Hot Tub Power Supply - In Need of Comparable Relay
  • grimacelord
    • Jan 2017
    • 380
    I have a power supply board to a hot tub that a customer brought in to me. He says that one of the relays on it is bad. He can hear it click and it does appear to be damaged visibly. I am having trouble sourcing the part because everywhere I have looked is out of stock due to the part being obsolete now.
    I was wondering if anyone here could recommend a substitute that would work. I'll give you all of the info I have on it.
    Part Number: ALF1TF12
    Datasheet: https://cdn.badcaps-static.com/pdfs/...35596d7749.pdf
    Contact Arrangement: Form 1 A
    ) Compressor load: 20A 250V AC
    2) Inverter load: 20A 100V AC,
    10A 200V AC
    2. High insulation resistance
    • Creepage distance and clearances
    between contact and coil;
    Creepage Min. 9.5mm
    .374inch
    Clearance Min. 8mm
    .315inch
    • Surge withstand voltage: 10,000V
    I appreciate any help I can get. Thanks.
  • R_J
    • Jun 2012
    • 9582
    Re: Hot Tub Power Supply - In Need of Comparable Relay
    https://www.digikey.com/product-deta...2633-ND/645563
    Digikey # 255-2633-ND Mfgr# ALF1T12
    Or drop the (f) and mouser also has it, none of the datasheets say anything about the (F), so what the F
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8297
      lol
        'F' is the UL Class F insulation.
        I.E.:
          • Jul 2011
          • 6059
          I.E.:
          Thanks for posting this information
          • grimacelord
            • Jan 2017
            • 380
            I.E.:
            Thanks guys. So even without the UL Class F, should the relay you linked me to work R_J? Budm?
              • Jul 2011
              • 6059
              Maybe
              It might not last as long as would ( F ) type one
              • R_J
                • Jun 2012
                • 9582
                I see no reason why it would'nt, It does appear to be Coil insulation class F. UL Class F
                I don't see what choice you have if the original part is obsolete. Does the board have a layout where an alternative type of relay could be installed?
                • grimacelord
                  • Jan 2017
                  • 380
                  Just wanted to report back -
                  I ordered the relay suggested and it worked. Successful repair. Thanks again, guys! This forum is the best.
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                    03-31-2024, 02:12 PM
                    Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                    I was working on this CNC machine today found no keyboard functioning no control relay powering on
                    The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                    Found shorted diodes on main controller relays there are 3 of them that...
                    01-07-2023, 05:43 PM
                    07-01-2024, 06:34 AM
                  • JimBanville
                    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                    by JimBanville
                    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                    09-13-2023, 07:21 AM
