APC 900 UPS fan going into high speed for no reason at all for long period of time
    • Jul 2011
    • 6070
    Re: APC 900 UPS fan going into high speed for no reason at all for long period of tim
    https://www.ebay.com/itm/Battery-Pro...4AAOSwUn9aBZAJ
    Here is a link to one that is very-very close to what I use I have look at how you select the number of cell because I can not remember what you have to do
      • Jul 2011
      • 6070
      Well some bad news on this battery backup it bit the big one
      We had a bad thunderstorm yesterday afternoon ( the power blinked on and off a bunch of times in a row ) and now it does not charge the batteries no more ( also the fan does not run either ) you can get the green to come on but if you turn on the power supply back on a couple of minutes later it goes into shutdown mode and the battery replace is flashing and there is no inverter function that is working
      To many issues with it this time around
      I am not going to try to repair it again I can not find any obvious damage but to me it not worth the time or the effort to try to fix it again
      • karatzdi
        Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
        by karatzdi
        I know some might say... just buy another one. Sell it as parts..!
        So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
        Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
        Spent some time downloading the Service...
        06-11-2024, 08:38 AM
      • EvazX
        ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
        by EvazX
        I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
        Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
        For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
        However, after some time, the replacement motherboard...
        08-25-2025, 06:09 PM
        Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
        I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
        I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
        I tested the battery cells there are installed right now and they are testing good with no issues that I...
        02-04-2025, 08:08 PM
      • DynaxSC
        Extreme High Current & Low Voltage Short Killer ??
        by DynaxSC
        Hi Folks
        I'm looking for a extreme high current short killer solution for a reasonable cost.
        I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
        After taking off the socket, the shorts dissappear again.
        The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
        10-15-2024, 10:13 AM
      • Gjackson
        Question about UE60JU6800K backlight power.
        by Gjackson
        got my hands on a Samsung UE60JU6800K, initially it apparently had a bunch of white circles on screen which I confirmed was due to loose diffusers when I opened the set up and found a mountain of them at the bottom. The person I got if from stored the TV unused for a lengthy period after this so when I got it the backlight was completely gone. I took out the strips and almost all of the LED's have a crack on the yellow phosphor form the center of the LED outward, the ones that don't have this crack seem to work still (Maybe due to humidity after a long period?). Anyways I...
        06-11-2024, 06:03 AM
