Westinghouse LTV-32W1 PSU blown
  • Wizard
    • Mar 2008
    • 2296
    Totem pole MOSFETs blown and 1W fusible resistor crispy in Delta PSU, checked everything for shorts, bad caps or opens. Nothing found. Would a transformer or a controller IC do this in this type of PSU that you come across before?
    Transistors is twin STP20NM50FP.
    DPS-210EP-2 C REV:01 F
    Tested the 5V PWM regulator off the 12V. Working as it should when I juiced it with 12V. I did check the mainboard and 24V LCD panel for shorts. No shorts.
    Cheers, Wizard
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Re: Westinghouse LTV-32W1 PSU blown
    I don't know this PSU but maybe an over voltage on the line could destroy the power Mosfet.
    It is strange that IC PWM is still live if Pmosfet are blown.
    Ciao
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    • Shane711
      • 493
      I have a Westing House LTV-32W1 with power supply DPS-210EP-2 C. Turns on but then shuts off after about 10 minutes. I turn it off and it turns back on and stays on for 10 seconds to 10 minutes. It does seem like it might be over heating. I have determined it is the power supply but can't seem to figure out what is wrong because I have 2 PSU and the other one does not turn on. So I checked the mosfets on both boards and they are not shorted. What about the IC ice380565, what is it and can it be the problem? I used a PSU from a different TV and the TV stays on forever but the PSU is not compatible so I get no picture, if it was I would just use that one.
      So all my caps, diodes and Transistors seem to be good. Is there a way I can test the ice380565?
        The ICE is for the STANDBY power supply.
        • Shane711
          • 493
          So this could be what turns it on and off? I noticed that vibrations seem to cause it to turn off so it may be a bad solder joint. But the second PSU could have a bad IC ice380565. I will check it tomorrow. I fixed one just like it before this one, Westing House 27" had bad transformers on the inverter board.
            You need to show us the full pictures of the power supply, there should be one or two pins for the standby power supply outputs that go to the main board, we need to monitor those to see if the Voltage disappear when the TV acts up or other signals are missing when TV acts up.
            You should read Basic LCD TV troubleshooting guide to get better understanding how TV works.
            • Shane711
              • 493
              Well, sure enough, it was a broken solder connection on Capacitor C310. In fact both boards had the same broken connection. So now I got a perfect working TV. The picture I included shows the broken solder joint.
              • cmlewis89
                LG 47LB5DF blown power supply board
                by cmlewis89
                Hi folks,
                I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                09-03-2024, 07:50 PM
              • drscoot
                HP X360 convertible battery blown fuse error, not charging
                by drscoot
                HP Modelnumber: 14-dh0061nb​
                This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                All these 3 batteries are charging...
                12-15-2023, 05:54 AM
              • swerg
                Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                by swerg
                Hey everyone,
                I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                06-06-2024, 03:39 PM
              • MrzPdlch
                Blown fuses on Gigabyte GTX 980TI 6GB
                by MrzPdlch
                Hey everyone,
                I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                Find some pictures of the actual GPU together with a picture of how it should look like.
                I also wonder whther it might be a problem that there...
                03-10-2024, 04:14 PM
              • cheeky2
                Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                by cheeky2
                This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                06-15-2025, 05:12 AM
