Totem pole MOSFETs blown and 1W fusible resistor crispy in Delta PSU, checked everything for shorts, bad caps or opens. Nothing found. Would a transformer or a controller IC do this in this type of PSU that you come across before?
Transistors is twin STP20NM50FP.
DPS-210EP-2 C REV:01 F
Tested the 5V PWM regulator off the 12V. Working as it should when I juiced it with 12V. I did check the mainboard and 24V LCD panel for shorts. No shorts.
Cheers, Wizard
Cheers, Wizard
