PlayStation 4 Slim power supply ADP-160CR
  • gokings12
    • Mar 2015
    • 4
    • usa
    Hi!
    I have a power supply that will not power on the Playstation 4 but everything I've checked seems to be OK. I'm hoping someone can help!
    I've checked
    Fuse - F1
    Resistor - R1
    Bridge Amplifier - BD1
    I get 12V and 5V when testing with a multimeter.
    I do not see any damaged caps or other components.
    What should I check next?
    https://imgur.com/a/kPiB4
  • CapLeaker
    Leaking Member
    • 8195
    Re: PlayStation 4 Slim power supply ADP-160CR
    Maybe there is something wrong with the PS4 and not the power supply. Did you try to power up your PS4 with a known working power supply?
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      Pictures like those are like power supply "porn".
      PeteS in CA
      • fester
        • May 2017
        • 158
        • Slovakia
        Have you tried to switch the power supply on?you must short some pins on the little connector to switch on 12V on output terminal.
        Sample video is here,i dont know if is this the right type of PS,is not everytime the same pin combination.
        https://www.youtube.com/watch?v=PRXEAF6YAA0
        • gokings12
          • Mar 2015
          • 4
          • usa
          Yes I absolutely tried another power supply and it switched on fine.
          Yes also tried this method and got 12V on the multimeter.
          • fester
            • May 2017
            • 158
            • Slovakia
            So,with another power supply is PS4 working and yours power supply is working too (switching 12V output)? Is standby light present with this bad power supply? Try to meassure it connected to PS4 if you have the same voltages,specialy 5V on standby somewhere on the 4pin connector.
            • gokings12
              • Mar 2015
              • 4
              • usa
              I tested for 5V but it was not connected to the PS4 during the test. I will do this tomorrow and share the result.
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                I would measure Q6. I think it is a FET so measure outer 2 legs in diode/beep mode. Beep is usually bad.
                • giovanni4ever
                  • Mar 2015
                  • 4
                  • Romania
                  I need to know the value of R39, the rezistor code, can you help me?
                  • lpraderi
                    • Dec 2017
                    • 30
                    • Uruguay
                    According this hand made russian diagram of ADP-160CR R39 is 4K7 ohms
