I am working on this power supply and curious as to how the DC voltage of the rectifier output is increased to what the manual indicates it should be. The manual says the DC output of BD901 should be 320vdc when off and 400vdc when turned on. Now I know the output of the rectifier is only around 170vdc by itself and this is about what I have now, way less then what the manual says it should be and the supply is not working. How does this circuit increase the DC line to 400vdc? My thought was the switching of the mosfet,Q902 but I am not an engineer. Thanks.
Power Supply Voltage
Tags: None
Re: Power Supply Voltage
see active power factor correction
Application Note 42047 Power Factor Correction (PFC) Basics
Power Factor Correction (PFC) Handbook Choosing the Right Power Factor Controller Solution
https://cdn.badcaps-static.com/pdfs/...25ddb0846b.pdf
CIRCUITS FOR POWER FACTOR CORRECTION
WITH REGARDS TO MAINS FILTERING
https://cdn.badcaps-static.com/pdfs/...94077c90c3.pdf
The explanation in the first post seems a bit wrong. BD901 voltage shouldn't increase much when turned on, however voltage after the coil L903/Q902 drain indeed should go higher when on. So, it means the PFC IC IC902 is not turning on your transistor Q902. Supposedly this should be an automatic world sense (i.e. can detect 120 or 240VAC mains) so that 170V you're getting at BD901 is about right for the US, but the voltage after the coil should go up to that 400V mark when turned on.Comment
Ok. So Q902 mosfet has to be running for the circuit to boost the DC to 400v. Correct?Comment
When the 'STANDBY' pin receives the ON command signal (>2VDC) the switched transistor is turned on to supply the VCC voltage to run the PFC Controller IC.
Do you have better pictures that show the whole page of the schematic?
Upload the service manual will be better.Never stop learning
The complete manual was to large to upload so I pulled out the PS page and attached it.
This supply had some damage. ic903 was blown apart and a couple other components in that circuit. Q902 was also damaged so it and ic902 were also changed. ic901 was pulling down the vcc line so it was changed.
Now when plugged in I have app. 4.75v on 5v line. When jumped to standby it comes up to the stated 5v. Q922 is switched on and I have 5v at the vcc of ic902 and ic901. But neither ic seems to be running.
But I think I found out why. In looking at the datasheets for both of these ic's I believe they both need app. 12v to turn on. So I am looking into this now. You are welcome to verify my thoughts with attached datasheets links.
https://cdn.badcaps-static.com/pdfs/...d35c2983cc.pdf Page 7
https://cdn.badcaps-static.com/pdfs/...49ac344075.pdf Page 8Attached FilesComment
That is a lot of blown parts, so what DCV do you have on the Emitter pin if switched VCC Transistor Q922?
You are working in the primary side so the GND ref. for your meter will be the negative leg of the main DC filter cap in the primary side.
BTW, can you give the link to the site so I can download the manual?
And what the model number of the TV?Last edited by budm; 03-23-2017, 09:54 PM.Never stop learning
It is a Sharp LC-42SB45UT
Complete manual here:
DC is 5v on e and c of Q922 when switched on. 5vdc on e when off.
Yes I am using hot gnd when testing hot side and cold gnd when testing cold side.Last edited by mrtech2017; 03-24-2017, 02:21 PM.Comment
5V? The VCC for running the SMPS and the PFC IC is generated by the AUX winding of the standby power supply transformer T904, D908, C965.
So I would check the Voltage of R976 of each end to GND (negative leg of the main filter cap when TV is in standby and when STANdby command is present..
"hot gnd" I hope you mean the negative leg of the main filter cap C907.Last edited by budm; 03-24-2017, 02:27 PM.Never stop learning
I believe you mean C969.
I have tested on both sides of R976 (5v) And tested D908, replaced C969 and checked winding for open.
Hot gnd meaning any location with an open triangle, neg side of C907 or anywhere else that has an open triangle. All hot gnd..
If you lift one leg of R976 do you then still get about 5V on C969?Never stop learning
Yes, this was how I found out that ic901 was bad. At first I only had @ 2vdc on this line when Q922 was on and after disconnecting most other components on this line it then came up to the 5v when ic901 was removed. After new ic was installed it held at the 5v when Q922 was turned on.
Last night I lifted 1 side of R976 and connected my external supply and set it at 12vdc and jumped Q922 and I had a good 12v on my vcc's at the ic's. But ic902 was still dead. I have another new ic but have not installed it yet.
I figured that once I see if the PFC runs normal with the 12v supply I will go back and see why there is not 12v on this line.Comment
Yes, that is puzzling since you do have about 5VDC standby on the cold side, and there is not much to that circuit at all. I expect the cold side 5V to be really low too since both windings are driven by the same primary drive.Last edited by budm; 03-24-2017, 08:04 PM.Never stop learning
Well i changed out ic902 and with 12v on vcc still no 400vdc. So in looking at the datasheets some more and the schematic it looked like it might need more then 12v to turn on. So I started turning up the external P/S and when it hit app. 12.5vdc the PFC came on and I had 400vdc and the 12 and 24 volt supplies. I think it actually should be around 15vdc on the vcc.
So back to T904 I rechecked voltage at D908 and had 5.85vdc. Lifting R976,R917,R991,R921 it dropped to 3.1vdc at D908. Both D908 and C969 test good and I do not have replacements.
What voltage do you think I should have on T904, pins 4 and 5?Last edited by mrtech2017; 03-26-2017, 09:38 PM.Comment
I think more than 5V should be at R976 as IC902's start-up happens at 11-13VDC. The over-voltage max. is ZD910+6V or 21VDC.
I would guess around 16V expected on C969.
Hard to tell if the TNY277 regulation is off (is 5V output OK?) or another issue.Comment
Assuming...7 Photos -
by sam_sam_samI want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
https://www.ebay.com/itm/116497313155?var=416785404161
Here are some of the description from the eBay seller
The main parameters:
1. Product name: High-power non-isolated DC boost module power supply.
2. Product model: 100A2000W.
3. Input voltage: DC12V-60V.
4. Input current: 100A (maximum).... -
by Jembanggood day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...-
Channel: Common Parts Library - Datasheets
10-07-2024, 04:12 AM -
by sam_sam_samI have been pondering this question for a while but now I have see if this doable but I need to answer this question once and for all
I would like to know how to safely do this undertaking my first thought is to solder wires to the main filtering capacitors and see
what voltage I am getting and seeing if I can build a battery pack with voltage or not and if
I can find a BMS balancing protection board at this voltage level and weather or not do I have use more than one BMS balancing protection board... - Loading...
