Antec SP-400 on knees and crying pulling a P4...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    What do people think...
    I have an Antec SP400 - the same one that I repaired, had to replace 5VSB caps and the switcher IC. It was working fine with 4 HDDs on a 3GHz P4 (Pres-Hott), but when I hooked up three more HDDs, it wouldn't turn on! Remove some HDDs and it works again. It might be the spin up surge of the HDDs but it's pretty rough.
    Maybe I have more bad caps? This machine also would not power up with an Antec SP300 when it just had 4 HDDs, hence I had to put in the the SP400. Maybe the SP300 also needs new caps too.
    I dropped in that BBQ'ed 750W PSU I just repaired and it started up just fine.
    • 31214
    Re: Antec SP-400 on knees and crying pulling a P4...
    could be caps,
    could also be the fact that ide/sata drives spin-up when you connect the power.
    this is shit, because you get a big surge.
    if it was scsi the drives would spin-up in sequence so as not to shut your psu down!!
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Yeah, SCSI drives have delayed spin easily controllable via jumper. SATA and PATA drives usually do not.
      It looks like a typical drive draws 2A on the 12V rail on first startup. So 7 hard drives trying to spin up is 14A =~ 170W. Then average out the 5V supply at .5A per disk = ~ 18W.
      Round that off to 200W. Wow, that indeed is quite a bit of pull for 7 disks.
      The pres-hott I've seen shoot up to 100W during boot (once I was running a gpu and a pres-hott and the pair drew 180W+ during boot...)
      -> A 400W PSU should be able to easily start these disks, it seems, as long as there's no GPU?
      • Behemot
        • 4845
        • CZ
        I think the start-up surge is even higher than what the disks are labeled, it's like with incandescent light bulbs…
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          The labels tend to write less than an amp on +12 (I just noticed two of my WDs are only 600mA). I saw a website that measured the peak to be around 2 amps when the disks start spinning so that was the value I used. Of course this is drive specific, and suspecting disks with more platters to be worse.
            master hoarder
            • May 2008
            • 12175
            Yup, normal to see lower Amp ratings on HDDs than what they actually use at startup. 2 Amps is a good assumption, so your calculations above should be pretty close.
            With that said, you have 100 Watts for the CPU + 180 Watts for the HDDs + 10-20 Watts for the fans and other misc stuff + xx watts for the GPU... so you probably need over 300 Watts on the 12V rail. Is the SP-400 capable of that? Is it capable of that without much load on the other rails? All these can cause the PSU not to work. Add bad caps on top of that, and that could well be why the PSU is not wanting to work.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              The SP400's rating:
              +5: 28A
              +3.3: 30A
              +5 and +3.3: 130W max draw. Likely mag amped.
              +5VSB: 2A
              +12V1: 14A => 168W max
              +12V2: 15A => 180W max
              -12V: 0.3A
              Total: 400W max
              This technically should be enough (the rails seem to actually be tied together), very possible it's just capacitors. The machine uses the onboard graphics so at least it doesn't need to power a discrete GPU along with the mess.
              Looking at the Antec SL300S, it's very clear why it can't supply 7 HDDs, as it seems to be +5/+3.3 heavy and doesn't pay much attention to the +12 rail as it only has one 15A output. Come to think of it, I think this SL300S is very poorly matched for the P4 as the +12 rail is very underpowered if it needs to power both the VRM and the HDDs. No wonder why it has trouble even powering a few HDDs with the P4.
                master hoarder
                • May 2008
                • 12175
                That doesn't tell you much, though.
                Most PSUs with more than one 12V rail will give a max combined power rating too. Without one, you can only assume what it could be. From what I've see on other PSUs before, your PSU is probably good for no more than 20-24 Amps total combined on the 12V rail.... or about 240-288 Watts. And that's probably if you have a somewhat bigger load on the 5V rail too (that's where motherboards with power-hungry Northbridges are useful, as those are typically powered by the 5V rail).
                With 2 HDDs or less, it would probably be okay. The problem is that Pentium 4 also has a high power draw at boot.
                That Antec SL300S may also be a bit more sensitive than other PSUs. I was using a 250 Watt HiPro to power an Athlon 64 3500+ (67W TDP) and a Radeon HD3870 video card (~90W TDP) with two heavy multi-platter HDDs, and never had a problem playing games and maxing out the video card. Sure the PSU got warn then, but it managed. 12V rail never dipped below 11.85V.
                • sirpsychol
                  Antec Earthwatts EA-380 smd element type/value
                  by sirpsychol
                  While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                  09-03-2023, 07:58 PM
                • ajdrenter
                  Picking caps for Antec SU-380
                  by ajdrenter
                  In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                  https://www.badcaps.net/forum/showthread.php?t=14159
                  It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                  05-13-2023, 10:40 AM
                • CWEastwood
                  Antec Smart Power SL300S capacitor replacement.
                  by CWEastwood
                  I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                  The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                  I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                  Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                  03-25-2023, 12:18 PM
                • s_henya
                  Antec VP-600P and NE550M dead
                  by s_henya
                  Got in these 2 nice PSUs, both died after power surge.
                  Both seems to be suffering from the same fault.
                  Blown main fuse
                  Shorted N mosfet 550v
                  VP-600P: 5R280CE short between GDS
                  NE550M: MDF18N50 short between GDS
                  In terns of board layout these seems pretty identical.
                  From past knowledge, once gate get shorted, most likely the for the driver to go bad as well.
                  I never tried to salvage blown fuse PSU with shorted Mosfet due to that.
                  Is it worth to try and replace the mosfets? is there a chance that the...
                  12-03-2024, 10:00 PM
                • survivalbloke
                  Lenovo X280 - short on board, voltage injection pulling 4.9a but nothing heating up?
                  by survivalbloke
                  This laptop came in for no power. I saw the board was not taking any power so I pulled the board and began testing. As you see in the photo, on those pair of mosfets, I had 20v into and out of mosfet 1 and 20v into mosfet 2, but only 3v out of mosfet 2. I found a location which was shorted and injected 1v5a and it took all the current, but nothing is heating up with the thermal camera and I can't for the life of me figure out how 5a isn't showing on thermal.
                  12-06-2023, 08:51 AM
