DC to DC Converter Quality - Does it Matter?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Need to hardwire a dashcam in my new Crown Vic and I'm wondering how important it is to get a good quality vs a crappy DC adapter and how do I tell if it's good or not? They all look about the same about the same price range. I'd happily spend a few bucks more to get a really well-made one but I don't really see too many options. Thank you in advance.
    https://www.ebay.com/itm/DC-DC-Conve...W/182901814133
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: DC to DC Converter Quality - Does it Matter?
    I have used and still using the cheap Chinese types and they work well. Just unsure the Current rating is adequate.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Thanks! Yeah it's a little dashcam that works fine on a 1A port so the "3A" one should be fine.
      • tibimakai
        • Jan 2012
        • 3680
        I'm using the same thing, for over two years, with no issues. Except the cams battery does not last to long and needs replacing. I have a Mini 0805 camera.
        • redwire
          • Dec 2010
          • 3906
          For 12V to 5V car SMPS, I thought using a cheap one to charge a $500 phone is not a great idea.
          I use KIM-055L modules (thanks stj!) which are efficient and good for over 4A, they use TPS40057 IC and some mosfets. You can find them on fleabay and Ali, unpotted for under $3. Also some boards have 4-port USB to use as car charger.
          I replace the two electrolytic capacitors with solid polymers, so it works in winter, and add a huge automotive-rated TVS diode SM8A27 to protect against transients, just soldered underneath. This has worked great for years.
          Some 12V to 5V DC-DC units I've seen are junk (overheat, crap capacitors, low Vin max like 16V).
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            I would never use anything but a quality, name-brand adapter to charge my phone, that's for sure. But for a cheap-ish dashcam, I don't care so much lol.
              What I do not like about using Buck converter is that when switched MOSFET shorted out, it will dump the input Voltage to the output. I put fuse and 6.2V zener at the output just in case.
                • Jul 2011
                • 6037
                I never thought about this but you are right I have one those Buck converter
                not the same model but it does the same thing
                Here is the one that I have
                https://www.ebay.com/itm/26089468014...84.m1436.l2649
                Thanks for posting this thought
                • DXseekerMO
                  Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                  by DXseekerMO
                  Hello everyone!
                  Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                  I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                  Yes
                  0%
                  1
                  All backlight strips are the same quality
                  0%
                  1
                  No
                  0%
                  0
                  12-16-2021, 03:58 PM
                  MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
                  The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
                  Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
                  10-23-2024, 03:23 AM
                • gizmo1990
                  What is this PSW1 part on a circuit board? Trying to fix a Canopus ADVC-300 DV/VHS Converter
                  by gizmo1990
                  I'm trying to fix this Canopus converter so that I can convert lots of old VHS cassettes. The problem is that it turns on for a split (and I mean split!) second, the fan jerks and then.. nothing. I've checked the power brick works. I've opened up the converter itself and been testing for shorts.
                  The image attached shows the on/off switch (which I've checked works) to the left of the yellow socket. Below the yellow socket is a green block marked 26 with a strange symbol at the front. Putting my probes either end of this block, on the silver parts, gives an open short...
                  10-21-2024, 08:02 AM
                • wolf1976
                  i look for equivalent dc to dc converter
                  by wolf1976
                  hi
                  in an inverter of aircondition i have dc to dc converter mes1515mh
                  i have attachment the pdf file
                  can i take a dual converter with two dc outputs instead this ? because i cannot found the same or is not possible ?
                  the problem is instead 15 volt dc output i have only 6,45 volt
                  thanks on advancxe...
                  08-01-2024, 04:52 PM
                • md500
                  [Question] Ch341a and 5v to 3.3v with logic converter
                  by md500
                  zz0.8tpitu4y0i8zzI bought a ch341a (I'm waiting for it to arrive) and I noticed that the programmer has a bug that the data pins go to 5v when the VCC pin is at 3.3v (which is the voltage I'm looking for).
                  Instead of doing the 3.3v mod, I'm thinking of converting the 5v to 3.3v with an 8 channel TXS0108E through the ZIF socket but I don't know if that would work, because it has to circulate voltage and also information.
                  What I am looking for is something that will convert from 5v to 3.3v but without modifying the ch341a.
                  I can't buy the ch341a 1.6v that has...
                  05-24-2024, 06:51 PM
