Sanken SMPS
  • spdf
    • Aug 2017
    • 13
    • Lt
    Sanken SMPS
    Hi, I have Sanken PSC10089G M SMPS pulled from Lg plasma Tv.
    First of all I found bad diode which says n44k on it. Does that mean 1n4400? 6.8V Zener? Looks like an ordinary silicon diode though.
    And I have 40 Volt 30A Dual Schotkky Rectifier in question. It reads 0.1V from cathode to anode on both diodes. From cathode to cathode it is not shorted. Is it ok?
    Any help will be appreciated
    Thanks!
  • spdf
    • Aug 2017
    • 13
    • Lt
    Re: Sanken SMPS PSC10089G M
    This is my first time I am trying to repair switching mode power supply that I pulled off from old LG plasma TV. After I am it still not working looking at it every day lol...
    Model Sanken PSC10089G M I couldn't find any schematics of it.
    At first it was completely dead no output voltage and no standby voltage what so ever. I tried to measure some voltages and I found out that I have ~300V on primary filter caps and that's all. After changing power IC KA7553 standby voltage came a live BUT after trying to powering it on in series with 100W bulb relay clicked and bulb began to shine - dead short. (I disconnected all smps loads and soldered some pull down resistors to start power supply) I literally checked every component with DMM and couldn't isolate any shorted components in circuit so now I am beginning to suspect switch mode power transformer, but I already know from reading this outstanding forum that it is highly unlike that this transformer went bad.
    it would be great if someone could give me advice or point out where to look for a clue. ;]
    I added photos (please don't mind red square in these photos it's just a personal reminder ).
    • spdf
      • Aug 2017
      • 13
      • Lt
      Re: Sanken SMPS
      A little update: today I pulled of the circuit (look atached photo) 3 x K2698 MOSFET'S (that was quite a work...) and FSU10B60 diode all these components are fine.
        • 31163
        Re: Sanken SMPS
        explain "dead short"
        if the bulb lit full brightness then the psu works - the problem is someplace else.
        • spdf
          • Aug 2017
          • 13
          • Lt
          Re: Sanken SMPS
          I have totally lost...
          I have disconnected all load from psu and added pull down resistor to power up psu, at first bulb ligts up and dim away after ~10s relay clicks and bulb is shining in full brightness. So i decided there is a dead short some where in psu circuit? Or isn't it?
            • 31163
            Re: Sanken SMPS
            oh - bulb is in series with the mains - o.k.
            well check what parts the relay switches in - then you will probably find the short.
            i cant see under the heatsinks, but i think there is a big bridge rectifier under the lower one - check that first.
            • spdf
              • Aug 2017
              • 13
              • Lt
              Re: Sanken SMPS
              Is it possible that if I left psu turned on with bulb in series that shorted components will become hot?
                • 31163
                Re: Sanken SMPS
                maybe - it depends what they are.
                it's also possible the shorted part with catch fire or explode - so dont leave it alone if you try that.
                • spdf
                  • Aug 2017
                  • 13
                  • Lt
                  Re: Sanken SMPS
                  Is there any possibility that this chip (in photo) is shorted? Is there any way to test it?
                    • 31163
                    Re: Sanken SMPS
                    no idea, but i suspect the problem is a simple but large part - like the bridge rectifier or a diode
                      Re: Sanken SMPS
                      Well, did you check the bridge rectifier as suggested? The relay supplies the AC to feed the bridge rectifier.
                      You should also check the resistance between the two outer pins of the bridge rectifier to see if it shows low resistance (<500 Ohms) in both directions.
                      • spdf
                        • Aug 2017
                        • 13
                        • Lt
                        Re: Sanken SMPS
                        Thanks for the input!
                        In diode mode bridge rectifier reads as expected, though resistance of outer pins in circuit is in megaohms range.
                        Voltage I measured on filter caps is ~300V DC while relay is not activated (does that make sense?). Is it still possible that bridge rectifier produces short?
                        • PeteS in CA
                          • Aug 2005
                          • 3581
                          • USA, Unsure of Planet
                          Re: Sanken SMPS
                          If you have 300VDC on the filter caps, I don't think there's a shorted diode in the bridge rectifier. Does the relay act as an on-off switch? Or does if short across inrush limiters after several AC cycles?
                          PeteS in CA
                          • spdf
                            • Aug 2017
                            • 13
                            • Lt
                            Re: Sanken SMPS
                            As an On-off switch.
                            There is no short if I unsolder pin 6 from power factor correction IC and relay is still turning on.
                            I managed to find two bad SMD transistors (or it's a diode?) + smd cap in question. Does anyone have a clue what kind of transistors are they and cap?
                              • 31163
                              Re: Sanken SMPS
                              can you see whats written on them?
                              • spdf
                                • Aug 2017
                                • 13
                                • Lt
                                Re: Sanken SMPS
                                There is nothing. It's just black ;]
                                • spdf
                                  • Aug 2017
                                  • 13
                                  • Lt
                                  Re: Sanken SMPS
                                  Is it even possible to tell something about these parts without scehmatics? (It's kinda strange that it's impossible to find any information about this smps, or isn't it)
                                  • R_J
                                    • 9582
                                    Re: Sanken SMPS
                                    This guy fixed the same board https://www.eevblog.com/forum/repair...s-psc10089g-m/
                                    • PeteS in CA
                                      • Aug 2005
                                      • 3581
                                      Re: Sanken SMPS
                                      It is possible that the normally open relay contacts have welded into the "on" position.
                                      PeteS in CA
                                      • asr
                                        Finding replacement diode iPad Pro 3rd gen A1701
                                        by asr
                                        Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                                        Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                                        07-09-2024, 06:24 PM
                                      • unimatrix93
                                        TV backlight zener diode
                                        by unimatrix93
                                        Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                        So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                        Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                        The led strips has 9 6V leds.
                                        02-10-2025, 12:13 PM
                                      • magistertc
                                        CMOS battery drains quickly
                                        by magistertc
                                        This problem is based on my experience with an ASUS Z390 Prime motherboard, but it appears to affect other motherboards
                                        as well Install a new CMOS battery, configure computer, turn off computer and disconnect from AC power or switch off SMPS.
                                        Return somewhat later and find that battery is drained, dead, or weak. Clock is wrong, other settings lost, etc.
                                        Examine the power 'sharing' circuit -- when the ATX 3V supply is on, the computer will function normally. The computer is also
                                        configured to support the RTC and some volatile RAM (when SMPS is on). What you may...
                                        07-06-2024, 09:55 AM
                                      • NicRac
                                        monowheel repair,Is the diode the problem?
                                        by NicRac
                                        Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                                        First of all, I am new here. Therefore I will shortly introduce myself.
                                        I am Nico and currently I study Physics.
                                        In my freetime I like to build and repair stuff. Especially big battery's.
                                        A few years ago I got myself an electric unicycle, monowheel or however you call that.
                                        The battery bms was broken so I replaced and resolder that. Nothing big.
                                        I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                                        07-26-2024, 06:13 AM
                                      • dennis_elx33
                                        NO BODY MARKING Diode
                                        by dennis_elx33
                                        Hello Everyone,
                                        I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
                                        While compared to the reading of another diode from the next channel it won't read at reverse bias.
                                        Now the problem is; it does not have any body marking.
                                        So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
                                        What do you think is this diode?
                                        Can you please suggest what part number can i use to replace this faulty diode instead?
                                        Hoping that you...
                                        06-14-2024, 12:36 AM
