may be an upgrade].
    Going down 20% should be okay but definitely don't lower ESR too when going down.
    Most mobo caps are +/-20% on the uF spec anyway so one size down is usually still in the 20%.
    uF tends to go down as they age so new cap at lower uF will be like old cap as aged.
    Only concern going down like that is new lower uF cap's uF goes too low as it ages.
    Even that -usually- isn't a problem because -usually- mobos design tolerance is wider than caps rating tolerance.
    Mann-Made Global Warming.
    - Dr Seuss
    • i4004
      • Oct 2006
      • 2029
      i would say it depends where it is.
      if it's output cap, then such increase probably won't hurt.
      if it's cap that is a passive component for some ic, i would stick with exact value.
      but given it's pretty high value, it's probably output, so you should be fine.
      if in doubt, post pics and i'll tell you is it output cap or otherwise...
      • ceramic
        • Feb 2009
        • 11
        What if you are working a power supply for a DVD player?
        Also, is there a way of finding the ESR value without buying those expensive ESR meters.
        • i4004
          • Oct 2006
          • 2029
          for dvd player power supply: on primary try to be as close as possible, on secondary it's passable to do increase you mention.
          not unless you make one...
          for example
          https://www.badcaps.net/forum/showth...hlight=manfred
          but i wouldn't say anatek blue esr is awfully expensive as a kit..
          http://www.anatekcorp.com/blueesr.htm
          then again it's not very cheap either.
          but for one dvd player repair you don't need esr meter, really...just follow what i said above.
          • ceramic
            • Feb 2009
            • 11
            for example
            I believe its the secondary side. Couldnt attach pic cos its too large but i'm sure i'm right so no need.
            Thank you so much.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Tuned circuits usually are used in signal processing.
              Not likely to have such an issue in a power supply section of anything.
              Without a meter the best way is to find the data sheet for the old caps.
              Not always possible but often is.
              What are they?
              PCBONEZ - Member, i4004 Ignore Club.
              - Dr Seuss
              • i4004
                • Oct 2006
                • 2029
                well in psu you can have just slightly changed capacitance(not even esr) on primary side cap blowing the stabiliser(for b+ flyback supply) of a pc monitor...
                yes, those usually go on dvd-players...and vcrs, etc.
                feel free to change those as intended.
                if still in doubt, primary is usually marked "hot" and has some sort of marking(drawn lines on the soldering or component side) to distingush it from secondary...
                be carefull with polarity, minus marking on cap should match those of previous cap.
                reversing it could lead to some smoke and simillar pyrotechnics...
                • ceramic
                  • Feb 2009
                  • 11
                  thanks for the tip and warning. yeah I have fried a few circuits by not considering the polarity. I've learnt that lesson now for good .
                  • ceramic
                    • Feb 2009
                    • 11
                    finally got it working....no problems so far. hope it stays that way
                    Thanks for all your help!
                    • yuzupatogik
                      Help with replacing Capacitors on Altec Lansing ATP 3
                      by yuzupatogik
                      I have this old (2004?) Altec Lansing ATP3 and i would like to replace the capacitors. I have identified 34 out of the 36 of them as Samxon GR of various capacities and voltages.
                      I can't find datasheets for the Samxon in any of the following variants:
                      10000uF 25 v - this one i really want to replace because i suspect it is what causes a dull hum regardless of the volume knob position or if the source is plugged in. I am eyeballing the Rubycon 25PK10000MEFCGC18X35.5 for this purpose. So if i pay a 10x the price part for shipping i might as well go ahead and...
                      02-14-2025, 04:11 PM
                    • quickname
                      Cyberpower 1500AVR UPS repair
                      by quickname
                      I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                      I decided to verify that the batteries were...
                      11-12-2023, 09:57 AM
                    • dragon3x
                      by dragon3x
                      power on.
                      Here are some examples :
                      switching supply area).
                      than 6.3 V.)
                      03-21-2025, 02:46 PM
                    • Agent24
                      Dick Smith Q-1760 linear power supply filter capacitor question
                      by Agent24
                      I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                      It has at least one problem.
                      The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                      I have already ordered a replacement potentiometer, so that's not an issue.
                      Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                      All are CapXon...
                      10-21-2025, 05:39 PM
                    • Noodneek
                      Replacing all the caps on the BenQ SW2700pt's power board didn't help...
                      by Noodneek
                      My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
                      I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
                      08-30-2024, 12:52 PM
