A few questions about recapping this particular PSU
  • espresso
    • Aug 2008
    • 24
    • Serbia
    Hi.
    I have this 350W ATX power supply from 2005 and I decided to recap it and maybe boost it up a little.
    Here is the schematic diagram for it. Many people here have the same PSU as I can see.
    I have already replaced the two biggest caps (originally 330uF/200v) with 470uF/200v. Now I'm after the caps on the output rails and I have the following doubts:
    1. Can I double the capacitance of C18, C22, C23, C25, C27, C28, C29, C32 without any consequences?
    2. Can I use 6.3V caps on 5V rails? The original caps on 5V rails are 10V rated.
    And a general question. Do C1 and C2 need to be low esr too?
    I do not have much experience with switching supplies and the main reason I'm doing this is because I wanna learn something new.
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: A few questions about recapping this particular PSU
    I'm not an expert and I hope more experienced people can reply better than me.
    The psu name is LC-B250ATX: this is the name of a Deer, Allied or L&C psu. Those aren't good: bad or undersized caps are the minor flaw in them.
    My reply is: I think there are consequences: rule of thumbs is up to a 20% variation is acceptable, over that requires a complete check of all components.
    Moreover there are limitations that may prevent you from recapping or may not be worth the hassle. First caps must fit (same diameter and pin interspace) and bigger capacity caps usually have bigger dimension as well; second some of those caps are on minor lines which aren't stressed at all and won't benefit from a capacity upgrade (C18 is on 5V STB, C29 and C32 are on negative lines which are required only by some ISA cards: unless you nan eed ISA card, you don't have to bother about negative lines). Third: supposed you find caps with appropriate dimension, maximum current is limited by FETs and transformers. If you want to draw more current from your psu, I think you'll be disappointed.
    In short, a bigger capacity could help by increasing tensions' stability (longer holdup time and lower ESR) but you may have to change other components as well.
    Yes, you can.
    Not sure: IIRC high endurance is worth more than low esr, but I can be wrong.
    Zandrax
    Have an happy life.
    • espresso
      • Aug 2008
      • 24
      • Serbia
      Thank you for the reply.
      My idea was to make the supply more stable by increasing the capacitance and to put less stress the motherboard caps.
      I will manage to fit most of the capacitors. I already have the replacements in my stock.
      As I understand there shouldn't be problems with increasing the caps which are acting as filters. The only thing that I would benefit is decreasing the ripple, right?
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        espresso- as Zandrax pointed out, caps are not your biggest concern with this supply. Even with good caps, these supplies are likely to go and take your PC components with it!
        Ludicrous gibs!
        • i4004
          • Oct 2006
          • 2029
          this is JNC psu: should be thrown it into garbage immediately!
          tinker with it only if you have no way of getting a good psu.
          but i have trouble imagining region of the wrold where you CAN get low esr caps(which you seem to be able) and NOT be able to get good psu.
          get a good psu, and recap it when needed(which is probably never).
          if you can't get corsair 450, get fortron.
          tell all those other people they have a ticking bomb in their machines.
          charge them for changing theiri psus.
          much better idoea than to repair such awfull quality psu.
          (although this design is not the worst jnc was doing, you should stil l steer away from it if at all possible...)
          • espresso
            • Aug 2008
            • 24
            • Serbia
            Please do not comment the quality of this PSU as I am completely aware what I'm dealing with. That's why I am emphasising the last sentance that I wrote in my first post:
            I'm asking for an advice on recapping. So basically, I would like to know if I am safe with larger capacity on the output rails? I already have the capacitors, the question is whether I should mount them.
            • zandrax
              Hit and miss
              • Dec 2007
              • 1157
              • Italy
              Read the thread about the 350 W psu Trodas recapped two years ago: Gonzo0815 says (comment #24) that increasing the output capacity by a large amount could change the bandwith of the regulator loop, leading to bad tension regulation (waving voltage) or unexpected oscillations in the circuit. 2nd point is low rated rectifiers may be overloaded by high capacity: most reputable brands use rectifiers rated for at least 4 time the real output (say 120 A for a 30 A 12 V line), cheap brands may skimp on those and use the cheapest one they find (say 20-30 A ones).
              On another thread Davmax points out that increasing capacitance slows a bit cap's response time.
              I respect Gonzo and Davmax but my knowledge in electonics is too limited to confirm or deny their claims: I hope they'll spot this thread eventually and properly reply you.
              Zandrax
              Have an happy life.
              • i4004
                • Oct 2006
                • 2029
                mount them and inspect voltages prior to connecting it to something valuable.
                what's the worst that can happen? crappy jnc psu crapping out?
                no damage there.
                chances are it'll work.
                as for learning...doubling wouldn't be enough for me..i would try tripling it, quadrupling it etc.
                just like i just tried with a dc source and adding (one by one) 1000uF caps while monitoring the output voltage...
                • linuxguru
                  • Apr 2005
                  • 1564
                  I have in the past doubled the rail capacitances on Deer/L&C to 2x2200uF on +5v and +3.3v, and to 1x2200 on +12v without much detriment. However, you may want to keep the caps on the +5Vsb rail closer to the designed value (say within +50%), since there is a small possibility that the auxiliary flyback converter may not start up reliably if the secondary caps on it become too large - 2 x 1000uF works fine in practice.
                  C1 and C2 need not be low-ESR - in fact, lower the ESR, the higher the inrush current on switching on at any instant other than zero-crossing. Ordinary general-purpose caps will suffice, as the primary caps almost never fail on even the crappiest PSUs.
                  • espresso
                    • Aug 2008
                    • 24
                    • Serbia
                    I finished the job last night and here is the summary.
                    I used Fujicon RK and TM serties as replacements.
                    All the electrolytics have been replaced with the appropriate values except for these:
                    Code:
                    C18: [B]2200µf/6.3V 105C Low ESR[/B] instead of [B]1000µf/16V 105C Low ESR ("Saturn logo")[/B]
                    C32: [B]1000µf/16V 105C Low ESR[/B] instead of [B]470µf/16V 105C Low ESR ("Saturn logo")[/B]
                    C23: [B]2200µf/6.3V 105C Low ESR[/B] instead of [B]1000µf/10V 105C Low ESR (G-Luxon)[/B]
                    C28: [B]2200µf/6.3V 105C Low ESR[/B] instead of [B]1000µf/10V 105C Low ESR (G-Luxon)[/B]
                    C29: [B]1000µf/6.3V 105C Low ESR[/B] instead of [B]470µf/16V 105C Low ESR ("Saturn logo")[/B]
                    The original capacitors showed no visible signs of deterioration (bulging, leaking). However I am planing to get me an ESR meter for 50€ like this one
                    • linuxguru
                      • Apr 2005
                      • 1564
                      The critical one is C27, on the +12v rail. That's the one that's stressed the most on P4 systems or any other mobo where the VRM is fed from the +12v rail. You can safely go up up to 2200uF/16v, maybe higher on that one. Try to go for something with ~3A ripple current specs for that cap.
                      • espresso
                        • Aug 2008
                        • 24
                        • Serbia
                        Unfortunatelly 2200uf/16v is too big to fit inside (13x25mm). I could probably mount it but it wouldn't be close to pcb.
                        • zandrax
                          Hit and miss
                          • Dec 2007
                          • 1157
                          • Italy
                          OT: where did you find that ESR meter, espresso?
                          Zandrax
                          Have an happy life.
                          • espresso
                            • Aug 2008
                            • 24
                            • Serbia
                            This pic is from a russian site where they talk about constructing ESR meter:
                            http://pro-radio.ru/measure/3288/
                            However, a guy in my country made a similar model and now he is selling it for 50€.
                            Here is something that looks like a simpler solution that one could make at home
                            I can get all the parts and I would make this one if there wasn't for double layer PCB.
                            • zandrax
                              Hit and miss
                              • Dec 2007
                              • 1157
                              • Italy
                              Thanks.
                              Zandrax
                              Have an happy life.
                              • gonzo0815
                                • Feb 2006
                                • 1600
                                @espresso
                                does the 50€ ESR meter have the capacitance measure capacility too or is this only a generic pic?
                                If yes, which is your country and would it be possible to ship one to Germany?
                                I am in the mood to buy an ESR kit may be, but i would love one wich does disply both, ESR and capacitance.
                                Until now i have only seen the offer from Atlas wich i could get for abouth 200€.
                                As i don`t use it in an profesional environment, i would prefer to not spend that mutch money for it.
                                • Wizard
                                  • Mar 2008
                                  • 2296
                                  You don't worry about capacitance (this give a value). ESR is! Ditto to ripple current capablity when choosing good caps.
                                  Cheers, Wizard
                                  • espresso
                                    • Aug 2008
                                    • 24
                                    • Serbia
                                    Originally posted by gonzo0815
                                    @espresso
                                    It does have the capacitance meter (0-99999uF) with 1% accuracy. Here is the picture of the 50€ device when dissasembled:
                                    I can inbox you the guy's email so you can try contact him. The country is Serbia.
                                    ESR measuring capabilities are
                                    Code:
                                    0,001 — 0,999 ohm with 0,001 ohm resolution
                                    0,010 - 9,99 ohm with 0,01 ohm resolution
                                    0,1 - 99,9 ohm with 0,1 ohm resolution
                                    • Paxman_Swede
                                      by Paxman_Swede
                                      Hello!
                                      01-14-2025, 09:51 AM
                                    • captain150
                                      by captain150
                                      03-16-2025, 07:34 PM
                                    • Foetuss
                                      Gigabyte GA-6OXT :: caps question
                                      by Foetuss
                                      Good evening
                                      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                      But I was also suprised about the bigger boys, which are 330µF 25V.
                                      Could it be they used 25V caps because they were cheaper / available at that time?...
                                      02-11-2025, 12:22 PM
                                    • madscientist750
                                      Replacing electrolytic caps by solid caps on old motherboards
                                      by madscientist750
                                      I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                                      I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                                      I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                                      10-19-2025, 06:10 AM
                                    • black6host
                                      Replacement caps for Samson Resolv studio monitor 65A Amp board.
                                      by black6host
                                      Good day!
                                      I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                                      I'm going to replace the caps and I'll be the first...
                                      02-06-2024, 08:22 PM
