I found the bad cap, looking at replacements
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: I found the bad cap, looking at replacements
    Originally posted by evilkitty
    @stj you hit the nail on the head with the brand part (Changx)
    I have 2 questions about the series
    1. do you have a link to what each means/ intended use
    2. which series do i want for each cap
    I do have 3 of these units (replacing caps in all), 2 have the same garbage caps, one has different caps, the other has Jwco, the larger 10uf caplooks to have a actual number on it (CD11G brand appears to be jw)
    CD11G looked familiar, read this thread for a laugh
    https://www.badcaps.net/forum/showthread.php?t=47823
    @Per Hansson
    After looking at that cap, wouldn't this one be better/last longer?
    https://www.mouser.com/ProductDetail.../EEU-FR1E471Y/
    Sure, was just trying to keep close to the dimensions you stated.
    and about that 400v cap, does that need to be fr as well?
    i had this in my cart, i know it is only rated at 160v, but it should only be getting used at ~125v
    https://www.mouser.com/ProductDetail...47-UCA2C100MPD
    Never ever do that as budm stated!!!
    You can use any 400v rated cap you find on your favorite shopping site, it really does not matter. (It does not have to be low ESR).
    EDIT: This one is nice, maybe it was already linked before:
    https://eu.mouser.com/ProductDetail/...5TgiW03dbXY%3d
    • evilkitty
      • Nov 2017
      • 299
      Would it be easy to take a photo of the 12 volt & 5 volts power supply board I am curious of the quality of that power supply seeing the quality of the 5 volt board is to me is crap
      Just a thought
      The 12v adapter is from networking hardware that my ISP uses, so it should be a decent unit, based on the math i did, but i do stress it at times, probably about a 95% load; that is a 1A supply; it will put out some heat under that load
      that unit is running my network switch and powers my keyboard light (SMD 3528 led strip), i think i used a TIP120 transistor to turn it on/off
      but yes i can take a pic for you, easier now then back when i took that last photo, i have space connectors on the mains power lines now and there is a molex plug on the DC side, i can do so this afternoon
      • evilkitty
        • Nov 2017
        • 299
        So assuming the transformer fails and allows ~170v to go through is there a fuse i can put in the output line to act as a safety? i would say a fuse of about 1.5A should be fine
        I know i would want a fast blow, but i do not know what the difference in between glass and ceramic, well i know what they are but i do not know why it matters in a fuse
          "So assuming the transformer fails and allows ~170v to go through is there a fuse i can put in the output line to act as a safety? i would say a fuse of about 1.5A should be fine"
          re you talking about putting a fuse on the DC output of the power supply?
          If that is the case it will not protect anything if the transfomer insulation failed, you will likely to get electrocuted, the fuse on the DC output is not going to do anything.
          • evilkitty
            • Nov 2017
            • 299
            When i say safety i mean for the intended load not me, is there anything i can add on either the dc or ac side of the circuit?
            as for the pictures of the 12v adapter:
            https://imgur.com/a/ps6uA
            • kaboom
              "Oh, Grouchy!"
              • Jan 2011
              • 2507
              Yes! An equipment grounding conductor (EGC), from DC common to the "third wire" of your (new) power cord. Your line voltage is 120, so for a 200V input filter, use Nichicon CS.
              Connect line & neutral from the cord to the fused & unfused (respectively) AC inputs on that PCB. Connect the green or green/yellow wire from the line cord to the "-" pin on the first filter cap after the transformer/rectifier on the secondary side.
              So if/when it shorts pri-sec, the fuse blows and/or bkr trips, if fault current gets into bkr's instantaneous range. Instead of the output sitting at line voltage, with the connected load still working, it's made safe and the input to the supply is killed.
              Let me add that those supplies are kind of flopping loose in that case- at least move them outside. Those little supplies, not that I'd use them personally, can be just as nasty as bigger ones, like what was in that case originally. Don't let their small physical size or capacity be mistaken for small hazards.
              After looking at this, I think you'd be better off with an external "brick" supply connected by a cable and multipin plug/receptacle.
              "pokemon go... to hell!"
              EOL it...
              All style and no substance.
              guilty,guilty,guilty,guilty!
              guilty of being cheap-made!
                • Jul 2011
                • 6070
                Do not get mad at me for saying this but you need to get a better power supply’s to cover the power that you want to push out of them
                I very rarely push a power supply be on 50% maybe to 75% but if I do it to 75% or higher I keep a very close eye on it to make sure it not overheating the case of the power supply
                If you need better power supply’s I can point you in the right direction just let me know and I will be glad help you with it
                They will not cost you an arm and leg
                I do tend to over size the power supply for what I am powering and more so with switching power supply
                Now if I am using a transformer type power supply I might cut it close to it maximum output but then will put a fuse in it that is what the transformer is rated for
                But I have seen some transformer and I laugh at what they say they can put out
                Please be safe
                • evilkitty
                  • Nov 2017
                  • 299
                  I used the plastic boxes to hold the adapter board cause they have no mounting holes
                  Sorry i do not quite understand all that i really could use a wiring diagram
                  Here is the color coding i am using
                  Code:
                  AC Wires (US standard AC color coding):
                   Green - Earth ground
                   Black - 120v AC
                   White - neutral AC (connected to earth ground in mains panel box)
                  DC Wires (standard Computer PSU color coding):
                   Black - 0v DC
                   Red - +5v DC
                   Yellow - +12v DC
                  At one point i had a brick for all this, but i replaced it cause it belongs in the power supply hall of shame thread
                  I believe this is the one:
                  https://www.newegg.com/Product/Produ...82E16812123309
                  The 1st issue is came with an adapter that was not pinned properly for the brick
                  I do not recall which pin was ground on which but this was the issue
                  Code:
                  Brick pin set:
                   5v
                   0
                   NULL
                   12v
                  Adapter pin set:
                   5v
                   NULL
                   0
                   12v
                  This POS was barley able to handle a 25% load with +5v falling a measly 4.8v
                  and it claims to do 2A on +12 and +5
                  *wonders hat i did with this piece of junk*
                  • evilkitty
                    • Nov 2017
                    • 299
                    Do not get mad at me for saying this but you need to get a better power supply's to cover the power that you want to push out of them
                    If you need better power supply's I can point you in the right direction just let me know and I will be glad help you with it
                    Please be safe
                    If you can find one that will fit in the allotted space that is not a POS that would be great, i would like to keep it inside the PSU case, the only way i know to find a good brick is to get a used one from networking hardware, unless you count going extreme overkill and getting picking up 300w seasonic PSU
                    when i say the 12v one gets pushed hard, i figured out my leds should pull 300ma at 12v without the vdrop from Darlington transistor and the spec page on the network switch states it uses 700ma, i should probably measure it
                      • Jul 2011
                      • 6070
                      Here is one power supply
                      I do not have one of these power supply but looking at the specks I might buy one soon and try it out
                      12 volt @ 8 amp
                      http://www.mpja.com/12VDC-84A-Power-...info/33176+PS/
                      Here is another one at same web site
                      I have not tried this brand of power supply before so I can not tell anything about it
                      5 volt @ 3 amp
                      http://www.mpja.com/5-Volt-Power-Sup...info/18438+PS/
                      I have some of these power supply they are very good they are made by MeanWell
                      The only problem with power supply it if you want a voltage lower than 4.75 volts
                      ( the trip pot gose lower than it should)
                      it is not going to happen without being mod it in some way it's high voltage is 5.8 with different trim pot then you get to 6.25 volts the review that has that as a note I was the one who wrote it that the range of adjustablty is not correct in the description that they have for it
                      https://www.allelectronics.com/item/...-supply/1.html
                      • evilkitty
                        • Nov 2017
                        • 299
                        Both those are alot of overkill
                        for the +5v i am only using probably about 800ma, clamp on meter shows i use 0.5A when not charging my old ipod shuffle
                        as for the +12v i am using a GX-D1081 network switch and running 45cm(3leds per 5cm) of cool white SMD 3528 led tape
                        I figure if both can do 2A that would good
                          • Jul 2011
                          • 6070
                          You can find very good power supply you just have to look
                          With me I do not like compact boards where all the components are real close together and caps are real close to heat sinks or do not have switching power regulator in them
                          This is a big one if I find one like that most of time I will not use it but that just me
                          Or if the switching transformer does not look like it can handle the load that they say it will
                          Most of the time I do not use them either
                          • evilkitty
                            • Nov 2017
                            • 299
                            are these board worth a crap?
                            http://www.mpja.com/5-Volt-Power-Sup...tinfo/18438+PS
                            http://www.mpja.com/12-Volt-Power-Su...tinfo/18443+PS
                              • Jul 2011
                              • 6070
                              They might be alright for the fact that are on sale right now
                              Here is what do when I get a brand for first time
                              One
                              I look at the brand of caps they on the board
                              If do not know the brand I recap it
                              Two
                              I run the power supply on a MR16 / 20 or 50 watt light bulb (at 12 volts = about 1.6 to 3.8 amps load )
                              With the load hook up with out power ON at first and see if it will start with a load the better power supply might start with a load up like that
                              If will not start that way then turn ON the power supply first then put load on it and read the voltage with load then out the load this will tell you how well this power supply regulator system functions
                              I seen some power supply that there voltage regulator is sorry at best or does not have any to speak of
                              Three
                              After 15 minuets I turn OFF the power supply and check the temperature of the heat sinks to see how hot they have become
                              Another test you can do after the heat sinks have come to room temperature is run the power supply at load you are going to use most of time and see how hot the heat sinks become
                              Before you turn it OFF have a load on the output and check the main cap before you do this
                              My rule is if you can hold your hand or figure on the heat sink for at least a minute with having to take them off you will be ok
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                #35
                                My rule is if you can hold your hand or figure on there for at least a minute with having to take them off you will be ok
                                Keep in mind that it's common for heatsinks to be LIVE with DC bus voltage on them!!!
                                  • Jul 2011
                                  • 6070
                                  I should have said before you turn it OFF have a load on it and check the main cap before you do that
                                    • Jul 2011
                                    • 6070
                                    I almost forgot about this power supply this looks be made pretty well
                                    It has 12 & 5 & 3 volt output
                                    http://www.goldmine-elec-products.co...?number=G20367
                                    If you can wait for it to go on sale if i remember right they go on sale for $20.00 but most of time it is one or two that you can buy at price if try buy more than that the price is then $500.00 each I am not kidding but they are funny with that
                                    I have not used this power supply yet but I have about 4 or 5 of them maybe in the next few weeks I am think about a project that I want build and I am going to use this power supply in it most
                                    of time I take the power concentor off the boards because I do not have those plugs
                                    • evilkitty
                                      • Nov 2017
                                      • 299
                                      Ok i like that more, that has everything i could possibly need and more, i would trade from 3.3 amps for 12v amps, wait maybe i could... nah i think that fan needs at least 4v; but hey i can run anything i want on 3.3v with that, not that i have a need to
                                      meh, who needs plugs when you have a soldering iron we could remove the plug OR we can solder to the pin and heat shrink it
                                      Ok i like that one more and after going over a spec sheet i found i like it even more:
                                      https://cdn.badcaps-static.com/pdfs/...c967142f61.pdf
                                      https://cdn.badcaps-static.com/pdfs/...c9c4333d55.pdf
                                      I managed to find it on ebay for about $20
                                      i just ordered it and 5min later i looked at the size that is 1/2 my dam case; there is no way in hell i can fit that in there
                                      • evilkitty
                                        • Nov 2017
                                        • 299
                                        Looks like the actual load on the 12v power supply is .7A max
                                        and the garbage 470uf caps are running at 29 C (norm 0.5A (25%) load)
                                        load based on my multimeter's readings (southwire 21050t)
                                        going back to plan A replace junk caps with real caps
                                        Hopefully kaboom can explain that safety in a way a novice can understand
                                        BTW there is a issue i have been having, it may be a software issue, but it could be a noise issue in my power, on occasion i get a odd noise in my audio over-wise it is seems spotless, so if there is something i can do to make the output cleaner i would like to know; i have already tried using aluminum foil to shield stuff from power lines, i did manage to get a voltage measurement during this event and only saw a variation of 0.01v; so far nothing i have done has had any effect, i also tried a ferret core on my audio cable
                                        After over a year i managed to find the issue, corrupt audio file
                                        • evilkitty
                                          • Nov 2017
                                          • 299
                                          i took a better picture of the 5v adapter (C1, C5, and C6 have been removed)
                                          so how do i wire up that EGC?
