ANTEC Power Supply EA-430D - Suddenly dead!
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: ANTEC Power Supply EA-430D - Suddenly dead!
    Originally posted by Advall
    C952 22uf 50v nichicon
    That would be my first candidate - but it gets benefit of doubt, being a Nichicon
    Do you have something with which to test it ? - like an ESR meter
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • Behemot
      • 4845
      • CZ
      Does it even get power? Fuse OK? Do you get voltage on the big input cap when you plug it in? Be EXTREMELY carefull not to short anything and electrocute yourself.
      • Advall
        • Feb 2017
        • 14
        Regret I do not have a ESR meter but might be able to borrow one.
        • Advall
          • Feb 2017
          • 14
          Yes there is about 125 volts on the big cap.
          • Advall
            • Feb 2017
            • 14
            Sorry - that voltage is down to earth.
            There is 325 V DC across the cap itself.
            • Behemot
              • 4845
              • CZ
              #26
              Yes that would be about OK. So the problem is in the stand-by circuit alone.
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • Andreas_de
                Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                by Andreas_de
                Hello!
                i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                04-12-2025, 10:38 AM
                03-31-2024, 02:12 PM
              • kevin_allein
                Samsung QE 75 Q 7 FGMTZG Power Supply dead
                by kevin_allein
                Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
                In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
                Does anyone have schematics for that board ?
                Any good tip, what could be the issue ?
                02-27-2025, 12:15 PM
              • khalillll
                maxipower 400W Dead power supply repair
                by khalillll
                The power supply was completely dead. Voltage reached the main capacitors, but nothing after that.
                After checking, I replaced the UTC7606D IC to restore the 5VSB.
                I using SDC606U as a replacement, but it didn’t work — possibly the IC itself was faulty.
                Replaced it again with another UTC7606D.
                Result: 5VSB came back, but still nothing — no 12V, 5V, or 3.3V.
                After checking again, I think the issue was with the UTC7520D IC.
                Replaced it with a WT7520.
                Result: PSU fully working again
                09-27-2025, 05:06 AM
