Benq W1070 projector smps
  • tibimakai
    • Jan 2012
    • 3680
    I have got this projector(pj) for free, and I'm trying to fix it.
    I did not get help in other sections on this forum, so I'm trying my luck here as well.
    The pj, has three LEDs(Lamp, Power and Temp) that should indicate, what is the problem with it. In my case, none are on. The only LED, that blinks(very dim), is the power button, which is not included in any troubleshooting info.
    I have took the projector apart and I have measured some voltages.
    12.65V and 3.3V are there in the secondary output(CN701 connector).
    I also have 171V at the main capacitor, after the rectifier.
    What I don't have, is the 385V that should supply the ballast for the bulb.
    Also, I have measured two more voltages in the primary side, 21V PFC and 19Vcc and these are much lower. 15.4V PFC and 11.2Vcc.
    I can't find datasheet, for STR-W6262A, so I'm stuck with the repair.
    I'm attaching the PS schematic(elektrotanya, has the full sm) and the datasheet for the FA5502M IC.
    I'm guessing that somehow the PS has to be turned on, right? I don't know how, though. Should I use a resistor(what size ?), between 3.3V and pin #14 at the CN701?
    Any help, would be appreciated.
    Tibor
  • CapLeaker
    Leaking Member
    • 7976
    Re: Benq W1070 projector smps
    or there is something wrong with the PFC. If it doesn't work, nothing else works either. You need to see 390V or so on the main filter cap. You measured 171V on it, that tells me either the PSU isn't turned on, or if it is turned on the PFC isn't working.
    As for the resistor size I use something around 1k Ohm.
    Can we see some pictures both sides of the PSU?
    • tibimakai
      • Jan 2012
      • 3680
      Thanks for trying to help.
      Today, I have plugged everything back together and I have measured the pins ,at CN701 and both voltages are oscillating. That is why the power button LED blinks.
      With Min/Max, the most that I have measured is 4.7V and 1.4V.
      Without the main board connected, these voltages are stable. Something is bad on the main board?
      I have took some quick phone shots. Most likely they are not good enough for diagnosing the boards. But at least, you have an idea what we are talking about.
      Without the main board connected, I have measured the optos, between pin numbers #3 & #4 and I'm measuring 1.00V, at IC652 and 15.3V, at IC653.
      • CapLeaker
        Leaking Member
        • 7976
        Either the main board is drawing too much current from the PSU due to some sort of a fault, or the stby circuit from the PSU can't provide enough current required for the main board to run properly.
        Check or replace that cap that runs the STBY circuit on the PSU. You can also use a bench power supply and feed the main boards STBY with it and see what happens.
        • tibimakai
          • Jan 2012
          • 3680
          If I would use a 1K resistor, between pin #13 and #14(CN701), the power supply should turn on, right?
          STBY capacitor, is C712?
          • CapLeaker
            Leaking Member
            • 7976
            yeah, c712 is on the 3.3v rail. Check or replace it. The PSU should fire up like that as you said above.
            • tibimakai
              • Jan 2012
              • 3680
              To tell you the truth, yesterday I have shorted the pins and nothing happened.
              • R_J
                • 9514
                The standby power supply needs to be stable before I would wory about the pfc power supply, If the 12volt and 3.3 volt are not stable, check or replace C661 (47/50v) and C662 (47/50v) If they are weak the smps will not be stable.
                • CapLeaker
                  Leaking Member
                  • 7976
                  yeah and it won't until the STBY rail is stable at 3.3V. As RJ already said, wouldn't hurt to check / replace the 12V caps as well. In order to test the 3.3V rail, just load it up with a light bulb or a resistor and see how much current it can supply.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    I have replaced all three capacitors, but there is no change.
                    I will still have to try it out, with a bulb. Flashlight bulb and car bulb, right?
                    • R_J
                      • 9514
                      The manual gives the current ratings of the supplies, 12v 3amp, 3.3v 30ma. I would load the 3.3 with about a 100 ohm 1/2w resistor, the 12 volts would need about a 5 ohm 30w resistor to draw about 2.5 amp.
                      So you might need a couple 12 volt lamps on the 12 volt line depending on how much current easc lamp draws, they are not all the same.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        I will do these tests, as soon as I can. I'm insulating and installing drywall in my garage(man cave) and I can't work fast enough these days.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I'm not really sure, how to do these load tests and measurements.
                          I should add these resistors, and measure the voltage? It shouldn't drop?
                          • R_J
                            • 9514
                            That is correct, 100 -75 ohm across cn701 3.3v (11,13) to (7,9) ground should load the 3.3 volt line.
                            a 12 volt lamp or 2 across cn701 12v (3,5) to (7,9) ground should load the 12 volt line, this line should supply at least 2 amps. without droping
                            If those voltages stay up, check the voltage across C662 (remember this cap is on the hot side) and is not measured to cold or chassis ground. this voltage supples the vcc for the pfc ic.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              I have a 6 Ohm/50W resistor. I will plug it in right now. One sec.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                I have 10.22V.
                                3.25V on the other.
                                • R_J
                                  • 9514
                                  Thst seem like it should be ok, the 12 is a bit low but I don't think it should cause a problem.
                                  What connects to CN702? is it a door switch?
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    Measure, with load resistors removed right?
                                    I have measured these voltages a while back, and they were showing 15.4V(21V PFC) and 11.2V Vcc(19V Vcc).
                                    I haven't measured them, since I have replaced the capacitors, though.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      C661=11.27V and C662=15.45V.
                                      • R_J
                                        • 9514
                                        You can leave loads in place. If those voltages are steady with the loads in place, you must have something on the main board that is really loading down the supply when its connected.
                                        From what I can tell, the 12 volts should not get loaded untill the LP_DRIVE signal it there (page 8),so it could be that the main is loading the 3.3 volt line?
                                          Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation P Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P51s + ThinkPad Stack Mobile Projector boardview and P51s + ThinkPad Stack Mobile Projector schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                          09-06-2024, 06:11 AM
                                        • tibimakai
                                          Benq W1070 projector power button blinks green
                                          by tibimakai
                                          I have got this projector for free.
                                          The only symptom, that I can see is, when I plug in the AC cord, the power button starts blinking like every two seconds, continuously.
                                          Power, Lamp and Temp LEDs do not turn on.
                                          Previous owner thinks, that is a bad transformer. I'm not convinced about that.
                                          I have took it apart, inspected the power supply and ballast driver and did not see anything obviously bad.
                                          At elektrotanya, is available the SM(schematics):
                                          elektrotanya.com/benq_w1070_w1080st_ver.00a_level3.pdf/download.html
                                          Here it is, the level 2 SM:...
                                          03-15-2018, 09:22 AM
                                        • bermo96
                                          BenQ W1070 Projector 5v rail
                                          by bermo96
                                          Hi, I've a BenQ W1070 projector and the lamp isn't working, I replaced it but same problem. Then I checked the voltage inside and the 5v rail is showing 2.3V. The commands for the ballast is powered by this 5v rail. I've the schematics but I can't find any 5v regulator an the 5v isn't coming from the power supply board. Can someone help troubleshoot this ?
                                          Have a nice day...
                                          06-16-2019, 10:34 AM
                                        • Kiks412
                                          BENQ MP511 Video Projector - No Button Responce and wierd Image
                                          by Kiks412
                                          Hey guys, I have this Video Projector that turns on, takes a bit to give some image, and when it does it displays a weird static image, and has no reaction to on-device buttons or remote whatsoever, even to turn off, only unplugging from the outlet. I'm new to this kind of device so I will be very happy to get some help with this....
                                          12-20-2022, 10:00 AM
                                        • dkneyle
                                          Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                                          by dkneyle
                                          This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                                          Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                                          02-01-2022, 02:08 AM
