Re: Converting Spotlight Power Supply
You know... that 2Ah battery and that 25W halogen lamp, I would only expect it to last maybe 20 minutes anyway, and that's with a new battery...
... just to reset people's expectations...
You need a 6V PSU that can supply 4 amperes. Else you will need a battery that has low enough impedance to supply that 4 amperes (which that 6V 2Ah battery can do.)Leave a comment:
@ kaboom
I have another 6V 2A adapter with the same plug size. I just need to rewire the board to hook it directly to the lamps through the existing jack without charging a battery. No such batteries on Aliexpress either, and they won't hold the charge for a long anyway, so the lamp was bright only for a short time on a battery, and then faded. An suggestions namely on rewire, since I don't won't to spend more on this old spotlight?Last edited by sambul83; 07-23-2018, 06:54 AM.Leave a comment:
i actually adapted one of these many years ago to use a compact flourescent lamp in the front, driven by the guts of an amergency escape sign in the back.
(charger/invertor + "C" nicad pack.)Leave a comment:
check ali-express for the battery, but be warned - most of these lamps cost less than a decent battery.
also the average life of a sealed gel-cell is 2-3years only.
(with correct charging)Leave a comment:
You can't do this with the adapter you have now. It's not even remotely adequate.Leave a comment:
Is your above advice related to improving the charger? But I don't have a reasonably priced battery for it. Can you suggest, how to rewire the board to power the lamps straight from the power adapter?Leave a comment:
Even under load, this one's 3v too high!
A 7806 with a 1N4004 elevating the common leg (setpoint 6.7v) with a schottkey in series to batt + will do. The max charge voltage will be ~6.3V. Another 4004 in the common leg will raise standby voltage to ~7v; one schottkey and one 4004 will give ~6.7v.
The buck-converter equivalent is an option for reduced dissipation.Leave a comment:
The 6V 4Ah battery won't fit for sure, its longer and somewhat bigger. I'm looking for "no battery" solution now.
I wanted to reuse the existing jack that is firmly mounted in the plastic case and is preferred to a 2nd standalone jack wired to battery terminals. I just need to figure out how to disable the charging circuit without affecting other functionality like switching btw front and side lamps, red power led, and a lamp handle power switch. Its likely a very simple rewire, I'm just not good enough in PCB schematics to figure it out, but can solder easily if someone suggests required changes.
I wonder if I can simply short the former battery wires to the existing power adapter jack contacts on the board? Since the 6V 2A power adapter will provide 6V, the charging circuit may stop charging the "battery" thinking its fully charged, and the lamps will be powered by the adapter via the existing jack, with all switches working. How does that sound?Last edited by sambul83; 07-22-2018, 07:52 PM.Leave a comment:
that charger killed that SLA battery. They just gave you the cheapest transformer based dumb charger there is. Look at the dimensions of that battery. Maybe a regular 6V 4Ah will fit? I think it is the same length and width, but I can't see the depth. And don't use that charger anymore, or you will kill the next battery too, because the charger does not stop charging the battery, hence a dumb charger.
If you want, just wire a 6V PSU to the terminal where the battery was. You saw the 18V on that charger, because it wasn't loaded. As you load it more and more, the V will drop.Last edited by CapLeaker; 07-22-2018, 07:25 PM.Leave a comment:
i have seen those with split open batteries, the charger is shit and kills the pack.Leave a comment:
Thanks for the battery hint, though its too costly in Canada for the task, like CAD45 shipped. And if I use 3W led module, I'd need to replace the internal battery charger with some different board? There might be a problem with holding the 3W module in place or cooling it well.
I prefer to power the front and side lamps directly from a 6V 2A power adapter I have, and don't use any battery. Would that be the right spec adapter, and how should I rewire the existing board? I can post more pics if the board layout is unclear.Last edited by sambul83; 07-22-2018, 03:35 PM.Leave a comment:
Powersonic PS-621 SLA should be a fit. It seems to be fairly readily available. Remember it's a 6V 2Ah battery pack. That 'h' is important.
Power adapters for lead acid charging tend to be really crappy resistive drop diode halfwave rectifier. Except if you leave it charging, yes it will kill the battery eventually. However they work fairly well for a while and is very cheap...
I don't think you can use that wall wart to light the lamp. The wall wart cannot supply enough power by itself - it needs the battery as a "capacitor" - you have to get a much beefier power supply to light the bulb. Even a 6V 2A power adapter is too weak, you need a 4A power adapter.Last edited by eccerr0r; 07-22-2018, 02:56 PM.Leave a comment:
Here is a thought
Use a one to three watt LED module where the front lamp is there now and use 18650 or 26650 batteriesLeave a comment:
I've an old Canadian Tire 37-9452 Halogen Spotlight, which seems to have 2mln candle H3 6v 25W halogen lamp, powered by lead battery SD620 6v 2Ah (cycle 7.25-7.45, standby 6.8-6.9 Yuyao SanDing Electric Ltd, size 3x1.85x1.5 inch), which is charged by the power adapter TL-9B 9V 300mA.
The battery is now dead, and I can't find replacement of the same size that would fit inside the Spotlight. Can you guys suggest & link a suitable battery model? May be using Li-Ion battery will be the best choice, but which one and how to charge it regularly without the Spotlight disassembly, as the internal charger is very basic and likely won't do it?
Alternatively, I'd use it without a battery, by powering directly from a 6V 2A power adapter, connected to the same female connector on the Spotlight. The question is, how to modify the PCB schematics to preserve all switches functionality (side/main lamp switch, handle lamp On/Off, red power led), but power the lamp directly? Current PCB layout only seems to charge the battery, which in turn powers the lamp if there is any remaining charge in the battery.
Interesting is, the battery is 6v 2A, but the power adapter used is 9V 300mA, and in fact its idle voltage is 18V DC as measured by a multimeter. Why is that?Last edited by sambul83; 07-22-2018, 01:54 PM.Tags: None
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by CMCMHello Everybody,
Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
The outputs marked 12v and 20v are all measuring only 1v.
The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
The capacitors physically look clean (no bludgesor leaks) and... - Loading...
