IRVCM10A rectifier troubles
  • littlejohn
    • Mar 2022
    • 23
    Hi, I'm looking for a data sheet or a quality IRVCM10A rectifier or equivalent , I can not find data sheets on this and the only place they sell it is at aliexpress and I am suspicious about there quality and at about $45.00 CAD I don't know if my wallet wants to take the risk.It is used in a Evinrude Etec engine management module ( EMM) P/N 586759
  • truclacicr
    • Apr 2019
    • 356
    • australia
    FWIW, the new part number is VSVCM10A.
    https://www.farnell.com/datasheets/523771.pdf (page 5)
    • littlejohn
      • Mar 2022
      • 23
      Thank you truclacicr , you made my day
      • EvinrudeEmm
        • Sep 2025
        Hey John, Did you have any luck finding a replacement or with the datasheet of IRVCM10A o VSVCM10A,
          • 31304
          what is it for?
          got any pictures?
          • EvinrudeEmm
            • Sep 2025
            55V rectifier on outboard ECU
              • 31304
              19pins?
              look at the pcb it was soldered to to see how they are grouped.
              you should be able to work out the pinout that way.
              • littlejohn
                • Mar 2022
                • 23
                I've had no luck on data sheets or part other than Aliexpress. I've read posts about purchasing this item and has a high failure due to quality. There must must be a factory in China that makes quality parts, I just don't know which ones they are.
                  • 31304
                  it's not about quality,
                  putting diodes in parallel never lasts - even though it's common in tv's and tool chargers
                  i bet those modules have lots of paralel diodes - hence the pincount.
