Xtreme Gear PSAZ-600
  • Drack
    Yup it's me
    • Nov 2016
    • 297
    • Venezuela
    Re: Xtreme Gear PSAZ-600
    Nice job, those where the minimum load resistor some PSU are kind of a ehh Wells bitches with those, what caps did you use?
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Thanks. I used nichicon PW, Panasonic FC, Rubycon YXF for the little caps. 1200uF 6.3V Chemi-Con KY for 5VSB, 3300uF 10V Rubycon PX for 5V and 3.3V, 2200uF 16V Chemi-Con KYB for 12V, nichicon PW for -12V.
      • SIDMX
        • Nov 2010
        • 165
        • Mexico
        Originally posted by Pentium4
        You were right! I hooked it up to a system and it powered up no problem. It just didn't have enough load with just a paperclip... Yes it indeed only has that one 20A schottky for 12V.
        Great job, as always!
        Remember those resistors are the minimum load needed for stability at minimal or no load conditions, i wouldn't attempt to explain exactly why they need a minimum load because there are too many things involved and don't even fully comprehend half of them but each design reacts different when changed, some give crazy voltages but stay on (usually crappy ones), others shut down after a couple of seconds or right away as yours.
        If the power distribution from the 12V rails is right this PSU fits a niche where only a couple of amps are needed from the 6-pin PCIe connector to feed a mainstream GPU like GTX 950/1050Ti and that may explain the 20A rectifier in 12V, so you were right, it's great for HTPC.
        • Drack
          Yup it's me
          • Nov 2016
          • 297
          • Venezuela
          I have heard that some PSUs went kaboom when the didn't have load, and that's why they are there on some PSUs.
          Agreed with you but I will use a 1050 or an Rx 460, less power consumption imagine 65w CPU, 75w GPU, 12w HDD, 20w ram and vrm looses, 12w on fans that's close to 15.33 amps on a part that should not exceed 70% usage and 70% of a 20a part is 14a, or that's what I have heard or read on some places like hardware secrets
          Or something like an r9 270, that's 120w power consumption with peaks at 150w and it only uses one 6pin, I want you guys to know that I respect you and I'm smart enough to know that you know more than me on psus so, I'm just saying not trying to piss you off with my comment
          • everell
            • Jan 2009
            • 1514
            The reason I began fixing computer power supplies in 2009 is because I wanted to learn what was wrong when they went bad such that computer shops won't repair them, but simply trash and replace. I have come to believe that if you are daring enough to fix just one computer power supply, you have become an expert electronics technician ......... unless the first one you fix is a Bestec ATX-250 12E. That was the first one I fixed and everyone started throwing chairs at me!!! The general opinion was that this model power supply was the worst in existence, a mother board killer, and total trash, certainly not worth fixing. Well......that power supply is still working, powering a computer with AMD cpu (Pentium 3 class). I still use it for playing music, mp3 files, and playing freecell cards. Why throw the psu away, or the "old" dinosaur computer. Still works fine!
            Meanwhile, I think my collection in the attic has doubled from the picture I posted some time ago. So..............Pentium4, if you run out of psu's to fix just let me know!!!!!!!!!!!!!!!
            Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              If you have doubled that collection, I'm amazed and impressed! I am mainly after "obscure" PSUs that I have never seen. And believe it or not...I love refurbishing Sun Pro units. Shame they went out of business
              • everell
                • Jan 2009
                • 1514
                Let me know which "obscure" PSU you have never seen......maybe I have one and can send it to you.
                • Drack
                  Yup it's me
                  • Nov 2016
                  • 297
                  • Venezuela
                  #28
                  The first PSU I fixed was a gutless that had no line filtering and a dead fan, changed the fan and added 2 y caps one x and one coil
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    #29
                    Yeah I'd call it a 275W PSU. I don't know why they even bother with the ceramic discs. If you're going to make crap, just leave it completely empty
                    If you update the primary caps to 680uF it can do 350W:
                    Switching transistors are good sized TO-3P D209L, heatsinks are thick enough and designed for 120mm fan cooling and the transformer is real ERL 35.
                    Originally posted by Drack
                    I think a 30a schottky for 12v rail and it would be usable for a new PC if it doesn't crossload because of the light 5v usage
                    +1
                    I would absolutely add a 30A schottky rectifier for 12V rail.
                    I have a Linkworld psu like that in my "for service" pile of power supplies, but I have been too busy to play with it. I remember the metal case was ridiculously thin.
                    • render1967
                      Problem with the Logitech G27 gaming steering wheel gear lever
                      by render1967
                      Hello! First, please excuse me if my English is not good enough because it is not my native language!
                      Now let me describe my specific problem. For two days, the gear lever on my Logitech G27 has shown the following defect. When switching in the game (for example ETS2) it often does not detect 1st, 3rd and 5th gear - in these positions it shows neutral or flashes between the specific gear and neutral (for example - 1st <> neutral). When I press the gear lever to the left or right while it is in a position, it still manages to guess the gear and engage. In addition, instead of rear...
                      11-13-2021, 01:35 PM
                    • iyas132
                      Corsair RM 750 blown schottky diode near ES1DF
                      by iyas132
                      Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
                      Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
                      My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
                      Can anyone help me identify the component...
                      12-30-2024, 01:34 AM
                    • zen
                      FH7 Sony cass deck service manual & gear required.
                      by zen
                      Hi all
                      This deck keeps jamming.
                      Took a chance & ordered an upgraded FF cam gear, plus slider sold on Ebay, as I thought it might be a common cause of issues being that it was sold a repair kit.
                      Well, that's what I get for making assumptions.
                      Stripped down & discovered a large black intermediate gear with worn teeth.
                      Can anyone help to source it?
                      10-10-2022, 08:07 AM
                    • The Byter
                      Looking for Gigabyte 1070 Xtreme Gaming boardview and schematics
                      by The Byter
                      It does not look like any other 1070 I got boardview for.
                      11-28-2023, 02:00 AM
                    • Crystaleyes
                      iMac screen problem - PSU schottky's failing?
                      by Crystaleyes
                      have another iMac with flickering then black screen issue.
                      It is a 21.5" 2010 A1311 model.
                      When switched on, the screen flickers before going black. With a torch you can see the image is there, as are all four diagnostic LED's.
                      Measuring the PSU output only gives around 10.5v with the cable harness connected, although it measures 12.06v unconnected. This leads me to suspect something the power supply.
                      I saw that some people had found a shorted mosfet on the output however these seem fine, when tested for...
                      03-31-2022, 06:55 AM
