My pc100 does not start
  • Drack
    replied
    Re: My pc100 does not start
    Found a shorted diode
  • Drack
    replied
    .I can put 240, I have 240 on my room actually but I'm to lazy to put a power outlet for 4% better efficiency, thanks Pete,capleaker,a24, sam, and everyone that helped me. Btw what it's newer half bridge or this?
  • PeteS in CA
    replied
    What A24 said. It's a universal input flyback design. No doubler, and no need to divide the rectified primary voltage (as would be necessary for a half bridge design). Were you in EuroLand the voltage across that cap would be on the order of 340V. Using one 400V cap instead of two 200V caps in series saves PCB space.
  • Drack
    replied
    It doesn't have PFC, the PSU say it can handle 100v/240v, it's weird, I would check everything I can today, and I will let you know if I see something weird
  • CapLeaker
    replied
    Originally posted by Drack
    I looked it's glue, what I don't understand is why is just 160v on the main caps that is a 400v, shouldn't be 370ish
    120V AC x 1.414 = 170V DC on the main rectifier with the unit off. Since it has a PFC, it will boost the voltage on the main filter cap to like 370V DC when turned on. If the PSU is turned on and you don't have boosted voltage on the main filter cap, then there is something wrong with the PFC IC, or the PSU doesn't get the PSon signal, etc.
  • Agent24
    replied
    Because your line voltage is only 110VAC and that PSU has no voltage doubler or Active PFC boost circuitry. After rectification, you get a higher voltage in DC. You can calculate it by multiplying the AC voltage by 1.414 to get the DC voltage. eg: 110 x 1.141 = 155 (about 160).
    It could be that your line voltage is a bit higher than 110v, maybe 113v.
    The 400V written on the capacitor just means it can handle up to 400V without blowing up.
    It makes me wonder though. Is this PSU actually designed for 110V supply? Running SMPS at lower line voltages than they are supposed to run on can be stressful and cause damage.
  • Drack
    replied
  • Agent24
    replied
    Well that 8-pin chip on the primary side certainly looks as if it has some damage on the top. Or maybe it's just glue\paint. I can't tell, the photo isn't clear enough.
  • Drack
    replied
    It doesn't have a hole, the transistor is fine, most be the pwm, the mov was behind a coil, I already took it out
  • CapLeaker
    replied
    I can't tell on that pic if it has a hole or not, but I am sure as heck that the PWM is dead for one reason or the other. Either it isn't getting any Vcc or it's dead.
    replied
    Originally posted by Agent24
    That 8-Pin PWM controller does look like it has a hole in it.
    It sure does look like that IC-chip has a hole in it
    It needs to be replaced
  • Agent24
    replied
    Fuse might have blown because of a bad MOV, or maybe the MOV blew from a voltage spike and blew the fuse. A spike may have damaged something else too.
    But not sure where the MOV is you speak of, I only see two Y-Capacitors and neither looks bad.
    Switching transistor might have shorted but then burned out and gone open-circuit afterwards. There doesn't need to be a heck of a lot (if any) outward signs of this on the component body either (although there usually is)
  • Drack
    replied
    ¡Happy new year guys!
  • Drack
    replied
    I already have another PSU lol, and 25 bucks is what you won on 3 months over here on average I will check tomorrow its almost 23:00 over here, thanks for the help
  • CapLeaker
    replied
    anyway... see if the PWM gets proper Vcc voltage on pin 7. If not, it may either be in under voltage lockout, or the dropping resistor feeding it went high in value. Other than that, you can try changing it out, or buy for 25 bux another one from flea-bay.
  • Drack
    replied
    It has its 8 pins(weird) this PSU is at 25 bucks on eBay lol
  • CapLeaker
    replied
    maybe a UC3842? See if the PWM has proper Vcc (pin 7)
  • Drack
    replied
    It says uc3142p
  • Drack
    replied
    Pete, when I took the rectifier out the resistance went up to 3200ohm I think
  • CapLeaker
    replied
    that's a voltage comperator, not a PWM. I am looking for the smaller IC with 8 legs next to the large main filter cap.
