Dell H235P-00 recap
  • lucky13
    • Aug 2007
    • 412
    Dell H235P-00 recap
    After a power outage, Dell Optiplex 760 won't start. Power LED flashing amber.
    Suspect bad caps.
    Crack open the power supply, and sure enough. there are.
    C60 2200/10V > 2200/16V (Old cap measured 22uF & ESR 4.1)
    C107 2200/16V LPZ > 2200/16V (Old cap measured 2244uF & ESR 0.01) <Wow
    C114 680/16V > 1000/16V (Old cap measured 2uF & ESR 13.4)
    C119 2200/10V > 2200/16V (Old cap measured 333uF & ESR 1.61)
    On small board for fan, 100/25V > 2*47/25V (Old cap measured 0uF, ESR 30). I don't have any 100uF on hand so I twsited two 47uF together and soldered it in.
    Computer is back up and running.
    Hope this helps someone in the future.
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: Dell H235P-00 recap
    Were any of them bulging? Sounds like the bad caps were failed LTEC LZP and TK (or possibly LXY and ST). Maybe some Teapo SC, SEK, or SS thrown into the mix, or OST RLP or RLS? It almost sounds like one of them was actually in spec. Was it deformed?
    EDIT: It's true that such a low ESR reading and a higher-than-nominal-capacitance reading is indicative of high leakage current (either the electrolyte is attacking the aluminum oxide or it can no longer repair defects in the dielectric because it's starting to break down), unless it was an ultra low ESR capacitor but you don't find those in PSUs usually.
      • 31284
      none are in spec, the 0.01 esr one is almost 100% leaky if you have a tester that shows leakage.
      i have seen it myself, leakage goes up and sometimes the uf too! and esr goes down.
      • lucky13
        • Aug 2007
        • 412
        OK, here are some pictures.
        The small cap on the fan PCB is C818.
        I missed one on the list. I did not see the printing on the PCB. It is the 1500u (3rd one from the line up) that is not deformed. I replaced it with 1500u/16V FM.
        • Wester547
          • Nov 2011
          • 1268
          • USA.
          Okay, bulged LZGs, LZPs, and LXYs. The bastards - they used Rubycon in all the low stress positions and LTEC in the critical, higher stress positions. That looks like it might be an ADDA or Sunon fan. I hope it still works (it might need lubrication).
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            built in failure points.the caps and the "death adda" fan.
            • lucky13
              • Aug 2007
              • 412
              Hmm.. fan seems to be running fine with no strange noise. I need to research this "death adda" fan syndrome and get a replacement ready.
              • mitchw
                • Dec 2016
                • 152
                • Slovenia
                Hi, I am repairing the same PSU and despite changing all of the capacitors (even the main smoothing filter that was the main problem), I still get blinking orange light. All of them were bad, only the Nichicon ones tested good, go figure
                I noticed that the resistor R844 is crusty and it is measuring 180 ohms. This seems rather high. I used the cropped image from OP as my resistor has almost unrecognisable color bands.
                As far I decoded it, it seems that it could be 1 ohms 2%?
                Can someone decode the image and what resistor should I use? Or perhaps if someone has schematics for this thing
                • mitchw
                  • Dec 2016
                  • 152
                  • Slovenia
                  Nevermind, I think the 180 ohms is correct value.
                  It is now working. Like I said, it needed a full recap including all of the small value capacitors (e.g. 22uF 16V, etc.).
                  Main problem was open main/PFC capacitor (420V 150uF) and shorted PFC rectifier (10A 600V TO220), most likely blown because of open main capacitor.
                  • fildelo
                    • Sep 2012
                    • 4
                    • France
                    This thread is still useful in august 2019.
                    You made me want to repair my H235P-00 which only provided 1V on green PS-ON.
                    I had 320Vcc on the 420V/150uF. I did'nt change it.
                    I only replaced the bulged capacitors (3x 2200uF, 2x 1500 and 1x 680uF) and everything works again.
                    Thanks from France
                    • Raziel19935
                      • Aug 2019
                      • 16
                      • República Dominicana
                      hi i have 2 units of these, the mosfets and resistors are good (measured with the multimeter), there is no 5v in green, it is the h255e-01, has anyone encountered this problem?
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • varunviolin007
                        Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                        by varunviolin007
                        Hi guys,
                        I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                        I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                        Looking for someone experienced with older PC boards who uses...
                        07-29-2025, 11:53 PM
                      • Akhlz001
                        by Akhlz001
                        09-20-2025, 07:15 PM
                        Dell Thunderbolt Firmware
                        by SMDFlea
                        Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                        Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                        The SKU is in brackets (****)
                        EDIT: NVM65...
                        01-26-2025, 06:22 AM
                      • dell_sadness
                        Dell Latitude 3440 - Service tag ending in 0001 - Locked!
                        by dell_sadness
                        BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
                        Have extracted the BIN and want to know how to rebuild a clean BIOS
                        I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
                        I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
                        Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
                        11-12-2025, 02:54 PM
