just to see what people think...
Antec
Antec
24yes0%10no0%5depends on how nice the PSU is...0%9sigpic
(Insert witty quote here)Tags: None -
Re: Antec
1 * P12362 CAP 4700UF 10V ELECT FM RADIAL 1.34000 $1.34
1 * P12345 CAP 3300UF 6.3V ELECT FM RADIAL 0.76000 $0.76
2 * P12735 CAP 3300UF 10V ELECT FM RADIAL 0.95000 $1.90
2 * P12369 CAP 2200UF 16V ELECT FM RADIAL 0.95000 $1.90
2 * P12354 CAP 1000UF 10V ELECT FM RADIAL 0.50000 $1.00
1 * P12366 CAP 1000UF 16V ELECT FM RADIAL 0.59000 $0.59
2 * P11621 CAP 820UF 200V ELECT TS-ED 4.18000 $8.36
1 * P12372 CAP 330UF 16V ELECT FM RADIAL 0.32000 $0.32
1 * P12919 CAP 100UF 10V ELECT FM RADIAL 0.16000 $0.16
1 * P12923 CAP 47UF 25V ELECT FM RADIAL 0.16000 $0.16
1 * P12927 CAP 22UF 50V ELECT FM RADIAL 0.16000 $0.16
2 * P10316 CAP 10UF 50V ELECT FC RADIAL 0.34000 $0.68
1 * P10312 CAP 1UF 50V ELECT FC RADIAL 0.27000 $0.27
1 * P1196 CAP 1.0UF 50V ELECT SU BI-POLAR 0.24000 $0.24
Total = $17.84
However, only the first 6 items were actually needed so the total cost to repair the supply would have been $7.49 + shipping. Worth it to me!Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
by Oldschool297I found these, i would only like to try them on a board to see if it post. It don't post at the moment, i guess there are 9 6.3v 3300uf that can be broken. Is these low or high esr? I did not find info on the web.
https://www.amazon.de/-/en/10-Capaci...s%2C469&sr=8-1-
by TomGJHi All, So I have two Genelec 8020Cs that are about 10 years old, one of them stopped switching on. I took it apart, fuse was blown, and I've traced the short to one of the two large capacitors on the circuit board.
Now from looking at the Capacitors, they seem to be from Samwha's SD Series with the following specs: 3300uf, 35v, 85C, 25 x 16 mm Radial.
The problem is, I can't find any capacitor from Samwha's SD Datasheet that matches these specs. The closest is 3300uf, 35v, 85c but 31.5 x 16mm, with a max ripple current of 2.5A. I'm guessing the 25mm is custom made for...-
by sirpsycholWhile recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
by bulkchart32i ordered a lot of caps from digikey to repair my xboxs. one thing i ordered was 50NXA10MEFC5X11-ND caps and i think they are not polarized. will this cause any kind of a problem? i really don't want to order new caps just because of this.
by ajdrenterIn my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
https://www.badcaps.net/forum/showthread.php?t=14159
It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...-
- Loading...
