Mackie mixer power supply no power
  • garrymc123
    • Apr 2010
    • 336
    • United Kingdom
    Hi, Guys, I got a mixer for repair and the problem was no power on the mixer I have removed the power supply and on checking components I found that D4 is an SB360 diode checking it with a multimeter on diode mode I only get 0.189 on the forward voltage but according to the datasheet it should be 0.74 could this be the problem ..thanks in advance
    Your never to old to learn
    • 31047
    Re: Mackie mixer power supply no power
    that's a schottky diode, they always either bounce or read about 160-180 on a meter.
    keep looking.
      0.74V at If of 30A, your meter only putting out in mA. look at the graph of Vf VS If.
        We need good clear straight shot of the WHOLE top and bottom side of the board.
        What Voltage testing have you done so far at various points on the board?
          • Jul 2011
          • 6040
          Dose this power supply have a IC chip that 4 pins or more on one of the heat sinks if it does what is the part number
          I would be looking for a switching regulating IC chip of some sort
          Do you have any voltage on the row capacitors on the left hand side of that board
          Be careful when measuring the voltage on those capacitors
            BTW, it is Vf @ 3.0A
            • garrymc123
              • Apr 2010
              • 336
              • United Kingdom
              Hi there thanks for all the info I understand now about the diode. I will upload more pics very shortly. I haven't had a chance to do a voltage test as I need to make a cable with clips on it to connect it to the mains I only did a quick check with a multimeter on the diodes I will do it tonight with power applied... Thanks in advance
                • 31047
                replace c9
                • garrymc123
                  • Apr 2010
                  • 336
                  • United Kingdom
                  Thanks, stj for your info can I ask why you suggest replacing capacitor c9 ..Thanks
                    • Jul 2011
                    • 6040
                    Because that could be the start cap for switching regulator IC chip I was talking about in an earlier post
                    It might be surface mount IC chip that is on bottom of board
                    What is the part number for U100
                      • 31047
                      exactly, first suspect in a psu that wont start is the startup cap.
                      • garrymc123
                        • Apr 2010
                        • 336
                        • United Kingdom
                        Cheers guys the part number for the ic is ob2269cp I have taken voltage from various test points and none of them match I've got 324vdc at the big filter cap that's ok at d4 its says 7v but I am only getting 1.906vdc at the +15v i am getting 3.62vdc and at the -15v I'm getting -3.59vdc at the last one is the +48v and I'm only getting 10.68vdc will I defo check/Replace c9. Thanks for the info much appreciated
                        • garrymc123
                          • Apr 2010
                          • 336
                          • United Kingdom
                          Also, I'm trying to find schematics for this power board but I'm having no luck anyone have such a thing. Thanks
                          • R_J
                            • 9550
                            There is a 2 leg component mounted to the main fet heatsink, is that thermister or could it be a thermal cutout (fuse)
                            It looks like the power supply is working at a reduced level. You could check and post the voltages on the U100 ic (hot ground) try and probe a component on the same trace rather than on the actual ic pin (probe slipping is not good)
                            I would also check across the 2 secondary pins of the optocoupler and report the voltage, and measure the voltage across the 2 pins on the primary side of the oprtocoupler
                            Also check the voltage on U101, that is the voltage reference (one pin will be ground)
                              • Jul 2011
                              • 6040
                              Here is the data sheet for this device
                              • garrymc123
                                • Apr 2010
                                • 336
                                • United Kingdom
                                Thanks, i will check the voltages when I get back from work I was hopfully wanting a full schmatic for the full power board.
                                • garrymc123
                                  • Apr 2010
                                  • 336
                                  • United Kingdom
                                  [QUOTE=R_J;835469]There is a 2 leg component mounted to the main fet heatsink, is that thermister or could it be a thermal cutout (fuse)
                                  I have had a quick test of the green thing mounted to the main FET heatsink with a multimeter, it has no continuity either way with probs
                                    • Jul 2011
                                    • 6040
                                    Need to post a photo of this
                                    “There is a 2 leg component mounted to the main fet heatsink, is that thermister or could it be a thermal cutout (fuse)”
                                    I would also replace C9 and go from there
                                    • R_J
                                      • 9550
                                      The green device on the heatsink looks like a thermistor it is in series with R133 and seems to be connected to the optocoupler. It may be some sort of temperature regulation.
                                      • garrymc123
                                        • Apr 2010
                                        • 336
                                        • United Kingdom
                                        cheers guys yes I think it is a thermistor it has a k or a x on it I have taken some pics of it. how would I go about testing this... Thanks in advance
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                          by sam_sam_sam
                                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                          Found shorted diodes on main controller relays there are 3 of them that...
                                          01-07-2023, 05:43 PM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
