Re: Converting Spotlight Power Supply
in plain language, your going to have to deal with the optics to get the beam angle you want.
I know its long obsolete tech with plenty of heat dissipated. Speaking about efficiencies, can you guys suggest a modern cree led 50W spotlight at low cost? I've small cree or similar flashlights brighter than this spotlight, but larger cree lamps seems to be on a costlier side.
A "50W cree" will dissipate just as much power (heat) as a 50W incandescent.
What you really want is an LED that throws as much LIGHT as the 50W incandescent/halogen -- but at a much lower power dissipation.
And, this is where things get tricky... are you concerned with "total light output" OR light at a specific point in space? (SPOTlight)Leave a comment:
@ stj
Thanks for pointing to this nice recovery charger.Last edited by sambul83; 07-25-2018, 12:00 PM.Leave a comment:
What's changing is the POWER. And, that translates into heat.
Leave such a lamp on for any length of time and I suspect you'll find the acrylic "lens" turns to mush. Plastic parts in and near the "socket" (I've not examined this particular lamp) could also be compromised.
We ALL know how hot light bulbs get -- having each tried to remove one before letting it cool down, completely!
(Note to OP: don't touch bulb glass -- even while cool -- with your fingertips as the oils from your hand will compromise the bulb. Wear gloves or use a clean tissue/cloth)Leave a comment:
And what can possibly happen with the jack at 12V instead of 6V - melting is not likely I guess?Laptop 12V power adapters are seemingly all switching converters?
The bigger issue might be the effects on the "lens" (bulb cover) as the doubling of POWER being dissipated in the lamp increases. Light bulbs are inefficient devices. Most of the power dissipated in them is HEAT, not light. Chances are, the type of plastic chosen wasn't selected for its thermal characteristics BEYOND what the original bulb was intended to produce.Leave a comment:
different chemistry.
if you really want to mess with lead-acid batteries then look at a B6 clone like this:
https://www.banggood.com/IMAX-B6-Min...p-1202402.htmlLeave a comment:
Wouldn't adjusting the resistor value on that board, soldered in sequence now with the diode, and shorting the diode allow to use 12V power adapter instead of 6V? And what can possibly happen with the jack at 12V instead of 6V - melting is not likely I guess?Laptop 12V power adapters are seemingly all switching converters?
I can look at a 12V lamp, but current lamp seems soldered now to the wires in a way hard to get to. I couldn't shake it by hand in its sit after removing the holder, and using pliers on the lamp seems prohibitive. Since you mentioned a "dead" battery, I wonder if I can try recovering the dead lead battery with this smarter Nitecore charger? I know, it doesn't support SLA batteries, but what can happen if I try? Won't provide enough voltage at 7.9V to fully charge, but at least may recover the battery to the initial state, from which it can be charged by the supplied lamp charger? Or the charging cycle for lead batteries is totally different?Last edited by sambul83; 07-25-2018, 08:02 AM.Leave a comment:
plastic melts, wires heat up, tracks burn - and most barrel connectors are only rated for a couple of amps.
the ones on laptops are constructed differently - even the plugs are different and more expensive.Leave a comment:
... and then the plastic melts (don't go up in watts....)Leave a comment:
I guess I need to buy a 6V 4A adapter now.
Is there a way to use a 12V adapter by modding the board, since I've a few with 2.5-3A rating, so they will heat up a bit at 3.5-4A but still working?
A smarter approach might be to see if you can find a (mechanically equivalent) replacement bulb that is rated at 12V (instead of 6V). I have numerous "oversized" lights and use them so rarely that the (rechargeable) batteries are almost always "dead". So, I've taken to just making sturdy (heavy gauge to reduce IR drops over these longer cables) coiled cords with "DC power plugs" (I have no idea what folks now call "lighters" in cars) so that they can be powered from such an "outlet". I've installed additional "outlets" in various places (under hood; rear of vehicle; etc.) to make it convenient to use these lamps. (I also have 12V "power packs" that I can sling over a shoulder for those times when I need to carry such a lamp with me).
What you will then have to worry about is the amount of heat thrown off by any larger lamp that you choose to fit in its place (e.g., you may end up with a 50W lamp instead of 25W -- watts == heat). I have a few "flashlights" that throw enough light (heat) that you can tell if they are on -- with your eyes closed -- just by holding your hand in the beam!Leave a comment:
Only if you also add a switching converter.Leave a comment:
Just confirmed using an old Buffalo router power adapter 5V 2.5A. Both lamps are lit now with diode-resistor combo short and also the 2 jack terminals short. It draws 3.5A current, but initial voltage 5.9V drops to 5V, so the lamp is not so bright. I guess I need to buy a 6V 4A adapter now. Is there a way to use a 12V adapter by modding the board, since I've a few with 2.5-3A rating, so they will heat up a bit at 3.5-4A but still working?Last edited by sambul83; 07-24-2018, 06:15 PM.Leave a comment:
@ Curious.George
Thanks for the explanation and suggested solution. I'm working on it in free time.Last edited by sambul83; 07-24-2018, 08:58 AM.Leave a comment:
why dont you just draw a diagram of the wiring and board.
btw, your not powering that lamp with the original charger - it will burn up the windings.Leave a comment:
I'm a little confused, how this PCB normally works? Once connected to a power adapter (the bad one with small transformer), it starts charging the battery. Once the battery charging current drops near 0, the charging circuit then drops slowly, while the battery (only?) supplies voltage to the lamps?
One is the battery powering the lamp (and the little LEDs?). This consists of the battery, the switch/trigger and the lamp.
The other is the charging circuit. It consists of the external transformer, a diode (to ensure "DC" of the correct polarity flows towards the battery) and a ballast resistor to limit the current into the battery.
The voltage loop around this circuit indicates:Vtransformer -~0.7V (diode) - Ibattery*Rblue = VbatteryRearranging this:
Ibattery * Rblue = Vtransformer - 0.7V - VbatteryThis indicates that the current flowing into the battery ("charging current") is
Ibattery = (Vtransformer - 0.7V - Vbattery) / RblueI.e., as the battery voltage climbs, the current flowing into it falls.
Ideally, the battery would eventually charge up to (Vtransformer - 0.7V) -- at which point the Ibattery would fall to 0 and charging would stop.
But, Vtransformer is significantly higher than the battery chemistry will ever allow Vbattery to attain. So, there will always be some Ibattery flowing into the battery. This, eventually, "cooks" the battery because it presents as "heat" inside the battery.
That's why these sorts of charging schemes suck.
So, if I short the diode and resistor combo, what should I do with black and red wires hooked to the (former) battery?
Is voltage to the lamp supplied only through the battery wires, and not by the diode - resistor combo, even if they are short? Or both sources supply voltage to the lamp, and while charging battery voltage raises, current through the diode to the lamp drops? But if the lamp is also fed by the diode circuit, why would the battery discharge so fast?
If you'd prefer, you could wire the external power connector to the battery connections directly. But, if you trace the foils, I suspect you will discover that my "patch" already does this with less work.Leave a comment:
A lot of these cheap plug in chargers, in order to prevent damage of the charging circuit of the large lamp load, use a 3-wire switched barrel connector that cuts off the load when it's plugged in. You'll have to defeat that switch.Leave a comment:
The rating 25W for for this spotlight lamp I found on the web. Its not seen anywhere on the lamp, so I don't know if its accurate. I'm a little confused, how this PCB normally works? Once connected to a power adapter (the bad one with small transformer), it starts charging the battery. Once the battery charging current drops near 0, the charging circuit then drops slowly, while the battery (only?) supplies voltage to the lamps? So, if I short the diode and resistor combo, what should I do with black and red wires hooked to the (former) battery?
P.S. I followed your suggestion, but current through VOM stayed at 0. Then I short 2 terminals as shown on the pic below. Side lamp gets lit, but when switching to the main lamp, it didn't lit. I suspect, the current fed by the original adapter is too low for the main lamp, or the diode get turned into a "blown fuse" for the main lamp as the current raises? Will try to find the right adapter 6V 4A tomorrow and check again. If keeping it short like this and it works, would I need to verify or change anything else? I guess still need to short the diode-resistor line?Last edited by sambul83; 07-23-2018, 10:28 PM.Leave a comment:
It also needs to be of the same polarity (which appear to be center positive, barrel negative) and (somewhat) "regulated" -- not just a "transformer with a bridge".
I just need to rewire the board to hook it directly to the lamps through the existing jack without charging a battery. An suggestions namely on rewire, since I don't won't to spend more on this old spotlight?
So, to act as a battery eliminator, that ballast resistor needs to be bypassed as it will otherwise represent a higher output impedance for the "power supply" (which means less power available to the lamp).
The diode ALSO needs to be replaced as it is probably just a 1A device and the lamp will want to pull several amps through it -- turning it into a (blown) fuse!
~25W = 6V * 4.16A
Even if you fudge the lamp rating and the battery voltage, you're still well above what a 1A diode would be comfortable passing.
You can verify this BEFORE modifying the PCB: get a VOM and set it to the 10A scale (usually, this means moving the "+" lead to a separate input on the meter designated for 10A measuements). Connect the meter across the diode+resistor combination (anode of diode and "battery end" of the resistor).
Plug in power adapter and you should see that ~4A bypassing those components by flowing through your meter. The lamp should light, etc.Leave a comment:
they are junk, just a poor battery, a tiny transformer to charge it, and a motorbike headlamp.
i only did what i did because the case was nice and it had a big reflector - bigger than this one.
and i had all the crap laying around doing nothing.Leave a comment:
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by Gust zhangI have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
- Loading...
