Thermaltake TR2-550 PSU Busted
  • jdimpas
    • May 2008
    • 39
    hi guys, thanks for coming in my thread! Anyway, just recently my PSU(Thermaltake TR2-550) is not working and when i opened the PSU casing, unfortunately i found a busted ceramic caps(covered w/ rubber) located between the two filter capacitors (820uF) as well as the fuse also got blown. I believe there's a component that is shorted in this PSU.
    What are the possible cause of this damage? Can it be fixed?
    If anyone has the same experience in this PSU, please do share.
    I appreciate any help around here. Thanks!
  • jdimpas
    • May 2008
    • 39
    Re: Thermaltake TR2-550 PSU Busted
    Is anyone here has the schematic diagram of this PSU? thanks
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Photo please.
      I think you might be looking at MOV's and not caps.
      You won't find a schematic, they aren't publicized.
      I'm not 100% sure but I think that PSU is built to the same reference design as Antec TP2.
      There are plenty of threads around on those because the cheap Fuhjyyu caps Antec used cause them all sorts of problems.
      Mann-Made Global Warming.
      - Dr Seuss
      • Gianni
        • Jul 2008
        • 681
        • Italy
        I think PCBONEZ is right
        The only ceramic cap I saw busted was in my LG TVset, it is used in a snubber network.
        In PC PSU I have not seen till now a CERCAP busted.
        Post some pics if you can.
        Ciao
        Gianni
        "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
        H. J. Brown
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          those are mov's so 1 of 2 things happened.
          high line voltage or you lost the neutral on your panel or drop.
          someone hooked it to 220 with the switch in the 110 position.
          • jdimpas
            • May 2008
            • 39
            I just recently found out that it was plug to 220 with 110 settings.
            I thought this expensive PSU have a good design for protection.
            • jdimpas
              • May 2008
              • 39
              Hi Sir, if ever i'll change the varistor(mov) will it work again? thanks
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                It does have a good design for protection.
                The MOV's died to save the motherboard, processor, RAM,,,,,,, from the user. [ahem]
                That's what is supposed to happen.
                As to fixing it all you can do is try and see.
                - Dr Seuss
                • jdimpas
                  • May 2008
                  • 39
                  Hi Sir,
                  I've just replaced the mov and the fuse, however, when i did a test by shorting the black and green pins it seems that theirs no power co'z the PSU fan is not spinning, but the PSU LED lights-on showing orange which means standby mode. I likely believe that the PSU has a power since it triggered the LED on, or maybe does my testing procedure is incorrect?
                  • Gianni
                    • Jul 2008
                    • 681
                    • Italy
                    Hi jdimpas,
                    maybe your PS need a minimum load to start. If you have an hold hard disk, CD/DVD player, you can try to connect them and see if the PS start.
                    Ciao
                    Gianni
                    H. J. Brown
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Gianni is correct.
                      Some PSU's won't start at all without at least some load.
                      - Dr Seuss
                      • jdimpas
                        • May 2008
                        • 39
                        i'll try it guys, thanks!
                        • Idzfix
                          [WTB] Avita Liber 14" NS14A2MY036P – Casing / Housing (Top/Bottom)
                          by Idzfix
                          I'm looking to buy a replacement **casing / housing** (either top cover, bottom base, or full chassis) for my laptop:
                          šŸ“Œ Model: Avita Liber 14"
                          šŸ”¢ Model Number: NS14A2MY036P
                          My original casing is cracked and I’m hoping to replace it. I’m open to:
                          - New or used parts
                          - Full chassis or just top/bottom shell
                          - Compatible parts from other Avita V14 / NS14A2 / NS14A8 models
                          If anyone has a non-working unit with intact body parts or knows where to get one, please let me know....
                          08-05-2025, 09:48 AM
                        • harp
                          Howto open schuco rubber plug
                          by harp
                          Oh, sadly it has no screw...
                          What is the proper way to open this so that not destroy rubber?
                          I feel if go on forward with not knowledge howto open, that it be broken rubber seal on it....
                          12-16-2022, 02:35 PM
                        • x_orange90_x
                          Busted panel corners... Repairable?
                          by x_orange90_x
                          I have a 50" Toshiba bezel-less that I replaced backlights in a few weeks ago. The tape didn't hold well so the panel started hanging from the top. The pressure caused the two bottom corners to shear off. I can see a court contact on the right corner, but the left is gone in assuming. The screen is not cracked anywhere else, but it displays no image.
                          Is it at all repairable? I'm assuming not....
                          02-02-2025, 04:17 PM
                        • rodd
                          Thermaltake TR2 750W -fixed 5v stby now +5v reads low and no 12v
                          by rodd
                          Dear all,
                          I am trying to repair the ATX power supply.
                          First I fixed the +5V stby, which was zero due to a shorted TNY279 and an open 2R2 resistor.
                          Just in case I replaced the PWM control IC (PS223) and the PFC control IC (CM6800).
                          Now the supply turns on, the +3.3V is fine, but the +5V measures only 2.5V and there is no +12V.
                          I have checked every diode I could find with a DMM (in circuit) and all the capacitors (in circuit) no shorts, low ESR.
                          In despair I removed the low voltage diodes which were all mounted on the same heatsink...
                          08-11-2023, 12:58 PM
                        • AresROC
                          Thermaltake TR2 Bronze 600w low 12v voltage
                          by AresROC
                          https://www.amazon.com/gp/product/B00NW6W2C8
                          I have a Thermaltake TR2 80+ Bronze that's been doing strange things. It would cause the computer to shot down randomly, and measures low voltage on the 12 volt rail. From 11.5 to 11volt.
                          I put it on the bench with a harddrive as load, and it outputs fine with low load:
                          5v - 5.17v
                          12v - 12.17v
                          It has all Japanese caps, but only 1 large cap for the Input supply. No obvious signs of overheating burns or bulge. Anyone know where I should start to troubleshoot? I guess I don't want to just start by replacing...
                          12-02-2021, 02:07 PM
