Bench PS Problem (Volteq HY3010D)
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8716
    Re: Bench PS Problem (Volteq HY3010D)
    In RP1, RP2, RP6, and RP4 - there should be a connection between the middle pin and one of the side pins when in circuit. However RP5 and RP7 should not -- that is, if the schematic is accurate.
    • orientalsniper
      • Apr 2013
      • 461
      mmmm what should my next step be? do they sell these boards?
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8716
        Can you take a better picture of the board/pots and annotate which wire goes where? Each of the voltage and current settings have three pots apparently - fine, coarse, and calibration PCB pot...
        When out of circuit do RP5 and RP7 change resistance as described when rotated?
        • orientalsniper
          • Apr 2013
          • 461
          I attached photo with the pots locations circled.
          RP7 resistance test failed, pin1 with pin3 resistance is way too small for the sum of 1-2 + 2-3.
          It's the potentiometer then?
          EDIT: What's the part number for these pots? I want to order from Digikey.
          • kaboom
            "Oh, Grouchy!"
            • Jan 2011
            • 2507
            Because you're checking them in ckt. Pull em and try again.
            "pokemon go... to hell!"
            EOL it...
            All style and no substance.
            guilty,guilty,guilty,guilty!
            guilty of being cheap-made!
            • orientalsniper
              • Apr 2013
              • 461
              ckt = circuit?
              The test was done outside of circuit (soldered out). Forgot to mention that.
              • kaboom
                "Oh, Grouchy!"
                • Jan 2011
                • 2507
                ckt = circuit?
                yes
                Ok. Try putting each wiper in the center of its rotation. Then check from 1-wiper and 3-wiper. Each should measure 1/2 of what 1-3 reads.
                ASSuming linear taper, a 10k nominal should be ~5k in each half-element/wiper check. All pots have some end resistance, don't expect zero ohms from end-to-wiper when fully turned to one side.
                And don't buy cheap/fake stuff from aliexpress. Mouser/Digikey are a better value overall, especially when you consider wasted time for "repeats."
                You can pull the 324 and disable the tap changer. You'll then be at the lowest range of raw DC before the regulator.
                Check the opamp supplies, with respect to the positive output terminal (black meter lead on + output).:
                M1/M2, 4(-6.2v) & 8(+12v)
                M3, 4(+12v) & 11(-15v)
                EOL it...
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8716
                  Oh cool, did not realize V16 was an LED on the front panel... I assume V15 is the other LED though it's obscured by the wire. Are these LEDs lit at any time? I also wonder if they're still good too...
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8716
                    BTW, in order for the voltage to drop to zero or something that's usable by typical digital electronics, V16 needs to be lit. If neither LED will ever turn on, that's another data point that will help tremendously to debug this problem, all without an external voltmeter...
                    The only thing to make sure is that either the LED lights up, or is not open circuit in both directions.
                    But the data given about the potentiometers is really messed up. Please carefully remeasure and make sure there's nothing in parallel that will skew the results. Potentiometers do not fail shorted, they fail open.
                    • ashan000
                      yx-305d bench power supply decreasing voltage problem
                      by ashan000
                      This power supply is 30v 5amp. Problem is when turned on after about 3 minutes voltage starting to decrease slowly. (like - 5.8 > 5.7 > 5.6 > 5.5) can't see any damaged component or dry solder joints. Checked main 2 transistors with multimeter. Reading seems ok. Tried changing potentiometers(both coarse and fine) still the same situation. Can any one help me to troubleshoot? What voltages to check? Any ideas helps to fix this. thank you.!
                      07-12-2025, 08:43 PM
                    • theone111
                      by theone111
                      3. Problem: TV shuts down
                      07-22-2024, 10:36 AM
                    • ClockChip
                      Advice sought - Selector switch knob repair
                      by ClockChip
                      Hello Everyone,
                      I am seeking to repair a knob on an old (circa 1971) Panasonic clock radio (a model RC-6900). The good news is that I have the small, easily lost knob. The bad news is that the knob has come off a slotted post and I need to re-attach it in such a way that I won't have to worry about it coming loose again.
                      Here is a picture of the bare slotted post (if I have the term right) the knob should be attached to:
                      As you can see, this is an Old School selector switch, which means it's pretty stiff. Put another way: the knob has to fit...
                      07-20-2024, 04:52 PM
                    • Zeonalbasta
                      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                      by Zeonalbasta
                      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                      09-13-2024, 01:17 PM
                    • Gibon378
                      Problem with stopping audio and video for no reason
                      by Gibon378
                      PC Specs:
                      • CPU: Ryzen 5 1600
                      • GPU: GTX 1080 Palit JetStream
                      • MOBO: ASRock ab350 PRO4
                      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                      • PSU: XFX 650W (don't remember what model)
                      • OS SSD: ADATA SP920
                      • OS: Windows 10 21H2
                      Problem description:
                      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                      11-19-2022, 09:41 AM
