Weirdest power problem
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Yes, this is the weirdest ive ever seen. Taken from a CD player. Just nice and compact with not much components.
    First it has no power. Dismantled the unit, unplugged everything and tested the power supply on its own. While the power plugged, hearing a ticking sound on the switching transformer. Tested the port for 12V, only 5V was showing.
    OK, i replaced all the electrolytic caps and ceramic caps, NO GO
    Swapped the N channel transistor. Still NO GO
    Soldered all the joints, NO GO
    Tested all the normal diodes and SMD diodes, all gives good reading, none shot
    But the thing is, all of a sudden after switched off for sometime and switch on the unit again, it will work providing solid 12V and there wont be any ticking sound and the entire set works fine . Then when you switch it off and switch on again after a while, the ticking sound will start doesn't matter with load or without load. Anyone had this issue before?
    All other boards on the player is fine, the power supply is faulty on its own as it gives the ticking sound without anything plugged in to other boards.
    Re: Weirdest power problem
    Did you check or replace startup/running cap C11 in the HOT side?
    The ticking sound you hear is due to SMPS is in start-up shut down mode whcih can be due to bad caps or bad rectifier in the cold side.
    BTW, the schematic looks to have error, C5 is labeled as 330/25V, that cannot be right, that is the main filter cap so it cannot be rated at 25V, C11 is shown as 22/5V which is wrong also. See what the real rating of the caps are on the board and compare them to the schematic.
    https://www.badcaps.net/forum/attach...3&d=1519382548
    The board is fed by 120VAC or 220VAC?
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      I was about to guess C11 but because "all" caps were replaced it couldn't be...
      I think this is C11:
        Looking at the bottom side of the board it does not look like there is sign of soldering works on the cap's legs.
        • DjKrish
          • Oct 2012
          • 354
          • SG
          Thats because after soldering everything, to make sure its clean i cleaned the entire board with alcohol and toothbrush
            OK, thanks for the clarification.
            So some how it is stuck in the ON/OFF cycle.
            Have to look for the spec sheet of that SMPS IC to see what other condition will cause the IC to get stuck in that mode.
            SSC6210A IC is what is used on the board, correct?
            • DjKrish
              • Oct 2012
              • 354
              • SG
              Yes thats correct
              • DjKrish
                • Oct 2012
                • 354
                • SG
                I saw a tv power supply being repaired by a guy on youtube and it had the exact same problem. The transformer was ticking, he replaced optocoupler and walla its solved. At first he sprayed duster on the optocoupler to test it and yes upon spraying, the power worked fine and after it gets hot, the problem starts again.
                https://www.youtube.com/watch?v=MGGyyi7gLO0
                • DjKrish
                  • Oct 2012
                  • 354
                  • SG
                  I have a optocoupler thats PS2571-1. Its very hard to find that particular part number but i believe we can use substitute right? Any reference i can get?
                  • DjKrish
                    • Oct 2012
                    • 354
                    • SG
                    Update : Replaced the optocoupler, power supply is working fine now. No more ticking sound.
                    • DjKrish
                      • Oct 2012
                      • 354
                      • SG
                      Replaced the optocoupler, power supply is working but the ticking comes back for few seconds like 10 seconds upon turning on if switched off for more than 10 minutes.
                      I think some smd ceramic caps needs checking.
                      • DjKrish
                        • Oct 2012
                        • 354
                        • SG
                        Update : C6 smd cap shot. Replaced, so far so good.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Thanks, I may have never checked the stays-cool optoisolator, never expected these to fail. I suspect that perhaps they're overdriven and hence fail.
                          Isn't C6 a MLCC, now these I wouldn't expect to fail unless they're physically damaged thus shorting...
                            I wonder what that Thermistor TH3 is being used for, it looks to be for something to do with temperature. I did not have a chance to look up the spec sheet of the IC yet to see what pin 4 is used for.
                            So C6 has leakage resistance?
                            Keep an eye it to see if the problem comes back.
                            • DjKrish
                              • Oct 2012
                              • 354
                              • SG
                              Thats the worse part about smd caps
                              Yes sir. Was running for few hours, so far so good.
                                master hoarder
                                • May 2008
                                • 12170
                                • Bulgaria
                                MLCCs fail "on their own" quite often, actually. It could be due to some light (or not so light) vibration or shock to the case, triggering a "sleeping" factory defect in the MLC cap. Or the damage could have been caused by improperly-calibrated pick-n-place SMD machine. I read an app note once that said that ceramic caps can develop internal cracks over time and short-out if the pick-and-place machine applied too much force or if the cap was subject to stress during PCB assembly. Also, if the ceramic cap is in a position where the board flexes a lot, that could also lead to internal fracture of the MLCC's layers and a short-circuit.
                                On that note, one of my neighbor's DVD/surround sound system appeared to fail all of a sudden after they moved to a new house. The unit would produce lots of sparks during turn On every time it was plugged it. The cause was a short ceramic cap on the output of the SMPS, which likely cracked when the DVD/surround system was moved. The sparks happened every time because the SMPS would try to turn On, then detect a short-circuit, then turn Off again. I think my neighbor donated it after I fixed it, as she didn't trust it anymore, lol. But that was really the whole problem. Unit worked flawless after I removed the faulty ceramic cap and replaced it.
                                So yeah, these small ceramic caps can cause lots of issues. Never ignore ceramic caps!
                                • Dan81
                                  SNES-powered
                                  • Oct 2013
                                  • 1865
                                  • Romania
                                  I had the same happen with an TV
                                  It had a bad ceramic cap inside (burnt to ashes, rest of components weren't broken or anything, just that cap) and wouldn't turn on because of it. I removed it (didn't bother with a replacement, it was a very narrow space) and tested the TV. It turned on and worked perfectly just like it does now.
                                  Main rig:
                                  Gigabyte B75M-D3H
                                  Core i5-3470 3.60GHz
                                  16GB DDR3-1600
                                  Samsung SH-224AB DVD-RW
                                  Delux MG760 case
                                  • GLISIT
                                    by GLISIT
                                    01-16-2025, 02:29 PM
                                    09-06-2024, 05:59 AM
                                  • meraklinetx
                                    Asus Z97-a power cycle, no boot no cpu voltage
                                    by meraklinetx
                                    Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                    05-10-2023, 06:08 AM
                                    HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation Specification for Upgrade or Repair
                                    This specification for the HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Power 15.6 inch G9 Mobile Workstation PC boardview and ZBook Power 15.6 inch G9 Mobile Workstation PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                    09-07-2024, 05:20 AM
